    deployprobe.g for Euclid not running
    1.2k
    • Adamfilipundefined
      Adamfilip
      Deploy prob has this logic
      seems to get stuck on this line
      if !move.axes[0].homed || !move.axes[1].homed
      echo "Running deployprobe.g"
      if !move.axes[0].homed || !move.axes[1].homed     ; If the printer hasn't been homed, home it
          M98 P"0:/sys/homexy.g"
      jay_s_ukundefined Stephen6309undefined 2 Replies Last reply Reply Quote 0
        jay_s_uk @Adamfilip
        @adamfilip do you have a homexy.g?
        how does it exactly get stuck?
        Adamfilipundefined 1 Reply Last reply Reply Quote 0
          Adamfilip @jay_s_uk
          @jay_s_uk
          i do have a homexy.g installed
          the echo line works,
          the M98 line works if i run it seperately.
          it just stops at that if statement line. doesnt continue with rest of the deploy.
            jay_s_uk @Adamfilip
            @adamfilip what comes next?
            Adamfilipundefined 2 Replies Last reply Reply Quote 0
              Adamfilip @jay_s_uk
              This post is deleted!
                Adamfilip @jay_s_uk
                @jay_s_uk
                Here is the entire file
                ; Euclid Probe Fixed Dock M401 Deploy Probe Macro
                ; RRF3.X Firmware Example
                ; saveas system/deployprobe.g
                ; comments and echo statements throughout are provided for convenience
                ;  __________________________________________________________________________
                ;  |                                * Probe Ready Position                  |
                ;  |                                  X150 Y150                             |
                ;  | * Dock staging position                                                |
                ;  |   X9 Y70                                                               |
                ;  | * Dock Exit Position                                                   |
                ;  |   X9 Y29                                                               |
                ;  |   X9 Y-21    X29 Y-21       X59 Y-21                                   |
                ;  | * Dock   * Dock Side  * Dock Preflight                                 |
                ;  |________________________________________________________________________|
                ; Above is example 300x300 bed to coorelate with macros and movements below.
                ; This example is for a fixed dock, fixed gantry/carraige and moving bed motion system.
                ; RailCore, Ender5, V-Core3, etc...
                ; coordinates are re-written below above the macros
                echo "stop 1"
                ; uncomment next line to echo the probe deploy state
                ; echo "Object Model Deployuser token =" ^sensors.probes[0].deployedByUser
                M564 H1 S0                   ; Allow movement BEYOND axes boundaries (for Y to reach probe dock)
                G91                          ; relative positioning
                echo "Lift Z in advance of deploy"
                G0 H2 Z15 F3000              ; move Z 15 for clearance above dock.
                ;                            ; need to figure out some safety check on this
                G90                          ; absolute positioning
                ; uncomment next line to echo the probe value
                ; echo "Probe Value =" ^sensors.probes[0].value[0]
                if sensors.probes[0].value[0]!=1000    ; if sensor is value other than 1000 do this
                  ; echo "deployuser token = " ^sensors.probes[0].deployedByUser
                  ; echo "Probe State = " ^sensors.probes[0].value[0]
                  abort "deployprobe start value Probe already picked up.  Manually return probe to the dock"
                ; if we're here we know it's becasue the above is true which I assume is because you have an NC switch as a probe.
                ; echo "Passed first logic test to deploy probe"
                ; Preflight position is X59 Y-21
                ; Dock Side position is at X29 Y-21
                ; Docked probe postion is at X9 Y-21
                ; Dock exit point is at X9 Y29
                ; Dock Re-Entry Staging Position is at X9 Y70
                ; Probe Ready Position X150 Y150
                ; echo "Probe Pickup macro running"
                G0 X59 Y-21 F6000              ; move to Preflight Position
                M400                          ; wait for moves to finish
                G0 X29 Y-21 F6000               ; move to Dock Side dock location
                ; uncomment next line to echo the probe deplot state
                ; echo "Object Model Deployuser token (before while loop) = " ^sensors.probes[0].deployedByUser
                G0 X9 Y-21 F3000                ; move over Dock
                G4 P500                       ; pause 0.5 seconds
                G0 X9 Y29 F300               ;  slide probe out of dock - slowly
                G0 X9 Y70 F3000               ; move to re-entry position
                echo "Probe Pickup complete"
                ; uncomment to echo the probe deploy state
                ; echo "Object Model Deployuser token (after while loop) = " ^sensors.probes[0].deployedByUser
                G0 X150 Y150 G3000            ; move to the center of the bed
                if sensors.probes[0].value[0]!=0
                  echo "Object Model Deployuser token (in abort if section)= " ^sensors.probes[0].deployedByUser
                  abort "Deployprobe endvalue not 0 Probe not picked up!  Deployt cancelled."
