    SOLVED - Heater Temp not increasing after initial test.
    2.8k
    • Anvilundefined
      Anvil @jay_s_uk
      @jay_s_uk ok coo! should i change that in the macro file or is that a command i can send to the console?
        jay_s_uk @Anvil
        @anvil i would just send it from the console, thats how i do it
        Anvilundefined 1 Reply Last reply Reply Quote 1
        • Anvilundefined
          Anvil @jay_s_uk
          @jay_s_uk it says heater not defined...
            jay_s_uk @Anvil
            @anvil post your config and an output of M98 P"config.g"
            Anvilundefined 4 Replies Last reply Reply Quote 0
            • Anvilundefined
              Anvil @jay_s_uk
              @jay_s_uk
              0:/sys/config.g
              ; generated by RepRapFirmware Configuration Tool v2.0.3 on Fri Sep 13 2019 00:35:32 GMT+0100 (British Summer Time)
              M550 P"Ender 5 Plus" ; set printer name
              M552 S1 ; enable network
              M586 P0 S1 ; enable HTTP
              M586 P1 S1 ; enable FTP
              M586 P2 S1 ; enable Telnet
              M569 P2 S0 ; physical drive 2 goes backwards
              M92 X80.56 Y80.48 Z801.62 E674.42 ; set steps per mm
              M572 D0 S0.02 ; pressure advance
              M207 S1.5 F7200 Z0.2 ; firmware retraction
              M566 X900.00 Y900.00 Z12.00 E300.00 ; set maximum instantaneous speed changes (mm/min)
              M203 X6000.00 Y6000.00 Z300.00 E1200.00 ; set maximum speeds (mm/min)
              M201 X500.00 Y500.00 Z20.00 E10000 ; set accelerations (mm/s^2)
              M906 X800 Y800 Z800 E1200 I10 ; set motor currents (mA) and motor idle factor in per cent
              M84 S30 ; Set idle timeout
              M208 X-5.5 Y0 Z-5.5 S1 ; set axis minima
              M208 X350 Y350 Z400 S0 ; set axis maxima
              M307 H3 A-1 C-1 D-1 ; disable heater on PWM channel for BLTouch
              M558 P9 H2.5 F180 T6000 ; set Z probe type to bltouch and the dive height + speeds
              G31 P500 X42 Y11 Z2.546 ; set Z probe trigger value, offset and trigger height
              M557 X0:305 Y0:315 S25 ; define mesh grid
              M307 H0 B0 S1.00 ; disable bang-bang mode for the bed heater and set PWlimit
              M106 P1 S0 I0 F500 H-1 C”Cooling Power” ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off. F500 to F0:1
              M563 P0 D0 H1 F0:1 ; define tool 0
              G10 P0 X0 Y0 Z0.18 ; set tool 0 axis offsets
              ; Custom settings
              M591 D0 P2 C3 S1 ; Filament Run out sensor
              G29 S1 ; Load mesh bed
              Ender 5 Plus
              M303 T1 S200
              Status
              Idle
              Tool Position
              X
              164.5
              Y
              0.0
              Z
              0.02
              Extruder Drives
              Drive 0
              0.0
              Speeds
              Requested Speed
              0 mm/s
              Top Speed
              0 mm/s
              Sensors
              Vin
              24.1 V
              MCU Temperature
              32.2 C
              Fan RPM
              0
              Z-Probe
              0
              Tools
              Extra
              Control All
              Tool Heater Current Active Standby
              Tool 0
              T0 - Load Filament Heater 1
              off 26.0 C
              0
              0
              Bed Heater 0
              off 25.6 C
              0
              0
              Temperature Chart
              System Directory
              • Anvilundefined
                Anvil @jay_s_uk
                @jay_s_uk
                M98 P"config.g"
                HTTP is enabled on port 80
                FTP is enabled on port 21
                TELNET is enabled on port 23
                • Anvilundefined
                  Anvil
                  I decided it was a good time to migrate to the latest firmware... i was pre 3.0 so im about done... ill post that here in a second to see if there are any glaring differences you can see
                  • Anvilundefined
                    Anvil @jay_s_uk
                    @jay_s_uk
                    updated firmware config
                    0:/sys/config.g
                    ; generated by RepRapFirmware Configuration Tool v3.3.13 on Fri Sep 16 2022 10:35:49 GMT-0400 (Eastern Daylight Time)
                    M550 P"Ender 5 Plus IWS" ; set printer name
                    M586 P1 S0 ; disable FTP
                    M586 P2 S0 ; disable Telnet
                    M92 X80.56 Y80.49 Z801.62 E674.42 ; set steps per mm
                    M201 X500.00 Y500.00 Z20.00 E10000.00 ; set accelerations (mm/s^2)
                    M574 X1 S1 P"xstop" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop
                    M574 Y1 S1 P"ystop" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ystop
                    M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
                    M556 S50 X0 Y0 Z0 ; set orthogonal axis compensation parameters
                    M557 X0:315 Y0:315 S25 ; define mesh grid
                    M563 P0 S"Nozzle" D0 H1 F0 ; define tool 0
                    Ender 5 Plus IWS
                    Send code...
                    Status
                    Idle
                    Mode: FFF
                    Tool Position
                    X
                    0.0
                    Y
                    0.0
                    Z
                    0.00
                    Extruder Drives
                    Drive 0
                    0.0
                    Speeds
                    Requested Speed
                    0 mm/s
                    Top Speed
                    0 mm/s
                    Sensors
                    Vin
                    24.1 V
                    MCU Temperature
                    32.4 C
                    Tools
                    Extra
                    Control All
                    Nozzle
                    off 26.2 C
                    0
                    0
                    Bed Heater 0
                    off 25.8 C
                    0
                    0
                    Temperature Chart
                    System Directory
                    • Anvilundefined
                      Anvil @jay_s_uk
                      @jay_s_uk
                      M98 P"config.g"
                      FTP is disabled
                      TELNET is disabled
                      Warning: M307: heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 365C.
                      hmm not sure what thats about
                      Rushmere3Dundefined 1 Reply Last reply Reply Quote 0
                      • Rushmere3Dundefined
                        Rushmere3D @Anvil
                        @anvil What command did you put in the console to PID the hotend? The one Jay gave was an example, you don't have a T1 so that wouldn't work.
