    Hotend temperature not rising at all
    494
    • Velviaundefined
      Velvia
      I have a 50w cartridge connected to a duet smart effector, to the H+ and H- input. I have tested the cables with a volt meter. I've also tried with a different cartridge. Here's my config and M122
      M308 S0 P"temp1" Y"thermistor" T118000 B3950       ; configure sensor 0 as thermistor on pin temp1
      M950 H0 C"out1" T0                                 ; create bed heater output on out1 and map it to sensor 0
      M307 H0 B0 S1.00                                   ; disable bang-bang mode for the bed heater and set PWM limit
      M308 S1 P"temp0" Y"pt1000"                         ; configure sensor 1 as PT1000 on pin temp0
      M950 H1 C"out2" T1                                 ; create nozzle heater output on out2 and map it to sensor 1
      M143 H1 S350                                       ; set temperature limit for heater 1 to 350C
      M950 F1 C"out9" Q400                               ; create fan 1 on pin out9 and set its frequency
      M106 P1 S0 H1 T50                                  ; set fan 1 value. Thermostatic control is turned on
      M950 F2 C"out6" Q500                               ; create fan 2 on pin out6 and set its frequency
      M106 P2 S0.5 H-1                                   ; set fan 2 value. Thermostatic control is turned off
      M563 P0 S"DragonHF" D0 H1 F0                       ; define tool 0
      M112
      M122
      RepRapFirmware for Duet 3 MB6HC version 3.4.1 (2022-06-01 21:09:01) running on Duet 3 MB6HC v1.01 or later (SBC mode)
      Board ID: 08DJM-9P63L-DJ3S0-7JKF0-3S86T-TAJR8
      Used output buffers: 1 of 40 (12 max)
      Static ram: 151000
      Dynamic ram: 64368 of which 24 recycled
      Never used RAM 135160, free system stack 156 words
      Tasks: SBC(ready,0.5%,476) HEAT(notifyWait,0.0%,318) Move(notifyWait,0.0%,267) CanReceiv(notifyWait,0.0%,944) CanSender(notifyWait,0.0%,356) CanClock(delaying,0.0%,333) TMC(notifyWait,7.7%,92) MAIN(running,91.4%,1231) IDLE(ready,0.3%,30), total 100.0%
      Owned mutexes: HTTP(MAIN)
      Last reset 00:04:55 ago, cause: software
      Last software reset at 2022-06-20 00:17, reason: User, GCodes spinning, available RAM 135280, slot 2
      Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0x00000000 SP 0x00000000 Task SBC Freestk 0 n/a
      Error status: 0x00
      Aux0 errors 0,0,0
      Step timer max interval 134
      MCU temperature: min 37.2, current 37.4, max 37.9
      Supply voltage: min 23.9, current 24.0, max 24.0, under voltage events: 0, over voltage events: 0, power good: yes
      12V rail voltage: min 12.2, current 12.2, max 12.3, under voltage events: 0
      Events: 1 queued, 1 completed
      Driver 0: standstill, SG min 0, mspos 840, reads 11182, writes 19 timeouts 0
      Driver 1: standstill, SG min 0, mspos 904, reads 11182, writes 19 timeouts 0
      Driver 2: standstill, SG min 0, mspos 24, reads 11182, writes 19 timeouts 0
      Driver 3: standstill, SG min 0, mspos 8, reads 11187, writes 14 timeouts 0
      Driver 4: standstill, SG min 0, mspos 8, reads 11190, writes 11 timeouts 0
      Driver 5: standstill, SG min 0, mspos 8, reads 11190, writes 11 timeouts 0
      Date/time: 2022-06-20 00:22:05
      Slowest loop: 37.38ms; fastest: 0.04ms
      === Storage ===
      Free file entries: 10
      DMs created 125, segments created 5, maxWait 23082ms, bed compensation in use: none, comp offset 0.000
      === MainDDARing ===
      Scheduled moves 5, completed 5, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
      === AuxDDARing ===
      Bed heaters 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0
      Segments left: 0
      Movement lock held by null
      Telnet is idle in state(s) 0
      File is idle in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      SBC is idle in state(s) 0
      Daemon is idle in state(s) 0
      Aux2 is idle in state(s) 0
      Code queue is empty
      === CAN ===
      Messages queued 2639, received 0, lost 0, boc 0
      Longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 50 (min 50), ts 1477/0/0
      Tx timeouts 0,0,1476,0,0,1161 last cancelled message type 30 dest 127
      === SBC interface ===
      Transfer state: 5, failed transfers: 0, checksum errors: 0
      RX/TX seq numbers: 12038/12038
      SPI underruns 0, overruns 0
      State: 5, disconnects: 0, timeouts: 0 total, 0 by SBC, IAP RAM available 0x2b880
      Buffer RX/TX: 0/0-0, open files: 0
      === Duet Control Server ===
      Duet Control Server v3.4.1
      Code buffer space: 4096
      Configured SPI speed: 8000000Hz, TfrRdy pin glitches: 0
      Full transfers per second: 41.00, max time between full transfers: 241.3ms, max pin wait times: 76.3ms/18.8ms
      Codes per second: 0.25
      Maximum length of RX/TX data transfers: 3080/992
      Whenever I try to heat it, I just get:
      Error: Heater 1 fault: temperature rising too slowly: expected 2.32°C/sec measured 0.00°C/sec
      Homegrown, grass fed and organically built 350mm delta
      • fcwiltundefined
        fcwilt @Velvia
        @velvia
        I don't know the ins and outs of the "smart effector".
