    6HC PanelDue Ribbon-cable
    PanelDue
    • lbtqsbundefined
      lbtqsb
      I am currently trying to follow the guide for using the sd-card on the PanelDue with 6HC
      https://docs.duet3d.com/User_manual/Connecting_hardware/Display_PanelDue
      Is the Orientation
      A)
      or
      B)
      (Do not worry - board of course is not powered…)
      Thanks in advance! Cheers!
        You'd need to compare this table
        https://docs.duet3d.com/en/User_manual/Connecting_hardware/Display_PanelDue#duet-3-mb6hc-using-ribbon-cable
        With the pinout from the wiring diagram for the 6HC
        https://docs.duet3d.com/duet_boards/duet_3_mb6hc/duet_3_mb6hc_wiring_diagram_v1.0_v1.01.png
        lbtqsbundefined 1 Reply Last reply Reply Quote 1
          dc42 administrators @lbtqsb
          @lbtqsb it's B, with the red stripe on the end near the CAN connector.
          • lbtqsbundefined
            lbtqsb @Phaedrux
            @phaedrux
            Thanks so much! (Sorry for my lazyness…)
            Is this correct then:
            Wondering why only (beside the RED being 10 (?)) only the most outer 2 and not 4 are cut away then?
            Or is my interpretation the wrong way round?
            Thanks for the fast reply!
            Did I get it right or wrong with the little paper-schematic?
            Thanks! Cheers!
            • lbtqsbundefined
              lbtqsb @dc42
              This post is deleted!
                @lbtqsb the red stripe should be the Pin 1 conductor, not pin 10.
                • lbtqsbundefined
                  lbtqsb @dc42
                  Thanks PanelDue now works! (Ups, so I got the theory upside down, looking on the paneldue-pcb with the pins pointing not towards you but out backwards, I think I got it all wrong from then on, anyway, as long as it works in reality…)
