    UNSOLVED No function after update
    Firmware installation
    • Wladekcz
      Wladekcz last edited by
      Hello.
      Extrusion Control does not work after the update.
      Compensation & Calibration doesn't work either
      Turning on the translation into Polish suspends the viewing of temperatures.
      M122
      RepRapFirmware for Duet 3 MB6HC version 3.4.0 (2022-03-15 18:57:24) running on Duet 3 MB6HC v1.01 or later (standalone mode)
      Władekcz
      fcwilt dc42 Phaedrux 3 Replies Last reply Reply Quote 0
      • fcwilt
        fcwilt @Wladekcz last edited by
        @wladekcz
        3.4.1 is in the pre-release stage - perhaps it mentions some of the issues you are facing.
        Printers: A FT-5 with the 713 upgrade bits. A custom MarkForged style. A small Utilmaker style and a CoreXY from kits. Various hotends. All with a variety of Duets (2 and 3) running 3.3.0
          dc42 administrators @Wladekcz last edited by
          @wladekcz which firmware version were you running previously?
          Have you checked that you are also running version 3.4.0 of DWC?
            Phaedrux Moderator @Wladekcz last edited by
            @wladekcz said in No function after update:
            It's most likely that the tool isn't selected. Do you have a T0 in your config.g?
            What exactly doesn't work? Can you be more specific?
            Perhaps you should try uploading the full 3.4 zip file to the system tab in DWC to ensure everything is actually up to date.
            https://github.com/Duet3D/RepRapFirmware/releases/download/3.4.0/Duet2and3Firmware-3.4.0.zip
