Unable to make External stepper driver work
Hi i am using an duet 3 6hc with and 1xd expansion board and i am trying to connect an external stepper driver i am currently not getting any movement when i try to extrude or retract on the dashboard. im pretty sure i have my wiring right but i dont know if my config is 100 percent from what i have looked into i seems to be okay. I send the command to check if xd board is conected with m115 b122, thanks. This is extruder i am trying to connect https://docs.dyzedesign.com/pulsar.html#reprap-firmware
code_text ; Configuration file for Duet 3 (firmware version 3.3) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v3.3.10 on Fri May 06 2022 00:13:26 GMT+0100 (British Summer Time) ; General preferences G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"L3D" ; set printer name ; Wait a moment for the CAN expansion boards to start G4 S2 ; Network M552 P10.10.1.4/ S1 ; enable network and acquire dynamic address via DHCP M586 P0 S1 ; enable HTTP M586 P1 S0 ; disable FTP M586 P2 S0 ; disable Telnet ; Drives M569 P0.0 S0 ; physical drive 0.0 goes backwards M569 P0.1 S0 ; physical drive 0.1 goes backwards M569 P0.2 S0 ; physical drive 0.2 goes backwards M569 P0.3 S0 ; physical drive 0.3 goes backwards M569 P122.0 S1 R1 T3:3:3:5:0 M584 X0.0 Y0.1 Z0.2 E0.3:122.0 ; set drive mapping M350 X16 Y16 Z16 E16:16 I1 ; configure microstepping with interpolation M92 X320.00 Y320.00 Z320.00 E492.45:3200.00 ; set steps per mm M566 X900.00 Y900.00 Z60.00 E120.00:120.00 ; set maximum instantaneous speed changes (mm/min) M203 X6000.00 Y6000.00 Z600.00 E1200.00:1200.00 ; set maximum speeds (mm/min) M201 X500.00 Y500.00 Z20.00 E250.00:250.00 ; set accelerations (mm/s^2) M906 X2800 Y2800 Z2800 E1200:2700 I60 ; set motor currents (mA) and motor idle factor in per cent M84 S200 ; Set idle timeout ; Axis Limits M208 X20 Y0 Z0 S1 ; set axis minima M208 X1100 Y1000 Z1500 S0 ; set axis maxima ; Endstops M574 X1 S1 P"io1.in" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin io1.in M574 Y1 S1 P"io2.in" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin io2.in M574 Z1 S2 ; configure Z-probe endstop for low end on Z ; Z-Probe M950 S0 C"io7.out" ; create servo pin 0 for BLTouch M558 P9 C"io4.in" H10 F240 T12000 ; set Z probe type to bltouch and the dive height + speeds G31 P500 X-22 Y-10 Z3.66 ; set Z probe trigger value, offset and trigger height M557 X50:1000 Y0:1000 S50 ; define mesh grid ; Heaters M308 S0 P"temp0" Y"pt1000" ; configure sensor 0 as PT1000 on pin temp0 M950 H0 C"out0" T0 ; create nozzle heater output on out0 and map it to sensor 0 M307 H0 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit M143 H0 S280 ; bed ; set temperature limit for heater 0 to 280C M308 S1 P"temp1" Y"thermistor" T100000 B3950 ; configure sensor 1 as thermistor on pin temp1 M950 H1 C"122.out0" T1 ; create bed heater output on 1.out0 and map it to sensor 1 M307 H1 B1 S1.00 ; enable bang-bang mode for the bed heater and set PWM limit M140 H1 ; map heated bed to heater 1 M143 H1 S150 ; set temperature limit for heater 1 to 150C ; dyze M308 S2 P"spi.cs2" Y"rtd-max31865" ; configure sensor 2 as PT100 on pin spi.cs2 M950 H2 C"out1" T2 ; create nozzle heater output on out1 and map it to sensor 2 M307 H2 B0 S2 ; disable bang-bang mode for heater and set PWM limit M143 H2 S480 ; set temperature limit for heater 2 to 150C M308 S3 P"spi.cs1" Y"rtd-max31865" ; configure sensor 3 as PT100 on pin spi.cs1 M950 H3 C"out2" T3 ; create nozzle heater output on out2 and map it to sensor 3 M307 H3 R0.882 K0.330:0.000 D22.74 E1.35 S1.00 B0 V28.3 ; disable bang-bang mode for heater and set PWM limit M143 H3 S480 ; set temperature limit for heater 3 to 150C M308 S4 P"spi.cs0" Y"rtd-max31865" ; configure sensor 4 as PT100 on pin spi.cs0 M950 H4 C"out3" T4 ; create nozzle heater output on out3 and map it to sensor 4 M307 H4 R0.964 K0.156:0.000 D21.85 E1.35 S1.00 B0 V28.3 ; disable bang-bang mode for heater and set PWM limit M143 H4 S480 ; Fans M950 F0 C"out6" Q500 ; create fan 0 on pin out6 and set its frequency M106 P0 C"Part fan" S1 H0 T45 ; set fan 0 value. Thermostatic control is turned off M950 F1 C"out5" Q500 ; create fan 1 on pin out5 and set its frequency M106 P1 C"noctua" S1 H-1 ; set fan 1 name and value. Thermostatic control is turned off M950 F2 C"!out4" Q500 ; create fan 2 on pin !out4 and set its frequency M106 P2 C"pump" S1 H0 T25 ; set fan 2 name and value. Thermostatic control is turned on ; Tools M563 P0 S"slice head" D0 F0 T0 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C M563 P1 S"dyze head" D1 H2:3:4 F0 T1 ; define tool 1 G10 P1 X0 Y0 Z0 ; set tool 1 axis offsets G10 P1 R0 S0 ; Custom settings are not defined
@cj19944 this is the mircostepper drive ,the green light is on constantly which says it is not enabled
https://drive.google.com/file/d/1Oqd8jz7uU2o1Le19gp45uWQ7Z-tONXLA/edit
Here is the drive it is an r60 model.
@cj19944 the enable polarity varies between drivers. Try swapping the ENA+ and ENA- wires over; or alternatively, change R1 to R0 in the M569 command for that driver.
PS - you could drive the motor in that device directly from the 6HC. The documentation says it needs 2.7A RMS and the 6HC can do up to 4.5A RMS.
@cj19944 See @dc42's answer for enabling the driver.
This is incorrect; you have five variables for the T parameter, when it only takes four. See https://docs.duet3d.com/en/User_manual/Reference/Gcodes#m569-set-motor-driver-direction-enable-polarity-mode-and-step-pulse-timing
There is no information in the driver user manual about pulse speeds, and your current ones look very fast. Once it is enabled, try something a bit slower and more standard for external drivers, eg:
M569 P122.0 S1 R1 T5:5:10:10
Then reduce the timings to find the limit, if needed.Ian
Really appreciate your help I will try these changes and see what happens.
Hi this issue is solved now by changing r1 to r0 and adjusting the timing, thanks again for your help.
@droftarts the Pulsar manual gives this suggestion for the driver timings:
M569 PXXX SXXX R1 T3:3:5:0
