    LIS3DSH Accelerometer not detected on Duet 3 6hc - How to?
    364
    • pro3dundefined
      pro3d
      Can someone help with configureing accelerometer?
      I have followed the documentation on each point I think.. How ever I am not sure if I should route the CS cable somewhere else as the picture in docs show.. It shows a duet 3 mini I think.
      Am I supposed to use all the TEMP doughterboard pins or also some others? I am confused
      Second picture is from the docs
      Valkyrie DIY High Temp 3D Printer
      R&D - Engineering Designer - Viking 3D Printers
      https://vkingprinter.com/
      pro3dundefined 1 Reply Last reply Reply Quote 0
      • pro3dundefined
        pro3d @pro3d
        @pro3d
        I added a 510 ohm resistor to the SDO and now it detects the meter
        • pro3dundefined pro3d has marked this topic as solved
        • pro3dundefined
          pro3d
          Just an update. This was all very simple when using the inputshaper plugin! Great work guys
          damaged_goodsundefined 1 Reply Last reply Reply Quote 1
          • damaged_goodsundefined
            damaged_goods @pro3d
            @pro3d my printer is very large. The distance from the mainboard to the accelerometer is approx 5 meters. Will the ribbon wire in your pictures work?
            thanks for any assistance,
            David
            Phaedruxundefined dc42undefined 2 Replies Last reply Reply Quote 0
              Phaedrux Moderator @damaged_goods
              @damaged_goods Unlikely. A shielded twisted pair cable would be better. USB3 cables are often recommended but those aren't available at 5m lengths.
              damaged_goodsundefined 1 Reply Last reply Reply Quote 0
                dc42 administrators @damaged_goods
                @damaged_goods if your main board is a Duet 3 then a CAN-connected accelerometer board would be more suitable. We're planning to release one soon, or if you can't wait you can use a TOOL1LC board.
                  damaged_goods @Phaedrux
                  @Phaedrux Thank you
                    damaged_goods @dc42
                    @dc42 Thanks David. I can wait 🙂
