    I could use some help
    682
    64.7k
    • fcwiltundefined
      fcwilt @Nightowl
      @nightowl said in I could use some help:
      @fcwilt
      I've got to hand it to you, Frederick. You have tha patience of Job.
      Uh... I like a challenge?
      A Former User? Nightowlundefined 2 Replies Last reply Reply Quote 1
      • A Former User?
        A Former User @fcwilt
        @fcwilt
        G91
        G1 H1 Y-220 F3600
        Send
        fcwiltundefined A Former User? 2 Replies Last reply Reply Quote 0
        • fcwiltundefined
          fcwilt @A Former User
          @mac
          Hey mac,
          What am I seeing?
          Did something work as expected for once? 😉
          • A Former User?
            A Former User @A Former User
            @fcwilt @droftarts @alankilian @Nightowl
            link text
            • fcwiltundefined
              @mac said in I could use some help:
              link text
              Hey mac,
              Nice but G1 H2 is not the same as G1 H1.
              To make use of the endstop for homing, you have to use G1 H1.
              • A Former User?
                @fcwilt yep one down, two to go.
                • A Former User?
                  @fcwilt of course there has to be something weird going on.
                  I changed the H2 to H1. When I hit SEND, the board went back a bit, then stopped. So I sent the instructions 3 more times to get the bed all the way back to the end stop.
                  So H2 makes the bed home as is expected. And H1 does something unexpected.
                  • A Former User?
                    @fcwilt the printer's back to its old tricks. It's pounding on the front of the bed when I tell it to home. I'm just trying to get it to do what it did, and it's telling me something I won't write. I'm thinking the same thing towards it.
                    • A Former User?
                      @fcwilt I'm having a hard time believing this, but it's true.
                      I sent G91
                      Then I wrote G1 H2 Y-220 F2600 (not 3600) (that was just a typo, but I'm not going to change it).
                      Now the jog menu to the right of Home Y is available. Before, it wasn't. (Like I had to Home Y to get the jog menu to function).
                      Now, when I use the jog menu to send the bed forwards 50mm, it goes all the way to the front of the printer.
                      Then, when I send the code again (G1 H2 Y-220 F2600) it goes all the way back to the end stop.
                      And I see that in the Status box, Y is showing as -220.0
                      It seems to me that DWC is making shite up, Frederick. What say you?
                      • A Former User?
                        @fcwilt I understood what you said, but when I used that code it did not work. Instead, the bed moved towards the end stop, stopped, and I had to push the button again and again to make it get there. But it never did because the firmware said you’re at 0 where you are, and that’s that.
                        A Former User? fcwiltundefined 2 Replies Last reply Reply Quote 0
                        • A Former User?
                          @fcwilt I’m done for today. Did something to my ear that’s killing me.
                          fcwiltundefined 1 Reply Last reply Reply Quote 1
                          • fcwiltundefined
                            I don't know what to say.
                            You did a series of short G1 H1 moves and they behaved as they should.
                            But a long G1 H1 move did not.
                            That suggests a stepper configuration issue.
                            • fcwiltundefined
                              @mac
                              Here is the meaning of the various H parameter options for a G1 move:
                              H0 no special action (default)
                              H1 terminate the move when the endstop switch is triggered and set the axis position to the axis limit defined by M208. On delta printers, H1 also selects individual motor mode as for H2. Normally used with relative motor coordinates (see G91).
                              H2 Individual motor mode. X refers to the X motor, Y refers to the Y motor, and so on. Normally used with relative motor coordinates (see G91).
                              H3 terminate the move when the endstop switch is triggered and set the axis limit to the current position, overriding the value that was set by M208.
                              H4 terminate the move when the endstop switch is triggered and update the current position (supported in RRF 3.2-b4 or newer)
                              Notice that H1, H3 and H4 do respond to the triggering of the endstop switch but H2 does not.
                              H1 is used for homing.
                              H2 is often used to move an un-homed axis in the homing code of another axis.
                              I've never had an occasion to use H3 or H4.
                              • A Former User?
                                @fcwilt I’ve been looking at the M208 lines in my config.g.
                                M208 X0 Y0 Z0 S1
                                M208 X220 Y220 Z240 S0
                                S1 means Forwards? S0 means backwards.
