    Big Delta is moving
    3D Printing General Chat
    670
    • tecnoundefined
      tecno
      https://youtu.be/JSg1X5fbeDI
      droftartsundefined fcwiltundefined pjlundefined 3 Replies Last reply Reply Quote 3
        droftarts administrators @tecno
        @tecno Hooray! It's a bit squeaky?
        • Norderundefined
          Norder
          It sounds like someone is moving furniture. 😄
          The printer screams for oil. 😉
          DDA5X... 0.9° Stepper... Linearrails... Duet 2 Wifi... PT100 Board... Duet IR-Probe... Dyze Pro Kit up to 500°C.. etc
          Thingiverse
          • fcwiltundefined
            fcwilt @tecno
            @tecno said in Big Delta is moving:
            Try some MagnaLube.
            Why did you make such a small printer? 🤣 🤣
            tecnoundefined 1 Reply Last reply Reply Quote 0
            • tecnoundefined
              tecno @fcwilt
              @fcwilt @Günter-Jibben @droftarts
              Yes the carriages are a bit squeaky. Got the rails/carriages used (private sponsor) and I did Ultrasound clean the xross roller carriages and it would have been best to vacuum chamber oil the but as I don´t have one I have to use oil and try to soak the as good as I can.
              • pjlundefined
                pjl @tecno
                @tecno woah that is an absolute unit of a delta. can almost print doghouses 🐶
                • tecnoundefined
                  tecno @pjl
                  @pjl
                  For small Chihuahuas maybe 😉
                  • tecnoundefined
                    tecno @tecno
                    So at last first attempt to print
                    https://youtu.be/4n_GONJVpxI
                    • tecnoundefined
                      tecno @tecno
                      Benchy 120mm printspeed
                      https://youtu.be/2Eu-yxL0SU4
                      • tecnoundefined
                        tecno @tecno
                        https://youtu.be/yW5SKjOXiHM
                        450mm printspeed
