    The tower motors ..... H E L P
    1.5k
    • tecnoundefined
      tecno
      The tower motors of a delta printer cannot be driven via CAN-connected expansion boards.
      WTF
      • tecnoundefined tecno referenced this topic
        Tentatively on target for 3.5. Sorry for the inconvenience.
        tecnoundefined 1 Reply Last reply Reply Quote 0
        • tecnoundefined
          tecno @Phaedrux
          @phaedrux said in The tower motors .....:
          When will that be? Next year?
            If I had to guess there may be a 3.5 beta within months.
            In the meantime, In RRF 3.4.1rc1 and later, delta towers driven from expansion board drivers might work if segmentation is enabled. So maybe worth trying.
            tecnoundefined 2 Replies Last reply Reply Quote 0
            • tecnoundefined
              tecno @Phaedrux
              @phaedrux
              M669 K3 S1 T1
              rc2
              No difference, M119 not stopped LED on or off and axis do not move but Z position is counting up on G28
                dc42 administrators @tecno
                @tecno have you tested movement of the tower motors individually using G1 H2 moves? See https://docs.duet3d.com/en/User_manual/Machine_configuration/Configuration_linear_delta#testing-the-motors-and-endstops-individually.
                Have you configured the delta parameters using M665? M669 is not used for delta printers.
                Please post your config.g file.
                • tecnoundefined
                  tecno @dc42
                  config.g
                  • tecnoundefined
                    tecno @tecno
                    G1 H2 X5
                    Error: G0/G1: attempt to move individual motors of a delta machine to absolute positions
                      @tecno the instructions on the page I linked to tell you to put the printer into relative movement mode first.
                      • tecnoundefined
                        tecno @dc42
                        Missed G91
                        But still no movement
                        tecnoundefined dc42undefined 2 Replies Last reply Reply Quote 0
                        • tecnoundefined
                          tecno @tecno
                          Now that my endstops are working I hope I can get help with motors.
                          • tecnoundefined
                            tecno @Phaedrux
                            @phaedrux said in The tower motors ..... H E L P:
                            So how do I activate segmentation if M669 is not to be used on Delta?
                              @tecno use M665 to set delta kinematics and the delta parameters first. Then use M669 with just S and T parameters (no K parameter) to enable segmentation.
                              • tecnoundefined
                                tecno @dc42
                                M575 P1 S0 B57600 ; enable support for PanelDue
                                M550 P"BigDelta" ; set printer name
                                M665 R300 L615 B275 H570 ; Set delta radius, diagonal rod length, printable radius and homed height
                                M666 X0 Y0 Z0 ; put your endstop adjustments here, or let auto calibration find them
                                M669 S1 T1 ; kinematics linear delta
                                M564 H0 S0 ; allow axis movement not homed
                                Still nothing
                                • gloomyandyundefined
                                  gloomyandy @tecno
                                  @tecno Do your drivers/motors work at all? What happens if you simply set them up using standard cartesian kinematics, can you move them then?
                                  • tecnoundefined
                                    tecno @gloomyandy
                                    @gloomyandy
                                    What lines to change?
                                      gloomyandy @tecno
                                      @tecno As I asked above, have you ever had your motors/drivers working with your current control board at all?
                                      • A Former User?
                                        A Former User
                                        This post is deleted!
                                        • tecnoundefined
                                          tecno @gloomyandy
                                          @gloomyandy
                                          Mini5 eth + 3pcs 1XD to DM556, so not with that configuration.
                                          • tecnoundefined
                                            tecno @A Former User
                                            @arnold_r_clark
                                            Can be done but the motors need high current so the Mini is not up to the task
