Intermittent WiFi Connection at Startup
@Phaedrux said in Intermittent WiFi Connection at Startup:
@Exerqtor How old is your board? Do you feel comfortable giving the solder points a touch with an iron and a dab of fresh solder?
Uhm i'm not 100% sute to be honest!
But yeah i'll pull out the iron and some flux paste and give it a reflow tomorrow and see if it does anything✌️
@Exerqtor Hey! I ended up switching to Klipper soon after my last post on this issue, so I don't use the WiFi on the Duet anymore.
But before I switched, one of the last things I did was check the WiFi networks that had been associated with my card using M587, and I found that there were a couple that were not on my network, not added by me; perhaps they were there from testing of the board or something, or maybe just corrupt memory? Anyway, I removed them all using M588 (I had to use M588 S"*" because one of the network names had weird, unprintable characters in it).
Then I re-associated with my network and confirmed that was the only one listed via M587.I can't say that solved the problem, but for the last several reboots before I upgraded it was connecting OK. Do you happen to have any spurious networks listed when you issue M587?
@tfjield said in Intermittent WiFi Connection at Startup:
SHAAAME
.... JK, it's actually almost my next step at this point, going the RRF on SBC route. But since getting hold on a rpi is what it is these days it's not really a valid optionBut before I switched, one of the last things I did was check the WiFi networks that had been associated with my card using M587, and I found that there were a couple that were not on my network, not added by me; perhaps they were there from testing of the board or something, or maybe just corrupt memory? Anyway, I removed them all using M588 (I had to use M588 S"*" because one of the network names had weird, unprintable characters in it).
Interesting, i will give that a go before i reflow the wifi module just to see if it's any difference!
@Exerqtor LOL, yeah, I know...
I really like RRF! This was my first time using it, and not only is it great, but the support here is top notch. Kudos to @Phaedrux and @dc42 and everyone else that contributes.
I ended up changing because I have a rather large printer (600 x 600 x 600 mm) that I'm using to print large prototypes of something before we invest in injection molding, and I need to crank them out as fast as possible. I upgraded my hotends to Takotos (they're great!) and went to Klipper, both for the speed. At this point, I think I'm limited by the residual stress in the plastic that causes warping if I try to print any faster.
Good luck with your problem! I'm with you, it didn't seem like hardware to me because it never dropped the connection once it got it. It was only during startup. And if I remember right, I could get it to connect again by turning the module off and on via software, but my memory here is hazy at this point... Clearing out those other SSID's made sense to me that it could have been the problem, but I really didn't run it long enough afterwards to confirm. I rarely restart my machine, so the annoyance wasn't a daily thing and it took quite a while to get any useful stats.
@tfjield Yeah i bet (and see) you have a reason for the swap!
I finally got the printer connected again, but in usual fashion i did more than one time at the time in a hope to get it up running. So i can't say for sure what actually did it.
Re-soldered the whole WiFi module and added more solder so that the solder points are fully filled on all pads. I also made a dedicated 2.4Ghz SSID for IoT devices and pointed the duet to that SSID, not it's connected and finally melting plastic again. So I HOPE this solved the issue.
Another side note, that MIGHT hint to the soldering being the problem is that i've had a somewhat annoying issue with the PanelDue backlight flickering. That flicker seem to have disappeared after i re-soldered the WiFi module.
Time will show if the problem is fixed or not, the printer have to work now so i'm not about to reboot it just to test my luck yet!
undefined Exerqtor referenced this topic
I have 8 machines all running on Duet2Wifi's with Panel Dues and identical settings. Two of them were plagued by this issues for the past year.
I was rebuilding one of them last week and decided to dig in an figure out what the issue was. I didnt think it was my router because all of them have reserved ip address. After hours of screwing with YAT and confirming that all the connections on the board were good, I cleared all the IP reservations and did a software update on my router. (EERO Mesh)
I was shocked to find that after the router firmware update, the issue was totally resolved on both the machines that had the issue. Not sure if it was the actual router firmware update, or the fact that I cleared the ip reservations and did new ones for each machine. Eitherway....the problem is gone.
undefined dc42 referenced this topic
