    Change names in Duet web control
    Duet Web Control
    • FJ3Dundefined
      FJ3D
      Hello.
      Is it possible to change the names of the Duet UI?
      That is, where for example Extrusion factor appears, Extruder 0 put another name to that...
      Norderundefined 1 Reply Last reply Reply Quote 0
      • Norderundefined
        Norder @FJ3D
        @fj3d
        You can give your HotEnd and the print bed a name.
        To do this, change or add the following command lines in config.g...
        M308 S0 P"bedtemp" Y"thermistor" T100000 B4138 A"Blackprint"
        M308 S1 P"E1_TEMP" Y"thermistor" T100000 B4138 A"Dyzend Pro"
        The bold would be the supplement or is the parameter for the naming.
        So do not accept the command line 1:1, just add the A parameter.
        DDA5X... 0.9° Stepper... Linearrails... Duet 2 Wifi... PT100 Board... Duet IR-Probe... Dyze Pro Kit up to 500°C.. etc
        Thingiverse
        FJ3Dundefined 1 Reply Last reply Reply Quote 1
        • FJ3Dundefined
          FJ3D @Norder
          @norder said in Change names in Duet web control:
          A"Blackprint"
          I was referring above all to being able to change the names of the UI itself, for example, what I mark in yellow:
          HebigTundefined 1 Reply Last reply Reply Quote 0
            droftarts administrators
            @fj3d you can change the fan names using C parameter of M106, see https://docs.duet3d.com/en/User_manual/Reference/Gcodes#m106-fan-on
            You can’t change the extrusion control labels; it just refers to the currently selected tool. You can change the values in most DWC controls, by right clicking on them.
            • HebigTundefined
              HebigT @FJ3D
              @fj3d You could use BtnCmd and create simple labels that cover unwanted/unchangeable text.
              https://plugins.duet3d.com/plugins/BtnCmd.html
              FJ3Dundefined 1 Reply Last reply Reply Quote 0
              • FJ3Dundefined
                FJ3D @HebigT
                @hebigt said in Change names in Duet web control:
                w
                With this I think it can help me!!!!
                Thanks a lot