        How does it connect to the 6HC board?
        Velviaundefined 1 Reply Last reply Reply Quote 0
        • Velviaundefined
          Velvia @fcwilt
          @fcwilt to a 2-pin connector at "out_2"
          • fcwiltundefined
            fcwilt @Velvia
            @velvia said in Hotend temperature not rising at all:
            And it also connects to "temp0"?
            • Velviaundefined
              Velvia @fcwilt
              @fcwilt pt1000 to temp_0, yes. It reads the temp fairly correctly +/- 1-2 degrees, but cartridge won't start heating at all.
              • fcwiltundefined
                fcwilt @Velvia
                Have you run heater tuning yet?
                Example: M303 H1 S200
                • Velviaundefined
                  Velvia @fcwilt
                  @fcwilt Yes, but it fails, since it won't start heating at all. It works fine for the bed.
                  • fcwiltundefined
                    fcwilt @Velvia
                    @velvia
                    Well seems to me that problems must be:
                    • in the wiring
                    • with the board output
                    You say have tested the wiring.
                    Have you tried connecting to the out1 connections - with the appropriate changes to the **config.**g file - just to see if the problems line with out2?
                    • Velviaundefined
                      Velvia @fcwilt
                      @fcwilt out1 is the heatbed. I have tested out3, and still the same issue. It could still be the wiring, I'm just not sure how to test it other than with a volt meter. Maybe I've connected it wrong on the smart effector, I don't know.
                      https://docs.duet3d.com/hardware/smart_effector/smart_effector_v2_wiring.png
                      I connected the output from the mainboard to the ones circled in green. And HEATER to the heating cartridge in the hotend.
                      • fcwiltundefined
                        fcwilt @Velvia
                        @velvia
                        There is a problem with that diagram unrelated to your issue. Notice on the input H+ is shown as a solid yellow shape. On the heater output H+ is shown as a yellow/black shape. It means nothing from a practical point of view since heaters don't have polarity.
                        You mention that out 1 is the heated bed. So you are not using the actual bed heater output, out 0?
                        If you have tested both out 2 and out 3 then the problem must lie in the wiring.
                        What do you get when you measure the resistance across the lead ends that connect to the 6HC?
                        • Velviaundefined
                          Velvia @fcwilt
                          @fcwilt said in Hotend temperature not rising at all:
                          Nothing. It seems to be a poor connection/crimp. Not the first time during this build. I'll try redoing it. It was very hard, since I had to use thick cables for tiny crimps.
                          • fcwiltundefined
                            fcwilt @Velvia
                            The connectors used for those outputs accept fairly large wires easily.
                            What size wire are you using?
                            What sort of crimp tool are you using?
                            • Velviaundefined
                              Velvia @fcwilt
                              @fcwilt You're right, the output side is fine, but the input on the smart effector is terrble.
                              Velviaundefined fcwiltundefined 2 Replies Last reply Reply Quote 0
                              • Velviaundefined
                                Velvia @Velvia
                                @velvia 18 AWG
                                • Velviaundefined
                                  Velvia @Velvia
                                  @velvia Tested the wires again, red to red and black to black, no problems. They are both whole.
                                  • fcwiltundefined
                                    fcwilt @Velvia
                                    You mean to say they did not use the same connectors for both the input and output connections?
                                    That is not a good idea at all.
                                    You can always "cheat" a little. Short lengths of small gauge wires are not going to be a problem.
                                    So if you have the tools you could solder and heat-shrink two 50mm lengths (or so) of small gauge wire to the long large gauge wires coming from the 6HC. That would make crimping the small connectors much easier.
                                    • fcwiltundefined
                                      fcwilt @Velvia
                                      You need to verify the resistance across the ends of the two wires that would connect to the 6HC.
                                      • Velviaundefined
                                        Velvia @fcwilt
                                        @fcwilt Did that now and discovered the issue. Yet another poor crimp by me. It threw me off since it worked the first time I tested it. Now the heater works
                                        fcwiltundefined 1 Reply Last reply Reply Quote 1
                                        • fcwiltundefined
                                          fcwilt @Velvia
                                          @velvia
                                          Glad to hear you got it sorted.
                                          Velviaundefined 1 Reply Last reply Reply Quote 1
                                          • Velviaundefined
                                            Velvia @fcwilt
                                            @fcwilt Thank you for all the help!
