    Layer tracking with variable layer heights
    Duet Web Control
    832
    • tmreithundefined
      tmreith
      Within my gcode, I have the following per layer. The current layer and the current Z value.
      ; layer 1, Z = 0.499
      ; layer 64, Z = 9.249
      However DWC seems to be calculating layers from a perceived Z height and layer heights.
      My code mixes layer heights at 0.100mm to 0.150mm depending on the feature.
      What is the best way to instruct DWC to report the correct amount of layers?
      It is currently reporting 64 of 59 layers at the end of the print.
      Norderundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
      • Norderundefined
        Norder @tmreith
        @tmreith
        Does this print also include support?
        Support is usually printed with a layer height of 0.2mm and for this reason the layers are incorrectly specified.
        Check out this thread
        Google Translate
        --- Original Text ---
        Enthält dieser Druck auch Support ?
        Support wird meist mit 0,2mm Layerhöhe gedruckt und aus diesem Grund kommt es zu einer falschen Angabe der Layer.
        Guck Dir dazu folgenden Thread an
        DDA5X... 0.9° Stepper... Linearrails... Duet 2 Wifi... PT100 Board... Duet IR-Probe... Dyze Pro Kit up to 500°C.. etc
        Thingiverse
        tmreithundefined 1 Reply Last reply Reply Quote 0
        • tmreithundefined
          tmreith @Norder
          @norder thanks for the reference. My support layers are in-sync with the print layers.
          The first 15 layers post raft, are at 0.100mm and the remaining layers are at 0.150mm
          64 is the correct of amount of total layers. It appears to be the 59 that is under calculating layers. The target amount of layers is incorrect.
          • tmreithundefined
            tmreith @tmreith
            @tmreith Note: the first 15 layers are at 0.100mm in height, the remaining layers are at 0.150mm. The error in the total amount of layers is due to a calculation within DWC looking possibly at the total height and dividing by 0.150mm which is giving the error of the missing 5 layers.
            15 layers @ 0.100mm vs 10 layers @0.150mm
            Norderundefined 1 Reply Last reply Reply Quote 0
            • Norderundefined
              Norder @tmreith
              @tmreith
              I have never noticed such a miscalculation.
              Maybe that's because I pay more attention to the height in mm, if it's necessary.
              It will certainly not be long before someone can say something about it or has suspicions.
              A little patience 😉
              Google Translate
              Mir ist so eine Fehlberechnung noch nicht aufgefallen.
              Das liegt vielleicht daran das ich eher auf die Höhe in mm achte, wenn es denn mal notwendig ist.
              Es wird sicher nicht lange dauern bis jemand etwas dazu sagen kann oder Vermutungen hat.
              Etwas Gedult 😉
              Thingiverse
              • tmreithundefined
                tmreith @Norder
                @norder
                R = (1-4) : 4 layers - raft mix
                A = (5-19) : 15 layers at 0.100mm
                B= (20-76) : 57 layers at 0.150mm
                Total 76 layers
                I have uploaded a sample file for the above cube with variable layer heights to show the effect.
                10X10X10.gcode
                • Norderundefined
                  Norder @tmreith
                  @tmreith
                  This is what the Prusa GCode Viewer shows me...
                  The first layer is an incredible 0.5mm thick... it certainly won't be a 0.4mm nozzle.
                  The number of 76 layers is displayed on the right edge.
                  I have colored the heights of the layers (see screenshot on the left).
                  Have you ever tried another slicer to see if it shows the correct number of layers?
                  Google Translate
                  Das zeigt mir der Prusa GCode Viewer an...
                  (Screenshot siehe oben)
                  Die erste Schicht ist unglaubliche 0,5mm dick... eine 0,4mm Düse wird es bestimmt nicht sein.
                  Die Anzahl von 76 Layern wird am rechten Rand angezeigt.
                  Ich habe die Höhen der Schichten farblich anzeigen lassen (siehe links auf dem Screenshot).
                  Hast Du schon einmal einen anderen Slicer ausprobiert ob der eine korrekte Layeranzahl anzeigt ?
                  Thingiverse
                  • Norderundefined
                    Norder @Norder
                    I simulated the GCode on my printer and the following values came out.
                    The layer heights are only correct from layer 29, before that they deviate extremely from 0.1mm.
                    Google Translate
                    Ich habe den GCode mal auf meinem Drucker simuliert und dabei sind folgende Werte heraus gekommen.
                    Erst ab Layer 29 sind die Schichthöhen korrekt, vorher weichen sie doch schon extrem von der 0,1mm ab.
                    Thingiverse
                      Phaedrux Moderator @tmreith
                      @tmreith said in Layer tracking with variable layer heights:
                      Yes this may be the case.
                      What version of firmware and DWC are you running?
                      • tmreithundefined
                        tmreith @Phaedrux
                        @phaedrux
                        Board: Duet 3 MB6HC (MB6HC)
                        DSF Version: 3.3.0
                        Firmware: RepRapFirmware for Duet 3 MB6HC 3.3 (2021-06-15)
                        Duet Web Control 3.3.0
                        I thought there was a keyword like "layer count" or "num_layers" that was being read in past before DWC would try to calculate based on a layer_height value and the max Z value.
                        The mixed layer heights are definitely messing with the layer calculation.
                        I have full control over the gcode, so I can add in the required commented value to drive the DWC.
                          Can you update to 3.4.1?
                          • tmreithundefined
                            tmreith @Phaedrux
                            @phaedrux
                            unfortunately not. The machines are validated to 3.3 and would require a re-validation effort if I updated the firmware.
                            Is there a layer count keyword that is still being used in the g-code? I can insert what ever DWC needs to establish a value vs trying to calculate from a Z height and the layer height value.
                              See if you can add num_layers=## to the end of the file.
                              https://forum.duet3d.com/topic/27471/num_layers-in-g-code/4?_=1662052426372
                              • tmreithundefined
                                tmreith @Phaedrux
                                @phaedrux
                                I added the following to the end of the gcode file, and there was no effect.
                                ; num_layers=64
                                I looked at the source code for FileInfoParser.cpp and it definitely has a routine to parse "num_layers" keyword. I am not sure why the DWC doesn't seem to see the value.
                                I have another machine running 3.4.1, so I'll give it a try on that machine over the weekend.
                                • tmreithundefined
                                  tmreith @tmreith
                                  @tmreith
                                  Works on a Duet 2 Wifi running 3.4.1.
                                  Added the following to the last line in gcode file.
                                  ; num_layers: 64
                                    Maybe a limitation or bug in the DuetPi version?
                                    @chrishamm
                                    • chrishammundefined
                                      chrishamm administrators @tmreith
                                      @tmreith @Phaedrux Parsing the number of layers (aka num_layers) isn't supported in DSF or RRF v3.3. In order to use this feature you must be on v3.4 or newer.
                                      PS: Until v3.4 RRF/DSF attempt to compute the number of layers from the object height (last absolute G0/G1 Z command in the print file) and the layer height. If you have an extra G1 Z lift command in there, the reported object height and the number of layers are probably wrong.
                                      Duet software engineer
                                      Phaedruxundefined 1 Reply Last reply Reply Quote 1
                                        Phaedrux Moderator @chrishamm
                                        @chrishamm said in Layer tracking with variable layer heights:
                                        His end code Z lift has ; E on the line.
                                          chrishamm administrators @Phaedrux
                                          @phaedrux It is correctly processed by DSF 3.4.1, I just checked (object height = 11.05mm). The number of layers was not present in the original file but once added that is parsed correctly, too.
