Solved [3.4.1] Network disconnecting
After update I have had several disconnects to network.
@tecno What did you upgrade from?
@gloomyandy
rc2 -
@tecno said in [3.4.1] Network disconnecting:
Need more information. Which Duet (or other board) are you using?
Mini 5 ETH + 3of 1XD
Where are you seeing the disconnect? Is it DWC? Are you still able to ping the Duet? Have you tried rolling back to 3.4.1 rc2 to see if it resolved?
Took some time to get the error today, can confirm that it is DWC. Ping is OK. -
This has been several times during the day = remedy = power off and on again
This post is deleted! -
Reloading the page does not reconnect?
If it happens again, can you open the developer console tab on your browser and see if there are any errors shown there?
@phaedrux
Not possible to reload, only fresh boot
Will try to remember to do that.
Have not rolled back yet. Trying to get motors moving >> now all axis on Mini5 just have to rewrite my config.g -
Failed to load resource: net::ERR_CONNECTION_TIMED_OUT app.180e38d8.js:42 Failed to load built-in plugin Height Map _callee2$ @ app.180e38d8.js:42 app.180e38d8.js:42 ChunkLoadError: Loading chunk HeightMap failed. (error: http://192.168.1.124/js/HeightMap.92302efe.js) at Function.requireEnsure [as e] (app.180e38d8.js:1:3103) at DwcPlugin.loadDwcResources (app.180e38d8.js:42:430492) at loadDwcResources (app.180e38d8.js:42:429536) at _callee5$ (app.180e38d8.js:42:467890) at tryCatch (app.180e38d8.js:24:29930) at Generator.invoke [as _invoke] (app.180e38d8.js:24:31593) at Generator.next (app.180e38d8.js:24:30487) at asyncGeneratorStep (app.180e38d8.js:1:6267) at _next (app.180e38d8.js:1:6490) at app.180e38d8.js:1:6606 _callee2$ @ app.180e38d8.js:42 app.180e38d8.js:42 Error: HTTP request timed out at new ExtendableBuiltin (app.180e38d8.js:42:616222) at TimeoutError._createSuperInternal (app.180e38d8.js:1:9537) at new NetworkError (app.180e38d8.js:42:617467) at TimeoutError._createSuperInternal (app.180e38d8.js:1:9537) at new TimeoutError (app.180e38d8.js:42:618033) at q.ontimeout (app.180e38d8.js:42:493759) _callee5$ @ app.180e38d8.js:42 app.180e38d8.js:42 Error: Could not complete action because the connection has been terminated at new ExtendableBuiltin (app.180e38d8.js:42:616222) at DisconnectedError._createSuperInternal (app.180e38d8.js:1:9537) at new NetworkError (app.180e38d8.js:42:617467) at DisconnectedError._createSuperInternal (app.180e38d8.js:1:9537) at new DisconnectedError (app.180e38d8.js:42:617769) at q.onabort (app.180e38d8.js:42:493326) at app.180e38d8.js:42:494005 at Array.forEach (<anonymous>) at PollConnector.cancelRequests (app.180e38d8.js:42:493975) at PollConnector._callee2$ (app.180e38d8.js:42:495263)
Can you try disabling (or updating) your plugins and seeing if that has an effect?
Hi, I think I have found the issue. The AP I have been using has been working OK with WiFi for years but when I connected via cable it became unstable periodically. I took another AP and now I no longer have issues with disconnecting.
Hope this helps.
@tecno thanks, I'm glad you got it sorted.
Me too, was driving me nuts
