    SuperSlicer question
    • tecnoundefined
      tecno
      I am getting tired of S3D and want to get new functions with latest SS.
      On my Voron 0.1 I want to have hotend fan always on 100% no matter what.
      M950 F0 C"fan0"                                ; // PART FAN
      M106 P0 S0 H-1				       ; P0 = fan0 S0 = Speed 0 H-1 = Disable Termostatic mode
      M950 F1 C"fan1" 		               ; // TOOL FAN
      M106 P1 S1				       ; P1 = fan1 S1 = Speed 100%
      M563 P1 H1 F1                                  ; P1 = tool1 H1 = heater1 F1 = fan1
      G10 P1 X0 Y0 Z0                                ; set tool 0 axis offsets
      G10 P1 R0 S0                                   ; set initial tool 0 active and standby temperatures to 0C
      SS posts M107 and it is stopping my hotend fan = BIG NO NO
      How can I get back to normal that is no matter what code this fan will always be on?
        jay_s_uk @tecno
        @tecno said in SuperSlicer question:
        M106 P1 S1
        M106 P1 S1 H1 T45 that would come on when the hotend is above 45 degrees
        M563 P1 H1 F1
        this line is mapping the wrong fan to the tool. It should be F0 not F1
        tecnoundefined 1 Reply Last reply Reply Quote 0
        • tecnoundefined
          tecno @jay_s_uk
          @jay_s_uk said in SuperSlicer question:
          F0 is partcooling and it is working
            jay_s_uk @tecno
            @tecno the part cooling fan is the fan that should be mapped to the tool, not the hotend cooling fan
            • tecnoundefined
              tecno @jay_s_uk
              @jay_s_uk
              OK, so F0 het+re will not affect M107 to kill hotend fan?
                jay_s_uk @tecno
                @tecno correct.
                Thermostatic fans aren't controlled with M106/M107
                info from the wiki for the F parameter of M563
                F The print cooling fan of the tool, default 0. Use this parameter if you are not using fan 0 as the print cooling fan for the tool you are defining. You do not need to, and should not, map thermostatic fans to tools. To map more than one fan to the tool, the definition would typically look like this:
                • rexxundefined
                  rexx
                  why not just use the always on pins then? select vin for ps voltage or 12v to that pin set i think the plug is the same just move it over to it
                  • tecnoundefined tecno referenced this topic
