    Warning: the height map has a substantial Z offset
    863
    • printingforfunundefined
      printingforfun
      Since RRF 3.4 this is unsolved issue ⚠️
      I have searched for solutions here and elsewhere and tried everything that was suggested...the warning is still here and I didn't change anything in settings or on the printer!?IMG_0979.jpeg
      printingforfunundefined 1 Reply Last reply Reply Quote 0
        printingforfun @printingforfun
        @printingforfun
        ; homeall.g
        ; called to home all axes
        G91 ; Set axes (not extruders) to relative positioning mode.
        G1 H2 Z5 F6000 ; Lift Z relative to current position.
        G1 H1 X255 Y220 F6000 ; Move quickly to X or Y axis endstop and stop there.
        G1 H1 X255 F6000 ; Move quickly to X endstop and stop there.
        G1 H1 Y220 F6000 ; Move quickly to Y endstop and stop there.
        G1 H2 X-5 Y-5 F6000 ; Move away from X and Y endstops.
        G1 H1 X355 F360 ; Move slowly to X endstop once more.
        G1 H1 Y355 F360 ; Move slowly to Y endstop once more.
        G90 ; Set axes (not extruders) to absolute positioning mode.
        G1 X125 Y120 F6000 ; Move X and Y axes so the Z probe is at the center of the bed.
        M558 F600 A1 ; Set Z probe. Feed rate: 600 mm/min. Times to probe: 1.
        G30 ; Z probe quickly (1 of 2 passes).
        G30 ; Home Z by probing the bed slowly (2 of 2 passes).
        G29 S1
          @printingforfun
          ; homez.g
          ; called to home the Z axis
          ; generated by RepRapFirmware Configuration Tool v3.3.5 on Thu Oct 28 2021 15:34:12 GMT+0200 (Central European Summer Time)
          G91 ; relative positioning
          G90 ; absolute positioning
          G1 X125 Y120 F6000 ; go to first probe point
          G29 S1
          ;G91 ; relative positioning
          ;G1 Z5 F100 ; lift Z relative to current position
          ;G90 ; absolute positioning
            @printingforfun
            ; bed.g
            G29 S0 ; Probe the bed, save height map to heightmap.csv and enable compensation
              @printingforfun
              M550 P"VORON" ; set printer name
              M669 K2 X1:0:1 Y0:1:0 Z1:0:-1 ; select CoreXZ mode
              M552 S1 ; enable network
              M586 P0 S1 ; enable HTTP
              M586 P1 S0 ; disable FTP
              M586 P2 S0 ; disable Telnet
              M92 X80.00 Y80.00 Z80.00 E427.45 ; set steps per mm
              M566 X600.00 Y600.00 Z600.00 E300.00 ; set maximum instantaneous speed changes (mm/min)
              M203 X30000.00 Y30000.00 Z30000.00 E3600.00 ; set maximum speeds (mm/min)
              M201 X3000.00 Y3000.00 Z3000.00 E7000.00 ; set accelerations (mm/s^2)
              M204 P1500 T3000
              M906 X1500 Y1500 Z1500 E700 I30 ; set motor currents (mA) and motor idle factor in per cent
              M84 S30 ; Set idle timeout
              M208 X0 Y-30 Z-4.0 S1 ; set axis minima
              M208 X250 Y210 Z230 S0 ; set axis maxima
              M574 X2 S1 P"^xstop" ; configure switch-type (e.g. microswitch) endstop for high end on X via pin ^xstop
              M574 Y2 S1 P"^ystop" ; configure switch-type (e.g. microswitch) endstop for high end on Y via pin ^ystop
              ;M574 Z1 S2 P5 ; configure Z-probe endstop for low end on Z
              ; Z-Probe[OMRON]
              M558 P5 C"zprobe.in" H9 F400 T6000 ; set Z probe type to unmodulated and the dive height + speeds
              G31 P500 X0 Y25 Z3.16 ; set Z probe trigger value, offset and trigger height
              M557 X25:270 Y10:210 S100 ; define mesh grid
              ;M308 S10 Y"mcu-temp" A"MCU"
              ;M308 S11 Y"drivers" A"Duet stepper drivers"
              M308 S3 A"Chamber" P"e1_temp" Y"thermistor" T100000 B4138
              M950 F2 C"fan2" Q500
              ;M106 P2 T45:65 H10:11
              M106 P2 S1 H3 T40
              M593 P"zvddd" F30.0 ; use ZVDDD input shaping to cancel ringing at 30.0Hz
              M955 P0 C"spi.cs3+spi.cs4"
              G92 S1
              M572 D0 S0.025 ; Pressure advance
              M501 ; load saved parameters from non-volatile memory;
                Remove the G29 S1 from your homing files. Move it to your slicer start gcode after homing has happened.
                @printingforfun said in Warning: the height map has a substantial Z offset:
                G92 S1
                It looks like you're also trying to load the heightmap at startup, but the command is wrong. You don't want to load it at startup because you haven't even homed the printer yet.
