    Prusa slicer G code flavor
    1.1k
    • usernoobundefined
      usernoob
      What gcode flavor do you use in prusa slicer reprap or reprap/sprinter? I currently use reprap firmware but I was wondering if there are significant pros/cons to using one or the other.
        The sprinter version is much older. Use RepRap.
        usernoobundefined 1 Reply Last reply Reply Quote 1
        • usernoobundefined
          usernoob @Phaedrux
          @phaedrux got it thank you! It seemed like the more appropriate choice anyhow but good to have someone reaffirm the choice
          Norderundefined 1 Reply Last reply Reply Quote 0
          • Norderundefined
            Norder @usernoob
            I was wondering what the better choice would be.
            Then I probably intuitively (or accidentally) made the right choice. 🙂
            But what EXACTLY differentiates the two now, I would like to know.
            Does anyone happen to have a link to more detailed information ?
            Google Translate
            --- Original Text ---
            Ich hatte mich das auch schon gefragt was wohl die bessere Wahl ist.
            Habe dann auch wohl intuitiv (oder zufällig) die richtige Wahl getroffen. 🙂
            Aber was die beiden jetzt GENAU unterscheidet, wüsste ich doch schon gerne.
            Hat da jemand zufällig einen Link zu einer genaueren Info ?
            DDA5X... 0.9° Stepper... Linearrails... Duet 2 Wifi... PT100 Board... Duet IR-Probe... Dyze Pro Kit up to 500°C.. etc
            Thingiverse
            Rushmere3Dundefined 1 Reply Last reply Reply Quote 0
            • Rushmere3Dundefined
              Rushmere3D @Norder
              @norder I'd imagine it's to do with the gcode commands that are used by the respected firmware.
              This is a list of gcodes, and you can see some are not used by Sprinter.
              https://reprap.org/wiki/G-code
              Follow my adventures in 3D Printing, laser cutting and electronics. https://linktr.ee/Rushmere3D
              Norderundefined 1 Reply Last reply Reply Quote 1
              • Norderundefined
                Norder @Rushmere3D
                WOW, that's a lot that Sprinter doesn't support.
                One wonders why the PrusaSlicer still has this option, because there are important commands that Sprinter does not know at all.
                Thanks for the link, @Rushmere3D.
                Tip: If you search for Sprinter on the page (Strg + F), it will be faster because the page is very long, so there is a lot to read. 🙂
                Google Translate
                WOW, das ist aber eine Menge die Sprinter nicht unterstützt.
                Da fragt man sich doch, warum hat der PrusaSlicer noch diese Option, denn da sind ja wichtige Befehle dabei die Sprinter gar nicht kennt.
                Danke für den Link, @Rushmere3D.
                Tipp: Auf der Seite nach Sprinter suchen lassen (Strg + F), dann geht es schneller, denn die Seite ist sehr lang, also viel zu lesen. 🙂
                Thingiverse
                  If you search the prusa slicer github you can find the discussion on the switch from reprap/sprinter to reprap flavor. Basically to adopt modern reprap syntax.
