    Duet3D USB connection is not working
    Using Duet Controllers
    555
    • Marethyuundefined
      Marethyu
      I bought my Duet 3D Mini 5+ Wifi from Rat Rig. When I raised my issues to them, they asked me to report this on this board.
      After software update my Duet wouldn't connect to the SBC and status LED on the board stays off. I already tryed all recomendations hier in the board, using differnt USB cables, USB ports and computers but in no configuration COM-port is showing up in the devicelist.
      Please let me know how to proceed.
        Can you go through this guide and let us know what you find?
        https://docs.duet3d.com/en/User_manual/Troubleshooting/Duet_wont_respond
        • Marethyuundefined
          Marethyu
          I followed the points one by one.
          When I connect the Duet to the PC via USB, only the two LEDs for 3.3V and 5V light up. The status LED remains off as well as all other LEDs.
          I can't see a COM port in the device manager. Not even if I swap USB cables, USB ports or computers, even if I use a USB hub.
          Also after performing the "Fall-back procedure #2" no COM port appears.
            Have you loaded the Bossa software yet? Does a port become selectable there?
            • Marethyuundefined
              Marethyu
              Yes, I've tried the Bossa software, but that doesn't show the connection either.
                And the reset jumper has been applied and then removed?
                  jay_s_uk @Phaedrux
                  @phaedrux @Marethyu bossa doesn't work with a duet 3 mini 5+. you need to double tap the reset button to make a USB drive appear. then drag the .uf2 file over, which will cause it to reboot
                    Phaedrux Moderator @jay_s_uk
                    @jay_s_uk said in Duet3D USB connection is not working:
                    Thanks for the catch!
                    • Marethyuundefined
                      Marethyu
                      The Duet 3 mini 5+ has no reset jumper only a reset button.
                      I also tried double tapping the reset button, but this didn't change anything and COM-port is still not showing up.
                        jay_s_uk @Marethyu
                        @marethyu it doesn't show as a com port, it shows as a folder, like a usb drive
                          droftarts administrators
                          @marethyu for manual Mini 5+ firmware update, see https://docs.duet3d.com/User_manual/RepRapFirmware/Updating_firmware#duet-3-mini-5-wifiethernet
                          • Marethyuundefined
                            Marethyu
                            @jay_s_uk no matter what I do, neither a COM port nor a folder is displayed.
                            The only two things that work reliably are the 5V and 3.3V LEDs.
                            @droftarts I've already read that, but it can't be executed because I can't get a working connection to the board.
                              droftarts administrators @Marethyu
                              @marethyu Is there any way you can confirm that your USB leads are definitely data leads? Many USB leads sold are power only. Is there any damage to the USB port on the Duet?
                              It is strange that the STATUS LED is off, not flashing or pulsing. If you double click the reset button does it pulse from bright to dim and back again, even though it doesn't show up on the desktop?
                              • Marethyuundefined
                                Marethyu
                                As I wrote before I tried different ports, cables and computers without any effect.
                                The USB cable I use now was previously used for data transfer and it worked perfectly. So I'm sure it's a USB data cable.
                                I can't see any damage to the Duet's micro USB port. I also compared the USB port of the Duet with the micro USB port of a Raspberry pi, but can't find any differences.
                                The STATUS LED does not light up, blink or pulse when I connect the board to the computer. When I double tap the reset button nothing happens.
                                  @marethyu Okay, I think we need to replace the board under warranty. How long ago did you purchase the board from RatRig?
                                  • Marethyuundefined
                                    Marethyu
                                    I bought the board in February 2022.
                                      Please send an email to warranty@duet3d.com and CC your reseller. Include a link to this forum thread and the details of your original purchase. You'll receive a reply with a form to fill out.
