    Suppress driver warning message
    • CR3Dundefined
      CR3D
      Dear Community and @dc42 ,
      we have installed a special print head for which we do not tap all four pins of the motor connector. All you have to do is rub off 2 phases and the integrated servo driver of the print head recognizes the speed and position to be driven. The problem here is that we are of course entitled to receive the driver error message. This in turn blocks our console in the long run and thus blocks the host when sending commands via USB. We are currently using firmware 3.4.1.
      So my question is, how is it possible to display the message only once and then not further?
      Disabling the driver is of course not an option.
      Thanks for your help
      Christian from CR-3D
      Homepage:
      www.cr-3d.de
      Facebook:
      https://www.facebook.com/cr3d.official
      Our Discord Server
      https://discord.gg/SxRaPNuRdA
      Thingiverse Profile:
      https://www.thingiverse.com/cr-3d_official/about
        dc42 administrators @CR3D
        @cr3d if you set the motor current to less than 500mA then the message should be suppressed.
        CR3Dundefined 1 Reply Last reply Reply Quote 0
        • CR3Dundefined
          CR3D @dc42
          @dc42 Thank you!
          It worked 🙂
          Homepage:
          www.cr-3d.de
          Facebook:
          Our Discord Server
          • dc42undefined dc42 marked this topic as a question
