    inductive Z-probe problem after firmware upgrade
    Firmware installation
    532
    • rubinkingmaundefined
      rubinkingma
      Hi all,
      Im finally upgrading the firmware of my printer (from 1.19)
      Firmware is there and working, web interface is better than ever but i cant get the Z-probe working again and im thinking im missing something basic here (it always is).
      What happens is that if i ask the machine to "home Z" itll go up 5 mm and thats it.
      In home Z It states that itll go up for 5 mm then down.
      I feel like its thinking it allready has a positive Z signal.
      Heres my old config:
      ;*** Wifi Networking
      M552 S1			; Enable WiFi
      M555 P2                             ; Set output to look like Marlin
      M575 P1 B57600 S1			; Comms parameters for PanelDue
      ; Machine configuration
      M569 P0 S1							; Drive 0 goes forwards (change to S0 to reverse it)
      M569 P1 S1							; Drive 1 goes forwards
      M569 P2 S0							; Drive 2 goes forwards
      M569 P3 S0							; Drive 3 goes forwards
      M569 P4 S1							; Drive 4 goes forwards
      ; If you use an endstop switch for Z homing, change Z0 to Z1 in the following line, and see also M558 command later in this file
      M574 X1 Y1 Z0 S0					; set endstop configuration (X and Y and endstops only, at low end, active high)
      M667 S1							; set CoreXY mode
      M350 X16 Y16 E16 I1    					; Set 16x microstepping with interpolation
      M92 X80 Y80 Z400					; Set axis steps/mm
      M92 E418.5:418.5						; Set extruder steps/mm
      M906 X800 Y800 Z800 E800            ; Set motor currents (mA)
      M201 X1200 Y1200 Z30 E1000            ; Accelerations (mm/s^2)
      M203 X15000 Y15000 Z600 E3600       ; Maximum speeds (mm/min)
      M566 X600 Y600 Z30 E20              ; Maximum jerk speeds mm/minute
      M208 X300 Y198 Z160					; set axis maxima (adjust to suit your machine)
      M208 X0 Y0 Z0 S1				; set axis minima (adjust to make X=0 and Y=0 the edges of the bed)
      G21                                 ; Work in millimetres
      G90                                 ; Send absolute coordinates...
      M83                                 ; ...but relative extruder moves
      ; Z probe
      M558 P5 X0 Y0 Z1                    ; Analog Z probe, also used for homing the Z axis
      G31 X 28 Y12 Z0.4 P500                      ; Set the probe height and threshold (put your own values here)
      ; The following M557 commands are not needed if you are using a bed.g file to perform bed compensation
      ;*** Adjust the XY coordinates in the following M557 commands to suit your build and the position of the Z probe
      M557 P0 X60 Y30                      ; Four...
      M557 P1 X60 Y165                    ; ...probe points...
      M557 P2 X222 Y165                   ; ...for bed...
      M557 P3 X222 Y30                     ; ...levelling
      ;M557 P4 X141 Y82.5                 ; 5th probe point for levelling
      ; Thermistors and heaters
      ;*** You can use S and B parameters to define the parameters of the thermistors you are using
      M305 P0 R4700 T100000 H0 L0					; Put your own H and/or L values here to set the bed thermistor ADC correction
      ;M305 P1 R4700 H0 L0					; Put your own H and/or L values here to set the first nozzle thermistor ADC correction
      M305 P1 R4700 T100000 B4725 C7.06e-8
      M307 H1 A314.3 C197.3 D3.5 B0
      M143 H1 S288
      M305 P2 R4700 H0 L0					; Put your own H and/or L values here to set the second nozzle thermistor ADC correction
      M301 H1 P30 I0.14 D90 T0.50 S1.0	; PID settings for extruder 0
      M301 H2 P10 I0.10 D100 T0.50 S1.0	; PID settings for extruder 1
      M570 S120							; Increase to allow extra heating time if needed
      ; Tool definition
      M563 P0 D0 H1                       ; Define tool 0
      G10 P0 S0 R0                        ; Set tool 0 operating and standby temperatures
      ;*** If you have a dual-nozzle build, un-comment the following 3 lines
      ;M563 P1 D1 H2                      ; Define tool 1
      ;G10 P1 S0 R0                       ; Set tool 1 operating and standby temperatures
      ;*** If you are using axis compensation, put the figures in the following command
      M556 S78 X0 Y0 Z0                   ; Axis compensation here
      T0									; select first hot end
      And this is the new config:
      M575 P1 S1 B57600                               ; enable support for PanelDue
      G90                                             ; send absolute coordinates...