                                Why do those M208 lines end with S commands?
                                • fcwiltundefined
                                  M208 X0 Y0 Z0 S1
                                  I know S1 is different than S0. I’ll have to review above before I can finish this post.
                                  Are you feeling better?
                                  And if you recall I mentioned my preferred short form:
                                  M208 Xmin:max Ymin:max Zmin:max
                                  where there is no S0/S1 to remember - which I never could.
                                  But for the old, two line way, S1 is min, S0 is max.
                                  So your two lines are setting X, Y and Z min as 0, X and Y max as 220 and Z max as 240.
                                  Fredric
                                  • A Former User?
                                    @fcwilt not really I kind of punctured my ear. A bit wobbly.
                                    I read your bit about the H commands. I wish H1 would do what it’s supposed to on my machine.
                                    I’ve been looking at the gcode info on the duet site.
                                    Maybe the H-command issues are related to the X or the Z somehow. Maybe working on X will provide some insight. Do you have any Job left in you to put up with my stupidity?
                                    Mac
                                    • fcwiltundefined
                                      Mac
                                      Mac, I am more than happy to help you in anyway I can. At this point I am determined to understand why code that works fine for me on all my printers is not working as it should for you.
                                      I have a theory about why the Y homing code is not working but it just a theory at this point. It will take a bit of testing to determine if my theory is correct.
                                      You posted that you were having success doing G1 H1 Y-10 commands and it moved 10mm at a time and the DWC display for the position of Y was consistent with those moves.
                                      Is that correct?
                                      If it is correct I would like you to do another test, starting with the bed somewhere in the middle of it's travel, so it has a ways to go before it reaches the endstop switch.
                                      Then from the DWC console:
                                      • issue a M119 command to check the state of the endstops
                                      • issue a G91 command to set relative movement mode which is necessary for homing
                                      • issue as many G1 H1 Y-10 F3600 moves as it takes to get the bed to the position where the endstop switch is triggered
                                      • check the DWC Y position display after each move to see if anything odd is happening
                                      • when you finally reach the position were the endstop switch is triggered issue another M119 to again check the state of the endstops
                                      What I am trying to check is if the problem only occurs when you try to do long Y moves but short Y moves, like 10mm, work fine.
                                      Thanks much. Wait until you feel better. Ear pain can really make it tough to focus and want to do anything.
                                      A Former User? 5 Replies Last reply Reply Quote 0
                                      • A Former User?
                                        @fcwilt the family has turned in. I’ll do these new tests first thing in the morning.
                                        I absolutely want to finish this project with you.
                                        Are you okay with the 0, 1 and 2 motor assignments? Please check those lines in the latest config.g. The ports are assigned as: “!^io5_in”, “!^io6_in”, and “!^io2_in” based on a discussion I had with @alankilian.
                                        Mac
                                        • fcwiltundefined
                                          Mac
                                          You mean the M569 commands for steppers? While I can verify the syntax of the commands, the only way to verify if they have the correct values is through testing. For instance if the M569 command for the X axis says driver 0 is used but the X axis stepper is connected, by mistake, to driver 5 that will only be found is during testing or by visually verifying connections to the board.
                                          As to the "ports" I assume you mean the M574 commands for the endstops?
                                          Again I can verify the syntax but I cannot verify if the values are correct without testing. For example the presence of the ! character says that an NO switch is being used. But is that true? That can only be determined by viewing that actual switch and how it is wired and/or by testing.
                                          I can say that the ^ character is incorrect. That is used to enable pull-up resistors for inputs on Duet 2 hardware. But Duet 3 hardware has fixed pull-up resistors on most inputs, including those you listed in your post. The ^ character doesn't cause a problem because it has no effect. But you might as well remove it.
                                          Hope you feel better tomorrow. I have a number of chores to help the wife with but I will check for messages when I can.
                                          • Nightowlundefined
                                            Nightowl @fcwilt
                                            @fcwilt
                                            Well, you've certainly found a good one! 😧
                                            Few things are more dangerous than taking the advice of someone who thinks he knows what he's doing.
                                            I'm still on my learning curve, so take everything I say with caution!
                                            RatRig 1075, Duet3 MB6HC, Sorotec SFM 1000 PV-ER milling motor, Hobbyist