                M564 H1 S1                    ; Restrict movement to within axes boundaries (for normal Y movement)
                echo "Macro deployprobe.g complete"
                Adamfilipundefined jay_s_ukundefined 2 Replies Last reply Reply Quote 0
                  Adamfilip @Adamfilip
                  @adamfilip I run a macro that runs the deployprobe.g
                  M401 P1 ;Deployprobe
                  • Stephen6309undefined
                    Stephen6309 @Adamfilip
                    @adamfilip I use this code to check homing:
                    while iterations < #move.axes & move.axes[iterations].visible
                    	if !move.axes[iterations].homed
                    		G28
                    		break
                      jay_s_uk @Adamfilip
                      @adamfilip so if your X and Y (assuming they are driver 0 and 1) aren't homed, it should home. If they are homed, it should echo stop1.
                      Are you trying this with or without the motors homed?
                        Adamfilip @jay_s_uk
                        @jay_s_uk
                        I run this after i have already homed
                        this is my config if it helps
                        ; generated by RepRapFirmware Configuration Tool v2.1.5 on Wed Jan 08 2020 19:38:55 GMT-0500 (Eastern Standard Time)
                        ;M564 H0											; allow movement without homing
                        G90                                              ; send absolute coordinates...
                        M83                                              ; ...but relative extruder moves
                        M550 P"TitanXY"                                  ; set printer name
                        M669 K0                                          ; Motion Kinematics for Cartesian mode
                        M552 S1                                          ; enable network
                        M586 P0 S1                                       ; enable HTTP
                        M586 P1 S0                                       ; disable FTP
                        M586 P2 S0                                       ; disable Telnet
                        M569 P0 S0                           			; X Motor physical drive 0 goes backwards previously P0
                        M569 P1 S1										; Y Motor
                        M569 P2 S1                                      ; Z physical drive 2 goes backwards
                        M569 P3 S1                                  ; E0 Extruder physical drive 3 goes Forwards
                        ;M569 P4 S1                                      ; 2nd Y Motor on E1 Driver
                        M584 X0 Y1 Z2 E3                              ; set drive mapping , Y is on two drivers. E1 as well
                        M350 X16 Y16 Z4 I1                             ; configure microstepping without interpolation, previously 32
                        M350 E16 I1                                     ; configure microstepping with interpolation
                        M92 X80 Y80 Z800 E409             				; set steps per mm
                        M566 X900 Y900 Z50 E1600 						; Set maximum instantaneous speed changes (mm/min) JERK
                        M203 X21000 Y21000 Z500 E10000 				; Set maximum speeds (mm/min)
                        M201 X2000 Y2000 Z50 E5000 					; Set accelerations (mm/s^2)
                        ;M204 P1000 T3000								; Set printing and travel accelerations
                        M906 X1100 Y1100 Z1200 E1200 I30 				; Set motor currents (mA) and motor idle factor in per cent X1400 Y1400 Z1300
                        M84 S30 ; Set idle timeout
                        M572 D0 S0.01									; Pressure Advance                                        ; Set idle timeout
                        M208 X0 Y0 Z0 S1                                 ; set axis minima
                        M208 X300 Y300 Z550 S0                           ; set axis maxima
                        M574 X2 S1 P"!xstop"   ; X max active high endstop switch
                        M574 Y2 S1 P"!ystop"   ; Y max active high endstop switch
                        M574 Z1 S1 P"!zstop"   ; Z min active high endstop switch
                        ;Euclid Settings
                        M574 E1 S2
                        M558 K0 P5 C"^zprobe.in" H4 F500 60 T9000 A1 S0.01
                        G31 K0 P500 X0 Y-39 Z3.55
                        M557 X10:290 Y10:290 S40                      ; define mesh grid S86 =  Spacing 86mm
                        ;Magnetic Filament Monitor
                        ;M591 D0 P3 C"e1_stop" S1  ; filament monitor connected to E0_stop
                        ;M591 D0 ; display filament sensor parameters for extruder drive 0
                        M308 S0 P"bedtemp" Y"thermistor" T100000 B4138   ; configure sensor 0 as thermistor on pin bedtemp
                        M950 H0 C"bedheat" T0                            ; create bed heater output on bedheat and map it to sensor 0
                        M140 H0											; Map heated bed to heater 0
                        M143 H0 S120                                     ; set temperature limit for heater 0 to 120C
                        M307 H1 B0 R1.591 C187.0:154.2 D7.57 S1.00 V24.1
                        M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin e0temp
                        M950 H1 C"e0heat" T1                             ; create nozzle heater output on e0heat and map it to sensor 1
