    SOLVED - Heater Temp not increasing after initial test.
    2.6k
    • Anvilundefined
      Anvil
      SOLVED! - either blew the heater itself or it was bad.
      (update at bottom) So I Installed a new hotend. A Phaetus Rapido on my ender 5 plus with a duet 2 wifi. I was told that by others that upgraded to one that they just plugged it in and it played very well after PID tuning. Well i tuned it on to 200c initially just to make sure it worked... and it did. I believe it overshot it and faulted out was the error i saw. So I went to run an autotune after i restarted and the heater wont increase temp. Did I blow a fuse on the board? How can i tell?
      My other concern (and i may be just being paranoid about having messed something up) is would there be anything wrong with copying and pasting a macro for another printers PID autotune macro that i liked? could that have altered and saved some sort of config-bak heater settings that arent playing nice after running the autotune and the temp not increasing?
      can i just delete everything in the config-bak file and see if it allows the heater to increase again?
      or is it likely a fuse?
      this is the macro i copied and pasted for anyone to look at to see if it could have been that.
      ; Macro file for Duet WiFi
      ; Generated by Modix - Version 3.4.1 Macro C
      M300 S666 P666 ; beep
      M291 S3 R"Attention!" P"During auto tuning there is minimal protection against heating faults. Therefore you should not leave the printer unattended"
      M570 H0 P120 T50 ; Extend the heater H1 fault timeout to 120 seconds for testing
      G4 S1 ; wait
      M303 H0 T0 P1 S240 F1.0 ; Start the PID tune at 240c, fan at 100%
      UPDATE;
      So Im getting super frustrated with this issue. Im pretty good with the duet ecosystem and have been able to iron out any issues ive had over the past few years without having to reach out to the forum... I search for previous issues and have always found my solution without needing to post... but im super stumped on this one....
      1. I dont see how it could be a wiring issue if i only changed the connector out and put the new hotend on. So i immediately figured it was a fuse or a configuration issue.
      2. Im leaning towards config issue over fuse because in my config.g if i go to the m307 difinitions and swap T0 and T1 (bed and nozzle) and activate the bed (now nozzle defined as bed just to test functionality at all) the nozzle temp starts climbing at the same rate as the bed would until of course the board dead times out and states that the bed temp (still measuring from the bed sensor) isnt rising... so the hotend thermistor is reading properly and the heater does in fact work... something just isnt telling it to heat.
      3. I have updated all firmware and web interface to most recent... i followed the duet documentation to the T and uptaded from 2.x to 3.0 via reprap configurator before updating to latest 3.3 version. (and this is where i seem to be having some issue i cant identify)
      4. as it states in the beginning of the post. I was able to get the heater to overheat and fault out for my initial functionality test... (which is where my fear of blown fuse first came from) but after clearing fault and initiating an autotune is where i started to have my issue..
      5. config-override saved m307 pid calibration seems to state that my pid tuning for H1 (nozzle) was performed at V0... while bed states V24.1 I have tried altering the value to read v24.1 and no change... and now i just booted up this morning and there is no nozzle heater listed on my paneldue, only reading the thermistor value.
      Ive tried commenting out m501 for bootup to see if i can just start fresh and not load m500 values and still no joy
      Ive found my old .json file and copied it as much as possible for the new firmware versions so it (as much as possible) matches my old config before firmware migration to 3.0
      There just has to be something odd going on with the reprap configuration helper... There just seems to be something not being written properly and somehow not creating the nozzle heater tool. Like.. im almost to the point of wondering if naming the tool "nozzle" somehow created some redundant naming definition that confused the configurator... I have no idea... but i really need to get this going again. Please help.
        jay_s_uk @Anvil
        @anvil the fuse for the heaters (on a 1.04 at least) is the same fuse for the motors so if that's gone you're stepper motors won't be able to move.
        Have you cleared the fault message before trying to heat?
        The typical failure method for a mosfet is to fail closed, which would result in the heater being always on.
        You can also check whether the LED near the hotend comes on when you command it.
        In terms of PID tuning, nothing wrong with using a macro from elsewhere, but the preferred method of tuning a hotend is to use the tool number rather than the heater number e.g. M303 T1 S200 as that will command the part cooling fans to be on during the second half of the tuning.
