    SOLVED - Heater Temp not increasing after initial test.
    2.8k
      jay_s_uk @Anvil
      @anvil post your config and an output of M98 P"config.g"
      Anvilundefined 4 Replies Last reply Reply Quote 0
      • Anvilundefined
        Anvil @jay_s_uk
        @jay_s_uk
        0:/sys/config.g
        ; generated by RepRapFirmware Configuration Tool v2.0.3 on Fri Sep 13 2019 00:35:32 GMT+0100 (British Summer Time)
        M550 P"Ender 5 Plus" ; set printer name
        M552 S1 ; enable network
        M586 P0 S1 ; enable HTTP
        M586 P1 S1 ; enable FTP
        M586 P2 S1 ; enable Telnet
        M569 P2 S0 ; physical drive 2 goes backwards
        M92 X80.56 Y80.48 Z801.62 E674.42 ; set steps per mm
        M572 D0 S0.02 ; pressure advance
        M207 S1.5 F7200 Z0.2 ; firmware retraction
        M566 X900.00 Y900.00 Z12.00 E300.00 ; set maximum instantaneous speed changes (mm/min)
        M203 X6000.00 Y6000.00 Z300.00 E1200.00 ; set maximum speeds (mm/min)
        M201 X500.00 Y500.00 Z20.00 E10000 ; set accelerations (mm/s^2)
        M906 X800 Y800 Z800 E1200 I10 ; set motor currents (mA) and motor idle factor in per cent
        M84 S30 ; Set idle timeout
        M208 X-5.5 Y0 Z-5.5 S1 ; set axis minima
        M208 X350 Y350 Z400 S0 ; set axis maxima
        M307 H3 A-1 C-1 D-1 ; disable heater on PWM channel for BLTouch
        M558 P9 H2.5 F180 T6000 ; set Z probe type to bltouch and the dive height + speeds
        G31 P500 X42 Y11 Z2.546 ; set Z probe trigger value, offset and trigger height
        M557 X0:305 Y0:315 S25 ; define mesh grid
        M307 H0 B0 S1.00 ; disable bang-bang mode for the bed heater and set PWlimit
        M106 P1 S0 I0 F500 H-1 C”Cooling Power” ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off. F500 to F0:1
        M563 P0 D0 H1 F0:1 ; define tool 0
        G10 P0 X0 Y0 Z0.18 ; set tool 0 axis offsets
        ; Custom settings
        M591 D0 P2 C3 S1 ; Filament Run out sensor
        G29 S1 ; Load mesh bed
        Ender 5 Plus
        M303 T1 S200
        Status
        Idle
        Tool Position
        X
        164.5
        Y
        0.0
        Z
        0.02
        Extruder Drives
        Drive 0
        0.0
        Speeds
        Requested Speed
        0 mm/s
        Top Speed
        0 mm/s
        Sensors
        Vin
        24.1 V
        MCU Temperature
        32.2 C
        Fan RPM
        0
        Z-Probe
        0
        Tools
        Extra
        Control All
        Tool Heater Current Active Standby
        Tool 0
        T0 - Load Filament Heater 1
        off 26.0 C
        0
        0
        Bed Heater 0
        off 25.6 C
        0
        0
        Temperature Chart
        System Directory
        • Anvilundefined
          Anvil @jay_s_uk
          @jay_s_uk
          M98 P"config.g"
          HTTP is enabled on port 80
          FTP is enabled on port 21
          TELNET is enabled on port 23
          • Anvilundefined
            Anvil
            I decided it was a good time to migrate to the latest firmware... i was pre 3.0 so im about done... ill post that here in a second to see if there are any glaring differences you can see
            • Anvilundefined
              Anvil @jay_s_uk
              @jay_s_uk
              updated firmware config
              0:/sys/config.g
              ; generated by RepRapFirmware Configuration Tool v3.3.13 on Fri Sep 16 2022 10:35:49 GMT-0400 (Eastern Daylight Time)
              M550 P"Ender 5 Plus IWS" ; set printer name
              M586 P1 S0 ; disable FTP
              M586 P2 S0 ; disable Telnet
              M92 X80.56 Y80.49 Z801.62 E674.42 ; set steps per mm
              M201 X500.00 Y500.00 Z20.00 E10000.00 ; set accelerations (mm/s^2)
              M574 X1 S1 P"xstop" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop
              M574 Y1 S1 P"ystop" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ystop
              M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
              M556 S50 X0 Y0 Z0 ; set orthogonal axis compensation parameters
              M557 X0:315 Y0:315 S25 ; define mesh grid
              M563 P0 S"Nozzle" D0 H1 F0 ; define tool 0
              Ender 5 Plus IWS
              Send code...
