    Magnetic Filament Monitor installation direction
    Filament Monitor
    489
    • BoAundefined
      BoA
      What is the right orientation of MFM? There are no markings to which side filament needs to be feeded.
      At least I could not find any information about that.
      Norderundefined 1 Reply Last reply Reply Quote 0
      • Norderundefined
        Norder @BoA
        @boa
        Here is a photo of a built-in magnet filament sensor. (Duet Docs)
        DDA5X... 0.9° Stepper... Linearrails... Duet 2 Wifi... PT100 Board... Duet IR-Probe... Dyze Pro Kit up to 500°C.. etc
        Thingiverse
        BoAundefined 1 Reply Last reply Reply Quote 0
        • BoAundefined
          BoA @Norder
          @norder I saw that photo, but is there any difference from which side filament comes in?
          • Norderundefined
            Norder @BoA
            @boa
            I don't have this sensor, so I can't answer the question.
            But I don't think you have to wait long until someone here can give you an answer to your question.
            Thingiverse
            • PetrKroupaundefined
              PetrKroupa
              My setup....
              BigOne:Duet3 6HC +1LC + Rpi5 +SSD, mosquito hotend, 400x400x420
              SmallOne : Duet3 6HC +1LC + Rpi5 +SSD, mosquito hotend, 210x250x210
              Petr
              • BoAundefined
                BoA @PetrKroupa
                @petrkroupa So this is the oposite to what is on the photo from documentation. Hmm... that would mean it works both ways.
                  It's counting pulses, so I don't think it matters which direction it rotates.
                  • BoAundefined
                    BoA @Phaedrux
                    @phaedrux But it also recognizes direction. So I would expect measured movement would have to correlate with extruder movement in terms of movement direction, but this seems not to be the case.
                      Phaedrux Moderator @BoA
                      @boa said in Magnetic Filament Monitor installation direction:
                      Well the firmware knows the commanded direction for extrude and retract.
