    Problems with homing the x-axis
    • heinrich.platauundefined
      heinrich.platau
      Hello everyone
      I have a problem with my printer / duet board.
      Suddenly (after 1,5 years working perfectly) it is not possible to home the x-axis.
      If I send the command, the printer head is moving just a small distance right and left (along the x-axis) from its position. The distance is about 1 or 2 cm. Also there is a strange noise.
      During that failed homing process, the duet shows the following message:
      G28 X
      Warning: motor phase B may be disconnected reported by driver(s) 0
      I have checked the stepper motor for a mecahnical failure. But the stepper seems to be ok.
      Can you help me and give me some advice? How can I check wether the On-Board Driver on the Duet Board is defective?
      I use a DuetBoard 2 (Ethernet) with firmware version 3.2.1
      Please tell me, if i should post any further information
        jay_s_uk @heinrich.platau
        @heinrich-platau fully check the wiring for your motor.
        use a multimeter so you can verify each of the coils
        heinrich.platauundefined 1 Reply Last reply Reply Quote 0
          heinrich.platau @jay_s_uk
          @jay_s_uk
          You are right!! Problem solved!
          I thought about the worst case but I'd better check the most obvious error.
          Thanks.
          Thread can be closed!
