    Duet Reprap Firmware 3.3 Software bug
    • illumaestheticundefined
      illumaesthetic
      Hi all,
      Modix 180X & 60X user here. We just updated everything to RR3.3 recently, noticed a weird bug. When printing, if the filament sensor ever triggers and pauses, it will proceed through the pause actions, park the carriage, but the status will be stuck at "printing" instead of "paused" making me unable to resume the print or send any other functions. This only seems to happen when the filament sensor triggers the pause, but will not do it when I hit pause or hit "change filament". This is a repeatable issue on both my 60X and 180X, which have been updated to firmware 3.3.
      This is the following config.g code for the filament sensor -
      M591 D1 P7 C"e0stop" L6.8 R10:200 E20 S1 ; BigTreeFilament Sensor
      Any help/luck and does anyone have this issue?
      ![alt text](278742503_3182287732054740_4027352952119022083_n.jpg image url)
        3.4 is out now. Can you update to see if the behaviour is the same?
        ComedianTF2undefined 1 Reply Last reply Reply Quote 0
        • ComedianTF2undefined
          ComedianTF2 @Phaedrux
          @phaedrux User confirmed that the pause behavior has been fixed
