Connect duet 3 to Rpi 4 with USB cable
Is it possible to connect the Duet 3 to a rpi 4 with a usb cable or any other method without the ribbon cable, as it is too short
@tratoon no. it needs to be SPI, so the ribbon cable
@jay_s_uk is there anyway to only connect necessary pins or are all of them necessary. If so which ones need to be connected?
@jay_s_uk would it be pins SBC 3.3v, mosi,miso,Spck,gnd
@jay_s_uk I looked at https://forum.duet3d.com/topic/20883/duet3-sbc-wiring-without-the-ribbon-cable/14 but I still don’t understand which pins need connections and where they go on both boards also some of the poster’s pin outs don’t match mine like TFR_rdy and spi_npcs0
@tratoon yes, you can just connect the pins required but I really wouldn't recommend running a cable any longer than the one provided as you will run into issues. SPI really inst great over long cables.
Why do you need the SBC? For WiFi? -
@jay_s_uk yes and as far as I’m aware faster upload speeds . Coul you please explain the differences.
undefined TRATOON marked this topic as a question
undefined TRATOON has marked this topic as solved
