    Endstop issues
    394
    • tecnoundefined
      tecno
      I have following endstops https://www.festo.com/us/en/a/download-document/datasheet/150855
      BN = 24V
      BK = io input
      BU = GND
      Built in LED lights up when magnet triggers BUT Nothing gets activated on io input.
      Using Endstops Monitor plugin to visualize triggering.
      Tried all combinations on M574 without ! or !^
      40.out0 is 24V to BN
      M574 X2 S1 P"!^40.io1.in" ; configure switch-type (e.g. microswitch) endstop for high end on X via pin io0.in
      M950 P0 C"40.out0" ; config output
      M42 P0 S1 ; set pwm 100%
      Shorting input to GND triggers input. So is the connection wrong? Switch BN and BU ?
      • infiniteloopundefined
        infiniteloop
        The SME-8K is a sensor with (according to the data sheet) less-than-optimal accuracy; the +/- 0.1 mm repeatability tolerance adds up to the height of a typical first layer. A cheap microswitch would be an adequate replacement, a high-quality switch gives better results. In order to get the Festo to work, try this:
        Connect BN to GND, BU to V_IN (no PWM output needed), and BK to io1.in.
        Then, configure your end stop like this:
        M574 X2 S1 Pโ€œ^40.io.inโ€œ
        Should work.
        • tecnoundefined
          tecno
          @infiniteloop said in Endstop issues:
          Should work.
          Did not work. No LED at all.
          So time to dig out some mechanical end switches
          Just a note PWM out was easiest way to get power so it is needed ๐Ÿ˜‰
          infiniteloopundefined 2 Replies Last reply Reply Quote 0
            infiniteloop @tecno
            @tecno said in Endstop issues:
            Using a multimeter, what voltage do you read at BK when the Festo is at the magnet, what do you read when it's not?
            tecnoundefined 1 Reply Last reply Reply Quote 0
            • tecnoundefined
              tecno @infiniteloop
              @infiniteloop
              Connected as per your instruction = 0.2V with or without magnet
              infiniteloopundefined 1 Reply Last reply Reply Quote 0
                infiniteloop @tecno
                I wouldn't trust a PWM signal to be always high. Festo and their suppliers do not provide application notes, but this thing should be, at the bottom, a simple reed switch, which I suppose to work fine with 5V, too.
                  infiniteloop @tecno
                  Did you measure BK against BU?
                  • tecnoundefined
                    tecno @infiniteloop
                    @infiniteloop
                    Haven't tried to use 5V = same shit no go
                    So I will use some mechanical
                    Nightowlundefined 1 Reply Last reply Reply Quote 0
                    • Nightowlundefined
                      Nightowl @tecno
                      @tecno
                      I don't know anything about these proximity sensors, but experience with mechanical end switches is that they're less consistent.
                      Have you tried something like these or these? I replaced my mechanical switches with the UK ones, and they work really well - even at 5V.
                      Few things are more dangerous than taking the advice of someone who thinks he knows what he's doing.
                      I'm still on my learning curve, so take everything I say with caution!
                      RatRig 1075, Duet3 MB6HC, Sorotec SFM 1000 PV-ER milling motor, Hobbyist
                      • tecnoundefined
                        tecno @Nightowl
                        @nightowl999
                        Way too big for my taste, and yes I have tried.
                        • fcwiltundefined
                          fcwilt @tecno
                          @nightowl999
                          Just about every kind of inductive sensor you might need. This is the source I use.
                          Inductive Sensors Supplier
                          • tecnoundefined
                            tecno @fcwilt
                            @fcwilt
                            I know about them but way too expensive to get parts to Sweden.
                            • fcwiltundefined
                              fcwilt @tecno
                              @fcwilt
                              My bad - didn't know you were in Sweden.
                              • tecnoundefined
                                tecno @fcwilt
                                @fcwilt
                                No worries Frederick
                                • tecnoundefined
                                  tecno @tecno
                                  Problem solved !
                                  Micro switches on each tower now.
                                  A Former User? 1 Reply Last reply Reply Quote 1
                                  • A Former User?
                                    A Former User @tecno
                                    This post is deleted!
                                    fcwiltundefined 1 Reply Last reply Reply Quote 1
                                    • fcwiltundefined
                                      fcwilt @A Former User
                                      @arnold_r_clark said in Endstop issues:
                                      @tecno
                                      On my Delta i use These
                                      I use them for Z probes but never thought of using them for endstops.
                                      To date I have used micro-switches or IR beam-break detectors.
                                      Thanks for sharing another approach.
                                      • A Former User?
                                        A Former User @fcwilt
