Solved Update 1HCL firmware from SBC
How do i update 1HCL firmware from a SBC running Duet3?
Also the main board still shows old firmware on the status message even after running apt update/upgrade.
@highfreq Use the standard
apt update
/apt upgrade
method, see here. In SBC mode you should never attempt to update anything by uploading files on the web interface.PS: If it displays the wrong firmware even after the
reprapfirmware
has been updated, try reinstalling it by runningsudo apt install --reinstall reprapfirmware
. Or just useM997
/M997 Bnnn
wherennn
is the CAN address of the 1HCL. -
@chrishamm it worked!! thanks.