        Anvilundefined 1 Reply Last reply Reply Quote 0
        • Anvilundefined
          Anvil @jay_s_uk
          @jay_s_uk ok coo! should i change that in the macro file or is that a command i can send to the console?
            jay_s_uk @Anvil
            @anvil i would just send it from the console, thats how i do it
            Anvilundefined 1 Reply Last reply Reply Quote 1
            • Anvilundefined
              Anvil @jay_s_uk
              @jay_s_uk it says heater not defined...
                jay_s_uk @Anvil
                @anvil post your config and an output of M98 P"config.g"
                Anvilundefined 4 Replies Last reply Reply Quote 0
                • Anvilundefined
                  Anvil @jay_s_uk
                  @jay_s_uk
                  0:/sys/config.g
                  ; generated by RepRapFirmware Configuration Tool v2.0.3 on Fri Sep 13 2019 00:35:32 GMT+0100 (British Summer Time)
                  M550 P"Ender 5 Plus" ; set printer name
                  M552 S1 ; enable network
                  M586 P0 S1 ; enable HTTP
                  M586 P1 S1 ; enable FTP
                  M586 P2 S1 ; enable Telnet
                  M569 P3 S0 ; physical drive 3 goes backwards
                  M92 X80.56 Y80.48 Z801.62 E674.42 ; set steps per mm
                  M572 D0 S0.02 ; pressure advance
                  M207 S1.5 F7200 Z0.2 ; firmware retraction
                  M566 X900.00 Y900.00 Z12.00 E300.00 ; set maximum instantaneous speed changes (mm/min)
                  M203 X6000.00 Y6000.00 Z300.00 E1200.00 ; set maximum speeds (mm/min)
                  M201 X500.00 Y500.00 Z20.00 E10000 ; set accelerations (mm/s^2)
                  M906 X800 Y800 Z800 E1200 I10 ; set motor currents (mA) and motor idle factor in per cent
                  M84 S30 ; Set idle timeout
                  M208 X-5.5 Y0 Z-5.5 S1 ; set axis minima
                  M208 X350 Y350 Z400 S0 ; set axis maxima
                  M574 X1 Y1 S1 ; set active high endstops
                  M574 Z1 S2 ; set endstops controlled by probe
                  M307 H3 A-1 C-1 D-1 ; disable heater on PWM channel for BLTouch
                  M558 P9 H2.5 F180 T6000 ; set Z probe type to bltouch and the dive height + speeds
                  G31 P500 X42 Y11 Z2.546 ; set Z probe trigger value, offset and trigger height
                  M557 X0:305 Y0:315 S25 ; define mesh grid
                  M307 H0 B0 S1.00 ; disable bang-bang mode for the bed heater and set PWlimit
                  M305 P0 T100000 B4138 R4700 ; set thermistor + ADC parameters for heater 0
                  M305 P1 T100000 B4138 R4700 ; set thermistor + ADC parameters for heater 1
                  M106 P1 S0 I0 F500 H-1 C”Cooling Power” ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off. F500 to F0:1
                  M563 P0 D0 H1 F0:1 ; define tool 0
                  G10 P0 X0 Y0 Z0.18 ; set tool 0 axis offsets
                  ; Custom settings
                  M591 D0 P2 C3 S1 ; Filament Run out sensor
                  G29 S1 ; Load mesh bed
                  Ender 5 Plus
                  M303 T1 S200
                  Status
                  Idle
                  Tool Position
                  X
                  164.5
                  Y
                  0.0
                  Z
                  0.02
                  Extruder Drives
                  Drive 0
                  0.0
                  Speeds
                  Requested Speed
                  0 mm/s
                  Top Speed
                  0 mm/s
                  Sensors
                  Vin
                  24.1 V
                  MCU Temperature
                  32.2 C
                  Fan RPM
                  0
                  Z-Probe
                  0
                  Tools
                  Extra
                  Control All
                  Tool Heater Current Active Standby
                  Tool 0
                  T0 - Load Filament Heater 1
                  off 26.0 C
                  0
                  0
                  Bed Heater 0
                  off 25.6 C
                  0
                  0
                  Temperature Chart
                  System Directory
                  • Anvilundefined
                    Anvil @jay_s_uk
                    @jay_s_uk
                    M98 P"config.g"
                    HTTP is enabled on port 80
                    FTP is enabled on port 21
                    TELNET is enabled on port 23
                    • Anvilundefined
                      Anvil
                      I decided it was a good time to migrate to the latest firmware... i was pre 3.0 so im about done... ill post that here in a second to see if there are any glaring differences you can see
                      • Anvilundefined
                        Anvil @jay_s_uk
                        @jay_s_uk
                        updated firmware config
                        0:/sys/config.g
                        ; generated by RepRapFirmware Configuration Tool v3.3.13 on Fri Sep 16 2022 10:35:49 GMT-0400 (Eastern Daylight Time)
                        M550 P"Ender 5 Plus IWS" ; set printer name
                        M586 P1 S0 ; disable FTP
                        M586 P2 S0 ; disable Telnet
                        M92 X80.56 Y80.49 Z801.62 E674.42 ; set steps per mm
                        M201 X500.00 Y500.00 Z20.00 E10000.00 ; set accelerations (mm/s^2)
                        M574 X1 S1 P"xstop" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop
                        M574 Y1 S1 P"ystop" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ystop
                        M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
                        M556 S50 X0 Y0 Z0 ; set orthogonal axis compensation parameters
                        M557 X0:315 Y0:315 S25 ; define mesh grid
                        M563 P0 S"Nozzle" D0 H1 F0 ; define tool 0
                        Ender 5 Plus IWS
                        Send code...
