    I could use some help
    682
    63.5k
    • A Former User?
      A Former User @fcwilt
      @fcwilt installation? You mean I have to install them?????
      A Former User? 1 Reply Last reply Reply Quote 1
      • A Former User?
        A Former User @A Former User
        @droftarts as Ian might say, and then he’d send a link to the documentation.
        • A Former User?
          @fcwilt but I have read them.
          • A Former User?
            @fcwilt @droftarts
            Just thought I’d share this with you:
            This is how the board of the Duet3D Mini 5+ is set up:
            And this is how the motors I hope to install today are set up:
            Talk about harmonious!
            Mac
            • A Former User?
              @droftarts @fcwilt
              Here’s a series a pictures I’d like to share with you. They tell a story. I hope you’ll figure it out.
              0A6CD37A-9F43-4502-871D-74DD7845AC90.jpeg 30E4A125-7B32-4907-BEAC-A4C188E1FF84.jpeg A8926053-72FB-4000-B109-1AD5855E631A.png F99A5766-A0E6-4051-91B2-A5BB2862C29F.jpeg
              • A Former User?
                @fcwilt @droftarts Do you see what I did wrong? With all 4 motors?
                Mac
                • fcwiltundefined
                  fcwilt @A Former User
                  @mac said in I could use some help:
                  Mac
                  No I don't.
                  Based on the diagram you posted the yellow/brown pair are connecting to one phase of the stepper and the red/black pair are connecting to the other phase.
                  And the connections to the Duet seem correct.
                  What do you think is wrong?
                  • A Former User?
                    @fcwilt this is why I’m not an electrical engineer. I decided to try shorting the two phases to make sure my “discovery” was correct. As you have indicated, post’s 1 and 3 (bottom and 3rd up) are a phase, and post’s 2 and 4 are the other phase. So that means red and yellow go together, and brown and black go together. Whew, my head is spinning!
                    Thanks for commenting. Your affirmation is helping, a lot.
                    Mac
                    • fcwiltundefined
                      Mac
                      On the Stepper and the Duet A+ and A- are one phase, B+ and B- are the other phase.
                      • A Former User?
                        @fcwilt it’s hard for me to understand this because what I always see is A+, A-, B+, B-. I don’t know which wire of each phase is minus, or plus for that matter. That’s what’s hanging me up on this issue. If it doesn’t water, (I’ve heard that), why is the wiring of the motors presented that way? Why does Duet3D label their pins that way? You know?
                        • fcwiltundefined
                          Here is a fairly typical stepper diagram showing how applied signals translate into steps:
                          Down on the lower left, notice the chart that has STEP 1,2,3,4 in the left column.
                          Notice that for Step 1 the + and - symbols under the columns for A+, B+, A- and B-.
                          That tells you when you apply a positive voltage to A+ and B+ and the corresponding negative voltage to A- and B- the stepper will move to Step 1.
                          As the board changes the voltages applied to the coils, so they match the chart, the stepper will move from Step 1 to Step 2 to Step 3 to Step 4.
                          And while it may not be obvious if the polarity applied to one of the coils happens to be the opposite of what the chart calls for the only thing that happens is the stepper turns in the reverse direction.
                          So, as long as you connect the A terminals for the Duet to the one of the coils and the B terminals of the Duet to other coil you can control the direction of rotation with the S parameter of the M569 commands.
                          • A Former User?
                            @fcwilt it truly is a magic borne of human ingenuity.
                            The motors didn’t show up today. Bummer. I’m hope for mail on Sunday now.
                            So could you talk about 24volts versus 12 volts. I know the change would cost me, but what are the hardcore benefits?
                            Mac
                            • deckingmanundefined
                              deckingman @A Former User
                              Mac
                              I already addressed that question in my post of 30th June. Scroll up and read the last bit again. Essentially you could get more torque out of the motors and use more powerful heaters. But if 12V gives you enough torque and enough heater power for your printer, you'll not see any benefit.
                              • A Former User?
                                A Former User @deckingman
                                @fcwilt the motors arrived at 8:55 PM.
                                What, exactly, does RRF want to know about these motors?
                                What line of the config.g file needs to be edited, and how should it appear with the correct info?
                                Mac
                                  @mac Motor current is all. A good setting is about 85% of the rating. So around 1.2 to 1.3 amps (1200 to 1300 mA) for those motors which are rated at 1.5Amps.
                                  • A Former User?
                                    @deckingman just finished installing them. It all went well.
                                    fcwiltundefined 1 Reply Last reply Reply Quote 1
                                    • fcwiltundefined
                                      Once you are ready to test the new steppers remember to:
                                      • execute M564 H0 S0 so you can jog each axis without homing or worrying about axis limits.
                                      • use the jog buttons to verify each axis is moving in the correct direction
                                      In the homing code I posted for you there was an absolute move at the end of each file.
                                      Comment those absolute moves out for now, until we know the homing moves are working.
                                      • A Former User?
                                        @fcwilt my clock says 10:45; I've been up since 2 AM.
                                        I just plugged the power into the machine.
                                        My plan is to use RRF to tell the config.g file about these new motors. I'm still UNCLEAR as to what I should tell it. I'm also unclear about how to code it.
                                        You referred to some code you wrote? Recently, or before?
                                        I'm going to take this one step at a time, and try not to jump forwards without knowing where I'm going.
                                        Mac
                                        deckingmanundefined A Former User? 2 Replies Last reply Reply Quote 0
                                          @mac There is an old adage which goes something like, "catch a man a fish and he'll feed himself for a day, but teach a man how to catch fish and he'll feed himself for life". Now I'm not trying to be disrespectful in any way, and I'll continue to help when I can, but if we carry on like this, you will have an endless list of questions and especially with the time differences due to geographic locations, you are going to have to wait for the answers. That's only going to add to your frustrations.
                                          I'd like to teach you how to fish rather than keep feeing you now and then. So might I respectfully suggest, that you start looking at the documentation https://docs.duet3d.com/. Ian ( @droftarts ) has put a lot of time and effort into it and it really is very user friendly. Just start typing something in the search box at the top (e.g. "stepper motors") and it'll return a host a relevant topics which in turn will give you the information you need - often with actual code examples.
                                          If you get used to doing this, you'll find you get all the answers you need much more quickly. Of course, we fellow users are on the whole a friendly bunch and we'll continue to help as a when our commitments allow. But we only know what we know from reading the documentation (and asking the odd question now and again).
                                          • A Former User?
                                            @mac Okay, I found the "code." (It was back at 510.)
                                            First, I feel like I have to tell my config.g that these new motors are X, where X is 1.2 - 1.3 amps / 1200 - 1300 mA.
                                            I just set all the the motors to 1200 mA.
                                            NOTE: I keep looking at the Z motor / Steps per mm; it's set at 4000? The Max. Speed Change (mm/s) is set at 1, the Max. Speed (mm/s) is set at 10, and the Acceleration (mm/s-squared) is set at 200? Is that right?