              Status
              Idle
              Mode: FFF
              Tool Position
              X
              0.0
              Y
              0.0
              Z
              0.00
              Extruder Drives
              Drive 0
              0.0
              Speeds
              Requested Speed
              0 mm/s
              Top Speed
              0 mm/s
              Sensors
              Vin
              24.1 V
              MCU Temperature
              32.4 C
              Tools
              Extra
              Control All
              Nozzle
              off 26.2 C
              0
              0
              Bed Heater 0
              off 25.8 C
              0
              0
              Temperature Chart
              System Directory
              • Anvilundefined
                Anvil @jay_s_uk
                @jay_s_uk
                M98 P"config.g"
                FTP is disabled
                TELNET is disabled
                Warning: M307: heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 365C.
                hmm not sure what thats about
                Rushmere3Dundefined 1 Reply Last reply Reply Quote 0
                • Rushmere3Dundefined
                  Rushmere3D @Anvil
                  @anvil What command did you put in the console to PID the hotend? The one Jay gave was an example, you don't have a T1 so that wouldn't work.
                  Follow my adventures in 3D Printing, laser cutting and electronics. https://linktr.ee/Rushmere3D
                  Anvilundefined 1 Reply Last reply Reply Quote 0
                  • Anvilundefined
                    Anvil @Rushmere3D
                    @rushmere3d
                    i used T0 for the command after firmware update and it says "no heater tuned"
                    • Anvilundefined
                      Anvil
                      Hotend heater gets error of "temperature rising too slowly"
                        jay_s_uk @Anvil
                        @anvil ah yes, I mean T0 not T1. Where do you see that error about no heater tuned?
                        When you send M303 do you see any rise out of the temperature at all?
                        Anvilundefined 3 Replies Last reply Reply Quote 0
                        • Anvilundefined
                          Anvil @jay_s_uk
                          @jay_s_uk both on the web interface and my paneldue
                          but currently im dealing with a random "incompatible firmware version" that randomly popped up after working fine for a bed tune and trying to tune the nozzle...
                          grrrrrrr
                          • Anvilundefined
                            Anvil @jay_s_uk
                            @jay_s_uk
                            ok got everything connected again and the right firmware all going...
                            but yes the heater rises verrrrryyyyyy slooooowly...
                            idle at same temp as be so i know the thermistors are correct... but ya it goes from 26.8 to like 27.4 before it says its not increasing fast enough
                              jay_s_uk @Anvil
                              @anvil sounds like you have a wiring issue. I'd start by using a multimeter to check the heater of the rapido
                              • Anvilundefined
                                Anvil @jay_s_uk
                                @jay_s_uk
                                does the rapido need to be double fed or something? specs say its a 115w heater... not sure why its not heating. its all wired correctly. I cant find any documentation on a wiring diagram for it.
                                  jay_s_uk @Anvil
                                  @anvil no, it doesn't need to be double fed. Are you using the right voltage version for your system?
                                  Have you checked it with a multimeter?
                                    Can you send M122 and post the results?
