    How to tune/calibrate heater feedforward?
    • oliof
      oliof last edited by
      RRF 3.4 has a new feature, heater feedforward. How do I determine the heater feedforward value(s) I need to set for my machine (and given filament)?
      <>Creality CR-20 IDEX Duet3 mini 5+<>RatRig V-Minion SKR RRF 1.1<>
        This is what I was told by DC42:
        heat the nozzle and let the temperature stabilise. Then commence extrusion at a fast rate (as fast as the extruder can reasonable manage without skipping) and watch the temperature. If there is an initial drop, then increase the feedforward. What you are looking for is either the temperature remaining steady, or rising by a small amount followed by a drop below target of a similar amount. When extrusion stops the reverse will happen, i.e. with no feedforward the temperature will rise and then gradually return to target.
        If you give that a try and it seems to work well I will add that to the M309 entry.
        o_lampe 1 Reply Last reply Reply Quote 1
        • demonlibra
          demonlibra last edited by
          What length of filament is enougth for this test?
            Phaedrux Moderator @demonlibra last edited by
            @demonlibra said in How to tune/calibrate heater feedforward?:
            How much filament does it take at max flow to impact the thermistor reading?
            • o_lampe
              o_lampe @Phaedrux last edited by
              @phaedrux
              I always assumed this feature would help with dual tool printers to heat up the idle tool from standby-temp to working temp before toolchange?
              Being able to look ahead was the reason for the dual gcode stream concept?
                dc42 administrators @o_lampe last edited by
                @o_lampe said in How to tune/calibrate heater feedforward?:
                One of the reasons.
                The purpose of heater feedforward is to better maintain an even nozzle temperature in high flow rate extruders, by anticipating the additional heat needed when the flow rate increases, instead of waiting for the temperature to drop before power is increased.
                • demonlibra
                  demonlibra last edited by demonlibra
                  @phaedrux said in How to tune/calibrate heater feedforward?:
                  Aluminum V6, heater 40 W, nozzle 0.4 mm, maximum flowrate around 10 mm3/sec.