                        Follow my adventures in 3D Printing, laser cutting and electronics. https://linktr.ee/Rushmere3D
                        Anvilundefined 1 Reply Last reply Reply Quote 0
                        • Anvilundefined
                          Anvil @Rushmere3D
                          @rushmere3d
                          i used T0 for the command after firmware update and it says "no heater tuned"
                          • Anvilundefined
                            Anvil
                            Hotend heater gets error of "temperature rising too slowly"
                              jay_s_uk @Anvil
                              @anvil ah yes, I mean T0 not T1. Where do you see that error about no heater tuned?
                              When you send M303 do you see any rise out of the temperature at all?
                              Anvilundefined 3 Replies Last reply Reply Quote 0
                              • Anvilundefined
                                Anvil @jay_s_uk
                                @jay_s_uk both on the web interface and my paneldue
                                but currently im dealing with a random "incompatible firmware version" that randomly popped up after working fine for a bed tune and trying to tune the nozzle...
                                grrrrrrr
                                • Anvilundefined
                                  Anvil @jay_s_uk
                                  @jay_s_uk
                                  ok got everything connected again and the right firmware all going...
                                  but yes the heater rises verrrrryyyyyy slooooowly...
                                  idle at same temp as be so i know the thermistors are correct... but ya it goes from 26.8 to like 27.4 before it says its not increasing fast enough
                                    jay_s_uk @Anvil
                                    @anvil sounds like you have a wiring issue. I'd start by using a multimeter to check the heater of the rapido
                                    • Anvilundefined
                                      Anvil @jay_s_uk
                                      @jay_s_uk
                                      does the rapido need to be double fed or something? specs say its a 115w heater... not sure why its not heating. its all wired correctly. I cant find any documentation on a wiring diagram for it.
                                        jay_s_uk @Anvil
                                        @anvil no, it doesn't need to be double fed. Are you using the right voltage version for your system?
                                        Have you checked it with a multimeter?
                                          Can you send M122 and post the results?
                                          • Anvilundefined
                                            Anvil @Phaedrux
                                            @phaedrux
                                            m122
                                            RepRapFirmware for Duet 2 WiFi/Ethernet version 3.4.2 (2022-09-13 15:11:16) running on Duet WiFi 1.02 or later
                                            Board ID: 08DJM-9178L-L2MSD-6JKFJ-3S86S-TBDQP
                                            Used output buffers: 1 of 26 (12 max)
                                            Static ram: 23860
                                            Dynamic ram: 75112 of which 0 recycled
                                            Never used RAM 13108, free system stack 184 words
                                            Tasks: NETWORK(ready,10.2%,237) HEAT(notifyWait,0.0%,333) Move(notifyWait,0.0%,363) MAIN(running,82.2%,440) IDLE(ready,7.5%,30), total 100.0%
                                            Owned mutexes: WiFi(NETWORK)
                                            Last reset 00:00:12 ago, cause: software
                                            Last software reset at 2022-09-16 15:21, reason: User, GCodes spinning, available RAM 13108, slot 1
                                            Error status: 0x00
                                            Aux0 errors 0,0,0
                                            Step timer max interval 0
                                            MCU temperature: min 37.3, current 38.1, max 38.2
                                            Supply voltage: min 24.0, current 24.1, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes
                                            Events: 0 queued, 0 completed
                                            Driver 0: standstill, SG min n/a
                                            Driver 1: standstill, SG min n/a
                                            Driver 2: standstill, SG min n/a
                                            Driver 3: standstill, SG min n/a
                                            Driver 4: standstill, SG min n/a
                                            Driver 5:
                                            Driver 6:
                                            Driver 7:
                                            Driver 8:
                                            Driver 9:
                                            Driver 10:
                                            Driver 11:
                                            Date/time: 2022-09-16 15:21:13
                                            Cache data hit count 458831398
                                            Slowest loop: 5.52ms; fastest: 0.18ms
                                            === Storage ===
                                            Free file entries: 10
                                            SD card longest read time 3.2ms, write time 0.0ms, max retries 0
                                            DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000
                                            === MainDDARing ===
                                            === AuxDDARing ===
                                            Segments left: 0
                                            Movement lock held by null
                                            HTTP is idle in state(s) 0
                                            Telnet is idle in state(s) 0
                                            File is idle in state(s) 0
                                            USB is idle in state(s) 0
                                            Aux is idle in state(s) 0
                                            Trigger is idle in state(s) 0
                                            Queue is idle in state(s) 0
                                            LCD is idle in state(s) 0
                                            Daemon is idle in state(s) 0
                                            Code queue is empty
                                            === Network ===
                                            Slowest loop: 16.01ms; fastest: 0.00ms
                                            HTTP sessions: 1 of 8
                                            = WiFi =
                                            Network state is active
                                            WiFi firmware version 1.23
                                            WiFi MAC address dc:4f:22:6e:6b:09
                                            WiFi Vcc 3.40, reset reason Turned on by main processor
                                            WiFi flash size 4194304, free heap 22944
                                            WiFi IP address 192.168.0.33
                                            WiFi signal strength -51dBm, mode none, reconnections 0, sleep mode modem
                                            Clock register ffffffff