      M550 P"Hypercube Master"                        ; set printer name
      M669 K1                                         ; select CoreXY mode
      M552 S1                                         ; enable network
      M586 P0 S1                                      ; enable HTTP
      M586 P1 S0                                      ; disable FTP
      M586 P2 S0                                      ; disable Telnet
      M569 P0 S1                                      ; physical drive 0 goes forwards
      M569 P1 S1                                      ; physical drive 1 goes forwards
      M569 P2 S0                                     ; physical drive 2 goes forwards
      M569 P3 S0                                      ; physical drive 3 goes forwards
      M584 X0 Y1 Z2 E3                                ; set drive mapping
      M350 X16 Y16 Z16 E16 I1                         ; configure microstepping with interpolation
      M92 X80.00 Y80.00 Z400.00 E418.50               ; set steps per mm
      M566 X900.00 Y900.00 Z60.00 E120.00             ; set maximum instantaneous speed changes (mm/min)
      M203 X900000.00 Y900000.00 Z36000.00 E216000.00 ; set maximum speeds (mm/min)
      M201 X1000.00 Y1000.00 Z30.00 E1000.00          ; set accelerations (mm/s^2)
      M906 X800 Y800 Z800 E800 I30                    ; set motor currents (mA) and motor idle factor in per cent
      M84 S30                                         ; Set idle timeout
      M208 X300 Y198 Z160 S0                          ; set axis maxima
      M574 X1 S1 P"!xstop"                             ; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop
      M574 Y1 S1 P"!ystop"                             ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ystop
      M558 P5 C"zprobe.in" H5 F120 T6000              ; set Z probe type to unmodulated and the dive height + speeds
      G31 P500 X28 Y12 Z0.4                           ; set Z probe trigger value, offset and trigger height
      M557 X15:215 Y15:195 S20                        ; define mesh grid
      ;M308 P1 B4725 C7.060000e-8
      M308 S0 P"bedtemp" Y"thermistor" T100000 B4138  ; configure sensor 0 as thermistor on pin bedtemp
      M950 H0 C"bedheat" T0                           ; create bed heater output on bedheat and map it to sensor 0
      M307 H0 B0 S1.00                                ; disable bang-bang mode for the bed heater and set PWM limit
      M140 H0                                         ; map heated bed to heater 0
      M143 H0 S120                                    ; set temperature limit for heater 0 to 120C
      M308 S1 P"e0temp" Y"thermistor" T100000 B4725   ; configure sensor 1 as thermistor on pin e0temp
      M950 H1 C"e0heat" T1                            ; create nozzle heater output on e0heat and map it to sensor 1
      M307 H1 B0 S1.00                                ; disable bang-bang mode for heater  and set PWM limit
      M143 H1 S280                                    ; set temperature limit for heater 1 to 280C
      M950 F0 C"fan0" Q500                            ; create fan 0 on pin fan0 and set its frequency
      M106 P0 S0 H-1                                  ; set fan 0 value. Thermostatic control is turned off
      M950 F1 C"fan1" Q500                            ; create fan 1 on pin fan1 and set its frequency
      M106 P1 S1 H1 T45                               ; set fan 1 value. Thermostatic control is turned on
      M563 P0 D0 H1 F0                                ; define tool 0
      G10 P0 X0 Y0 Z0                                 ; set tool 0 axis offsets
      G10 P0 R0 S0                                    ; set initial tool 0 active and standby temperatures to 0C
      M501                                            ; load saved parameters from non-volatile memory
      The probe is a inductive PNP normally open sensor.
      Chances are there are more things not fixed at this point.
      Thanks in advance!!
      Rubin, The Netherlands
      • Th0mpyundefined
        Th0mpy
        Does the z-probe show triggered in DWC? Also, what board are you running?
        If you are in fact inverted on the signal you can change this line:
        Add an "!" before the pin name so it reads like this:
        M558 P5 C"!zprobe.in" H5 F120 T6000
        Usually the team that scores the most points wins the game.
          rubinkingma
          It shows triggered when it should (gives a value of 1000 when approached with something metal).
          Also i kinda solved it, tho im not sure if this is a solution "as intended"
          Apparantly i forgot to tell the system to use the probe as a Z-stop.
