    How do I use the BL-Touch When homing Z-axis
    Using Duet Controllers
    370
    • TomasLundefined
      TomasL
      Well as it says in the title
      Tried to put M574 Z1 S2 , it did not work, it crached hard into the bed.
      Board: Duet 2 WiFi (2WiFi)
      Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.1 (2022-06-01)
      Duet WiFi Server Version: 1.26
      BL Touch config is:
      ;BL-Touch
      M307 H3 A-1 C-1 D-1
      M950 S0 C"exp.heater3"                                 ; create servo pin 0 for BLTouch
      M558 P9 C"^zprobe.in" H5 F120 T6000                    ; set Z probe type to bltouch and the dive height + speeds
      G31 P500 X64 Y0 Z2.46                                  ; set Z probe trigger value, offset and trigger height
        jay_s_uk @TomasL
        @tomasl use G30, not G1 H1 Z
        TomasLundefined 1 Reply Last reply Reply Quote 0
        • TomasLundefined
          TomasL @jay_s_uk
          @jay_s_uk
          Well, that whas what RRF put in the config.g
          So, How do I use the G30 code?
            jay_s_uk @TomasL
            @tomasl e.g.
            G1 X100 Y100
            G30
            obviously changing the move location to the centre of the bed, taking into account to offset of the probe as the firmware won't
            • TomasLundefined
              TomasL @jay_s_uk
              @jay_s_uk
              Ok, so I,ll put this in the config.g, presumably at the end.
              So it would read
              G1 X33,5 Y82,5 Z5
              G30
              If I do this via the console, Z stops att 2,43 (+5mm) I do assume that the X-axis is lifted 5 mm after the g30 command.
              jay_s_ukundefined 2 Replies Last reply Reply Quote 0
                jay_s_uk @TomasL
                @tomasl not in config, in your homing files
                  jay_s_uk @TomasL
                  @tomasl and if you want any further movements after the probe then you'll need to add those in
                  • TomasLundefined
                    TomasL @jay_s_uk
                    @jay_s_uk
                    Ok, I have put in homeall.g and homez.g
                    G1 X33,5 Y82,5 F6000
                    G30
                    However Z-level is the same as the trigger height, is that correct?
                      jay_s_uk @TomasL
                      @tomasl the height it'll set is the z offset that you've set in G31 in your config
                      • TomasLundefined
                        TomasL @jay_s_uk
                        @jay_s_uk Ok
                          For the record
                          https://docs.duet3d.com/en/User_manual/Connecting_hardware/Z_probe_testing
                          https://docs.duet3d.com/en/User_manual/Connecting_hardware/Z_probe_connecting#bltouch
                          • TomasLundefined
                            TomasL @Phaedrux
                            @phaedrux Yes, I know all that, however my question was not answer in those documents.
                            droftartsundefined 1 Reply Last reply Reply Quote 1
                              droftarts administrators @TomasL
                              @tomasl For example configurations, see https://docs.duet3d.com/User_manual/Machine_configuration/Configuration_cartesian#homing-z