                                    • Anvilundefined
                                      Anvil @Phaedrux
                                      @phaedrux
                                      m122
                                      RepRapFirmware for Duet 2 WiFi/Ethernet version 3.4.2 (2022-09-13 15:11:16) running on Duet WiFi 1.02 or later
                                      Board ID: 08DJM-9178L-L2MSD-6JKFJ-3S86S-TBDQP
                                      Used output buffers: 1 of 26 (12 max)
                                      Static ram: 23860
                                      Dynamic ram: 75112 of which 0 recycled
                                      Never used RAM 13108, free system stack 184 words
                                      Tasks: NETWORK(ready,10.2%,237) HEAT(notifyWait,0.0%,333) Move(notifyWait,0.0%,363) MAIN(running,82.2%,440) IDLE(ready,7.5%,30), total 100.0%
                                      Owned mutexes: WiFi(NETWORK)
                                      Last reset 00:00:12 ago, cause: software
                                      Last software reset at 2022-09-16 15:21, reason: User, GCodes spinning, available RAM 13108, slot 1
                                      Error status: 0x00
                                      Aux0 errors 0,0,0
                                      Step timer max interval 0
                                      MCU temperature: min 37.3, current 38.1, max 38.2
                                      Supply voltage: min 24.0, current 24.1, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes
                                      Events: 0 queued, 0 completed
                                      Driver 0: standstill, SG min n/a
                                      Driver 1: standstill, SG min n/a
                                      Driver 2: standstill, SG min n/a
                                      Driver 3: standstill, SG min n/a
                                      Driver 4: standstill, SG min n/a
                                      Driver 5:
                                      Driver 6:
                                      Driver 7:
                                      Driver 8:
                                      Driver 9:
                                      Driver 10:
                                      Driver 11:
                                      Date/time: 2022-09-16 15:21:13
                                      Cache data hit count 458831398
                                      Slowest loop: 5.52ms; fastest: 0.18ms
                                      === Storage ===
                                      Free file entries: 10
                                      SD card longest read time 3.2ms, write time 0.0ms, max retries 0
                                      DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000
                                      === MainDDARing ===
                                      === AuxDDARing ===
                                      Segments left: 0
                                      Movement lock held by null
                                      HTTP is idle in state(s) 0
                                      Telnet is idle in state(s) 0
                                      File is idle in state(s) 0
                                      USB is idle in state(s) 0
                                      Aux is idle in state(s) 0
                                      Trigger is idle in state(s) 0
                                      Queue is idle in state(s) 0
                                      LCD is idle in state(s) 0
                                      Daemon is idle in state(s) 0
                                      Code queue is empty
                                      === Network ===
                                      Slowest loop: 16.01ms; fastest: 0.00ms
                                      HTTP sessions: 1 of 8
                                      = WiFi =
                                      Network state is active
                                      WiFi firmware version 1.23
                                      WiFi MAC address dc:4f:22:6e:6b:09
                                      WiFi Vcc 3.40, reset reason Turned on by main processor
                                      WiFi flash size 4194304, free heap 22944
                                      WiFi IP address 192.168.0.33
                                      WiFi signal strength -51dBm, mode none, reconnections 0, sleep mode modem
                                      Clock register ffffffff
                                        Your wifi server version is out of date for 3.4.2. How did you update the firmware?
                                        I suggest uploading the firmware zip file again to ensure everything is up to date.
                                        https://github.com/Duet3D/RepRapFirmware/releases/download/3.4.2/Duet2and3Firmware-3.4.2.zip
                                        Next try tuning the heater again and take a screen shot of the temp graph and capture the complete error message if you get one.
                                        M303 H0 S200
                                        Anvilundefined Phaedruxundefined 4 Replies Last reply Reply Quote 0
                                        • Anvilundefined
                                          Anvil
                                          So i just noticed something on my paneldue when it starts up.... doesnt show up in the web console for some reason... but it says T0 hasnt been set up and that the bed seems to be overpowered.
                                          I think my bed and nozzle are competing for the same tool definition in the config.. not sure how to fix it... i swapped the numbers and got the nozzle to start increasing temp normally but only by setting the bed temp and activating... can i fix this in my config or do i need to change something in my .json?
                                          • Anvilundefined
                                            Anvil @Phaedrux
                                            @phaedrux i think theres something up with the definition of my heaters... can you look it over and see if its odd with the bed and primary tool being the way they are?