                        M143 H1 S285									; set temperature limit for heater 1 to 280C
                        M307 H1 R1.71 C175.5:157.9 D5.73 S1.00 V24.1
                        ;Chamber Temp
                        M308 S2 P"Chamber" Y"thermistor" T100000 B4725 C7.06e-8 A"Chamber"
                        M950 F0 C"fan2" Q500                         ;create fan 2 on pin fan0 and set its frequency
                        M106 P0 S0 H-1                            ; set fan 0 value. Thermostatic control is turned off
                        ;M950 F1 C"fan1" Q500                             ; create fan 1 on pin fan1 and set its frequency
                        ;M106 P1 S1 H1 T45                                ; set fan 1 value. Thermostatic control is turned on
                        ;M950 F2 C"fan1" Q500                             ; create fan 2 on pin fan1 and set its frequency
                        ;M106 P2 S1 H1 T45                                ; set fan 2 value. Thermostatic control is turned on
                        M563 P0 D0 H1 F0                                 ; define tool 0
                        G10 P0 X0 Y0 Z0                                  ; set tool 0 axis offsets
                        G10 P0 R0 S0                                     ; set initial tool 0 active and standby temperatures to 0C
                        ;M564 S0 H0										;disable homing and no limits on movement
                        jay_s_ukundefined fcwiltundefined 2 Replies Last reply Reply Quote 0
                          jay_s_uk @Adamfilip
                          @adamfilip it should just run then. I don't see anything wrong with the logic.
                          What version of RRF are you running?
                            Adamfilip @jay_s_uk
                            @jay_s_uk
                            Board: Duet 2 WiFi (2WiFi)
                            Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.1 (2022-06-01)
                            Duet WiFi Server Version: 1.26
                            • fcwiltundefined
                              fcwilt @Adamfilip
                              @adamfilip
                              If you have two steppers for the Y axis why do they not appear in your M584 commands?
                              Normally it would look like this (based on the comments):
                              M584 X0 Y1:4 Z2 E3
                              Thanks.
                                Adamfilip @fcwilt
                                @fcwilt actually I use too, its changed to only a signal Y.
                                sorry some old notes still linger
                                  Adamfilip @jay_s_uk
                                  @jay_s_uk yeah its weird.
                                  I restarted the machine. did home all.
                                  ran the macro and nothing.
                                  not even the first echo statement showed up in console
                                  Adamfilipundefined fcwiltundefined 2 Replies Last reply Reply Quote 0
                                    @adamfilip
                                    I copied the entire deployprobe.g code into a macro and it runs on its own
                                    so it seems like the deployprobe.g itself isnt being run when asked with
                                    fcwiltundefined oliofundefined 2 Replies Last reply Reply Quote 0
                                    • fcwiltundefined
                                      fcwilt @Adamfilip
                                      @adamfilip
                                      Just to provide another point of view.
                                      I no longer home things as needed because I found I did not like homing taking place unexpectedly because I had tried to do something that required the printer to be homed, like mount the probe.
                                      So now I just check that the printer is homed and abort if it is not.
                                      I have a Euclid on one of my printers but I don't use the deploy/retract feature that is part of the firmware. I call my routines to mount/unmount the probe as needed. I have found that for normal operations I can keep the probe mounted except during actual printing. Any operation that needs the probe, such as setting the Z=0 Datum, mounts the probe and leaves it mounted. In the print start code just before actual printing begins the probe is unmounted.
                                      Just food for thought.
                                      • fcwiltundefined
                                        fcwilt @Adamfilip
                                        @adamfilip said in deployprobe.g for Euclid not running:
                                        Doesn't the firmware track the state of the probe and only run the deploy/retract routines when it thinks it needs to?
                                        • oliofundefined
                                          oliof @Adamfilip
                                          @adamfilip If the euclid is your only probe, drop the P1 and only run M401. Alternately, try P0 because your probe definition assignes ID 0.
                                          Adamfilipundefined 1 Reply Last reply Reply Quote 1
                                            Adamfilip @oliof
                                            @oliof Thank you both M401 and M401 P0 worked!
