    Help on custom Delta printer build
    3D Printing General Chat
    delta build help custom custom diy delta dimensional accuracy 3d printing 3d-printers
    • Yiannisundefined
      Yiannis
      Hello everyone!
      I am building a custom delta 3d printer and I could use some help on calculating the rod lengths.
      I made a simulation of the geometry in the following link
      http://danalspub.com/DKcalc/?he=1000&ve=2000&dr=900&lr=1550
      The vertical extrusions will be 2000mm as I already have them.
      The horizontal extrusions at 1000mm give me a printable radius of 316mm which I am happy with.
      Is the ratio of the horizontal extrusions and rod lengths in the simulation correct or is there is a better solution?
      Thanks in advance for any help!
      lord binkyundefined breedundefined 2 Replies Last reply Reply Quote 0
        I don't know much about delta printers, but everything I do know comes from here
        https://docs.duet3d.com/en/User_manual/Machine_configuration/Configuration_linear_delta
        https://docs.duet3d.com/en/User_manual/Tuning/Delta_calibration
        • lord binkyundefined
          lord binky @Yiannis
          @yiannis i used the openscad delta simulator to maximize my stability for my delta over the print area when designing the parts : effector carriages, and arm spacing. The frame is a rostock max metal, and the arms are 360mm haydn magball arms. I did get improvements in my printer optimizing for stability so it's what i'd recommend using for any variables you don't have locked down.
            lord binky
            If your making your own arms, I did a test (yes i haven't shared it before now but i had another trick up my sleeve i wanted to test out and grab comparison data from the accelerometer) and got improvements on ringing/ on 360mm arms by reinforcing them midway. It does not affect the arms as long as the articulation is centered on the arms.20220713_181028.jpg
            • breedundefined
              breed @Yiannis
              @yiannis wow. Big delta. Where you getting a 640mm dia heated bed?
              Yiannisundefined 1 Reply Last reply Reply Quote 0
              • Yiannisundefined
                Yiannis @breed
                @breed No need for a heated bed I am printing ceramics