          So heres the updated config:
          M574 Z1 S2
          M558 P5 C"^zprobe.in" H5 F120 T6000
          ;M558 P5 C"zprobe.in" H5 F120 T6000 ; set Z probe type to unmodulated and the dive height + speeds
          I added the M574 Z1 S2 line, then needed to slow the home script because of fast aproach
          Tell me if im doing this wrong 😄
          Next are the heaters, configuring my slicer again, start working with my materials apart from generated G-code.
          Enough to do
          Th0mpyundefined 2 Replies Last reply Reply Quote 0
          • Th0mpyundefined
            Th0mpy @rubinkingma
            @rubinkingma
            You shouldn't need the M574 Z1.... Let me look at my config, one moment.
            • Th0mpyundefined
              Th0mpy @rubinkingma
              @rubinkingma
              This should be all you need, this is mine:
              M558 P5 C"^io3.in" H5 F600 T6000 A10
              G31 P500 X0 Y25 Z3.6
              M557 X15:205 Y25:205 P4
              rubinkingmaundefined 1 Reply Last reply Reply Quote 0
                What do you have in your homing files?
                @rubinkingma said in inductive Z-probe problem after firmware upgrade:
                ; Z probe
                You should remove the old RRF2 commands.
                  rubinkingma @Th0mpy
                  @th0mpy
                  Weird, when i dont it complains about "cant enable endstop".
                  Th0mpyundefined 1 Reply Last reply Reply Quote 0
                  • Th0mpyundefined
                    Th0mpy @rubinkingma
                    @rubinkingma
                    Can you paste in your homeall.g and homez.g?
                    Sorry, what board are you using? Just to confirm the pins.
                      rubinkingma @Phaedrux
                      @phaedrux
                      Thank you for your reply, what part is RRF2 ?
                      I got to 3xx firmware today after running 1.19 since 2017
                      Used the configurator and while i could have dropped some old stuff in there looking for solutions i'm not at the point where i can see the difference between old and new config.
                        rubinkingma @Th0mpy
                        @th0mpy
                        homeall ( I have been dicking around with this for mesh compensation)
                        ; homeall.g
                        ; called to home all axes
                        ; generated by RepRapFirmware Configuration Tool v3.3.13 on Mon Sep 19 2022 15:01:08 GMT+0200 (Midden-Europese zomertijd)
                        ;G91 ; relative positioning
                        ;G1 H2 Z5 F6000 ; lift Z relative to current position
                        ;G1 H1 X-305 Y-203 F1800 ; move quickly to X or Y endstop and stop there (first pass)
                        ;G1 H1 X-305 ; home X axis
                        ;G1 H1 Y-203 ; home Y axis
                        ;G1 X5 Y5 F6000 ; go back a few mm
                        ;G1 H1 X-305 F360 ; move slowly to X axis endstop once more (second pass)
                        ;G1 H1 Y-203 ; then move slowly to Y axis endstop
                        ;G1 H1 Z-165 F360 ; move Z down stopping at the endstop
                        ;G90 ; absolute positioning
                        ;G92 Z0 ; set Z position to axis minimum (you may want to adjust this)
                        ;G1 Z5 F100 ; lift Z relative to current position
                        ; homeall.g
                        G1 H2 X5 Y5 F6000 ; go back a few mm
                        G1 H2 Z5 F6000
                        G1 X150 Y100 F6000
                        G30 ;probe bed
                        Home Z
                        ; homez.g
                        ; called to home the Z axis
                        G1 H2 Z5 F600 ; lift Z relative to current position
                        G1 H1 Z-165 F1000 ; move Z down until the endstop is triggered (first pass)
                        G1 Z5 F1000 ; go back a few mm
                        G1 H1 Z-100 F360 ; move slowly to Z axis endstop once more (second pass)
                          Ah, nevermind about the old config parts. I see now that it's two separate configs. I've edited your post to make it a bit clearer.
                          Can you send M122 and M98 P"config.g" in the console and copy and paste the results here?