                        Status
                        Idle
                        Mode: FFF
                        Tool Position
                        X
                        0.0
                        Y
                        0.0
                        Z
                        0.00
                        Extruder Drives
                        Drive 0
                        0.0
                        Speeds
                        Requested Speed
                        0 mm/s
                        Top Speed
                        0 mm/s
                        Sensors
                        Vin
                        24.1 V
                        MCU Temperature
                        32.4 C
                        Tools
                        Extra
                        Control All
                        Nozzle
                        off 26.2 C
                        0
                        0
                        Bed Heater 0
                        off 25.8 C
                        0
                        0
                        Temperature Chart
                        System Directory
                        • Anvilundefined
                          Anvil @jay_s_uk
                          @jay_s_uk
                          M98 P"config.g"
                          FTP is disabled
                          TELNET is disabled
                          Warning: M307: heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 365C.
                          hmm not sure what thats about
                          Rushmere3Dundefined 1 Reply Last reply Reply Quote 0
                          • Rushmere3Dundefined
                            Rushmere3D @Anvil
                            @anvil What command did you put in the console to PID the hotend? The one Jay gave was an example, you don't have a T1 so that wouldn't work.
                            Follow my adventures in 3D Printing, laser cutting and electronics. https://linktr.ee/Rushmere3D
                            • Anvilundefined
                              Anvil @Rushmere3D
                              @rushmere3d
                              i used T0 for the command after firmware update and it says "no heater tuned"
                              • Anvilundefined
                                Anvil
                                Hotend heater gets error of "temperature rising too slowly"
                                  jay_s_uk @Anvil
                                  @anvil ah yes, I mean T0 not T1. Where do you see that error about no heater tuned?
                                  When you send M303 do you see any rise out of the temperature at all?
                                  Anvilundefined 3 Replies Last reply Reply Quote 0
                                  • Anvilundefined
                                    Anvil @jay_s_uk
                                    @jay_s_uk both on the web interface and my paneldue
                                    but currently im dealing with a random "incompatible firmware version" that randomly popped up after working fine for a bed tune and trying to tune the nozzle...
                                    grrrrrrr
                                    • Anvilundefined
                                      Anvil @jay_s_uk
                                      @jay_s_uk
                                      ok got everything connected again and the right firmware all going...
                                      but yes the heater rises verrrrryyyyyy slooooowly...
                                      idle at same temp as be so i know the thermistors are correct... but ya it goes from 26.8 to like 27.4 before it says its not increasing fast enough
                                        jay_s_uk @Anvil
                                        @anvil sounds like you have a wiring issue. I'd start by using a multimeter to check the heater of the rapido
                                        • Anvilundefined
                                          Anvil @jay_s_uk
                                          @jay_s_uk
                                          does the rapido need to be double fed or something? specs say its a 115w heater... not sure why its not heating. its all wired correctly. I cant find any documentation on a wiring diagram for it.
                                            jay_s_uk @Anvil
                                            @anvil no, it doesn't need to be double fed. Are you using the right voltage version for your system?
                                            Have you checked it with a multimeter?