                          rubinkingmaundefined Th0mpyundefined 2 Replies Last reply Reply Quote 0
                            @phaedrux
                            M122:
                            M122
                            RepRapFirmware for Duet 2 WiFi/Ethernet version 3.4.2 (2022-09-13 15:11:16) running on Duet WiFi 1.02 or later
                            Board ID: 08DAM-9K9K2-NGNSN-6J9D6-3S46T-TPSRK
                            Used output buffers: 1 of 26 (24 max)
                            Static ram: 23860
                            Dynamic ram: 74924 of which 40 recycled
                            Never used RAM 13184, free system stack 106 words
                            Tasks: NETWORK(ready,15.2%,237) HEAT(notifyWait,0.0%,333) Move(notifyWait,0.0%,292) MAIN(running,84.8%,442) IDLE(ready,0.0%,30), total 100.0%
                            Owned mutexes: WiFi(NETWORK)
                            Last reset 01:25:43 ago, cause: power up
                            Last software reset at 2022-09-19 20:21, reason: User, GCodes spinning, available RAM 13256, slot 0
                            Error status: 0x08
                            Aux0 errors 0,0,0
                            Step timer max interval 0
                            MCU temperature: min 40.0, current 40.5, max 43.3
                            Supply voltage: min 24.3, current 24.5, max 24.7, under voltage events: 0, over voltage events: 0, power good: yes
                            Events: 0 queued, 0 completed
                            Driver 0: standstill, SG min 31
                            Driver 1: standstill, SG min 38
                            Driver 2: standstill, SG min 13
                            Driver 3: standstill, SG min n/a
                            Driver 4: standstill, SG min n/a
                            Driver 5:
                            Driver 6:
                            Driver 7:
                            Driver 8:
                            Driver 9:
                            Driver 10:
                            Driver 11:
                            Date/time: 2022-09-19 21:49:25
                            Slowest loop: 8.64ms; fastest: 0.17ms
                            === Storage ===
                            Free file entries: 10
                            SD card longest read time 0.7ms, write time 24.2ms, max retries 0
                            DMs created 83, segments created 3, maxWait 1254428ms, bed compensation in use: mesh, comp offset 0.000
                            === MainDDARing ===
                            Scheduled moves 883, completed 883, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
                            === AuxDDARing ===
                            Segments left: 0
                            Movement lock held by null
                            HTTP is idle in state(s) 0
                            Telnet is idle in state(s) 0
                            File is idle in state(s) 0
                            USB is idle in state(s) 0
                            Aux is idle in state(s) 0
                            Trigger is idle in state(s) 0
                            Queue is idle in state(s) 0
                            LCD is idle in state(s) 0
                            Daemon is idle in state(s) 0
                            Code queue is empty
                            === Network ===
                            Slowest loop: 243.62ms; fastest: 0.07ms
                            HTTP sessions: 1 of 8
                            = WiFi =
                            Network state is active
                            WiFi firmware version 1.27
                            WiFi MAC address 5c:cf:7f:f7:de:92
                            WiFi Vcc 3.37, reset reason Turned on by main processor
                            WiFi flash size 4194304, free heap 25864
                            WiFi IP address 192.168.1.201
                            WiFi signal strength -77dBm, mode 802.11n, reconnections 0, sleep mode modem
                            Clock register 00002002
                            • Th0mpyundefined
                              Th0mpy @Phaedrux
                              @phaedrux
                              I see the issue.
                              In the homez.g file change this:
                              to this
                              G1 X150 Y150 F6000
                              G90
                              G30
                                Phaedrux Moderator @rubinkingma
                                Your homez.g file is still looking for an endstop. It needs to be changed to use G30 instead of a G1 H1 Z move in order to use the probe.
                                Your homeall.g is using both an endstop move AND a G30 to probe.
                                Here are the corrected files
                                ; homeall.g
                                G1 X150 Y100 F6000
                                G30 ;probe bed
                                ; homez.g
                                G1 X150 Y100 F6000
                                G30 ;probe bed
                                • Th0mpyundefined
                                  Th0mpy @Phaedrux
                                  @phaedrux
                                  Stop replying so fast 🙂
                                  But you're right, I missed the homeall.g error.
                                    rubinkingma
                                    Thanks to you both!
                                    So it works now, this or next week ill start printing again and see what else i can find to complain about.
                                    This used to be my "quick and dirty" machine, and after a few years almost the only machine i use.
                                    I never took the time to really make it print nicely because i had a E3D volcano on it with a 0.8 Nozzle.
                                    Now with all these cool changes i want to dial it in with a 0.6 nozzle and make it a really nice machine.
                                    Its a core XY "hypercube" remix with hiwin rails for the bed.
                                    It should be able to make very nice prints if i just spend some time with it
                                    Th0mpyundefined 1 Reply Last reply Reply Quote 1
                                    • Th0mpyundefined
                                      Th0mpy @rubinkingma
                                      @rubinkingma
                                      Excellent! Happy Printing!