                The warning is telling you about what you are seeing in your heightmap display. There is a major difference between where your homed height is, and where the Z0 plane is found when creating the heightmap.
                What kind of probe are you using? How is it used? Is there a trigger height difference between when it is homing and when it is creating the heightmap with G29?
                What is the order of operations you are using to create the heightmap?
                Can you post your config-override.g file as well?
                  printingforfun @Phaedrux
                  proximity probe Omron 5mm, I have tried with all G29 S1 disabled in homingall, homingZ, config.g, config.g.bak including G92 S1, deleted everything in height map.csv folder, send G29 S2 before homing all, cancel active mesh compensation, disable axis limits, set Z=datum, set Z probe trigger height then run G29 and G29 S1 after probing....same results
                  printingforfunundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
                    ; config-override.g file generated in response to M500 at 2022-09-27 15:48
                    ; Heater model parameters
                    M307 H0 R0.307 K0.261:0.000 D8.03 E1.35 S1.00 B0
                    M307 H1 R3.019 K0.416:0.000 D5.63 E1.35 S1.00 B0 V24.2
                    ; Workplace coordinates
                    G10 L2 P1 X0.00 Y0.00 Z0.00
                    G10 L2 P2 X0.00 Y0.00 Z0.00
                    G10 L2 P3 X0.00 Y0.00 Z0.00
                    G10 L2 P4 X0.00 Y0.00 Z0.00
                    G10 L2 P5 X0.00 Y0.00 Z0.00
                    G10 L2 P6 X0.00 Y0.00 Z0.00
                    G10 L2 P7 X0.00 Y0.00 Z0.00
                    G10 L2 P8 X0.00 Y0.00 Z0.00
                    G10 L2 P9 X0.00 Y0.00 Z0.00
                    Norderundefined 1 Reply Last reply Reply Quote 0
                    • Norderundefined
                      Norder @printingforfun
                      @printingforfun
                      You probably did it with a dirty nozzle when determining the Z offset (trigger height) of your probe!?
                      I would measure the Z offset again, but make sure that no filament residue is stuck to the nozzle tip.
                      The following parameter is meant...
                      Google Translate
                      -- Original Text --
                      Vermutlich hast Du beim ermitteln des Z-Offset (Auslösehöhe) Deiner Sonde mit einer schmutzigen Düse gemacht !?
                      Ich würde den Z-Offset noch einmal ausmessen, aber achte darauf das keine Filamentreste an der Düsenspitze haften.
                      Folgender Parameter ist gemeint...
                      DDA5X... 0.9° Stepper... Linearrails... Duet 2 Wifi... PT100 Board... Duet IR-Probe... Dyze Pro Kit up to 500°C.. etc
                      Thingiverse
                      printingforfunundefined 3 Replies Last reply Reply Quote 0
                        printingforfun @Norder
                        @norder 10 years printing and building machines.... It's a mosquito hotend, for that price you bet it's clean!
                          @norder Z offset was (before RRF3.4)usually around 0.45
                          printingforfunundefined Norderundefined 2 Replies Last reply Reply Quote 0
                            @printingforfun people here already addressed this problem...and what I have found it's not resolved, I am just bringing the question again if somebody found solution
                              I have a Duet3D DC42 IR sensor / Probe somewhere laying around, will try with a different probe to see the difference and report the results
                                @norder this is before RRF3.4
                                • Norderundefined
                                  I don't understand what the price or the model has to do with clean.
                                  Maybe you misunderstood me or I misunderstood you because the translation from Google is sometimes a bit cryptic.
                                  By clean I mean the nozzle tip.
                                  If residues of the filament are still stuck to the tip of the nozzle and you use it to determine the Z offset, i.e. the trigger height of the probe, the result of the height map is exactly the same as you showed in the first post.
                                  So clean the nozzle... home the printer (all axes)... heat the print bed to the average temperature used (e.g. 60°C)... place the nozzle over a bed level screw (if possible). Use the Machine Movement of the DWC for this.
                                  Raise the nozzle to Z0.05mm when using a 0.05mm sheet of feeler gauge to measure, which is the most accurate method.
                                  Raise or lower the print bed with the leveling screws so that the sheet of the feeler gauge is just slightly clamped.
                                  Now place the probe exactly over this point where the nozzle was before.
                                  Measure this point 10 times in a row with the G30 S-1.
                                  Then add the 10 measurement results from the console and divide by 10.
                                  Now you have the exact Z offset of your probe.
                                  This is my procedure to determine the Z offset.
                                  Google Translate
                                  -- Original Text --
                                  Ich verstehe jetzt nicht was der Preis oder das Modell mit sauber zutun hat.
                                  Vielleicht hast Du mich oder ich Dich auch falsch verstanden denn die Übersetzung von Google ist manches mal etwas kryptisch.
                                  Mit sauber meinte ich die Düsenspitze.
                                  Wenn noch Reste vom Filament an der Düsenspitze haften und man damit den Z-Offset also die Auslösehöhe der Sonde ermittelt, dann kommt genau so ein Resultat der heohtmap heraus wie Du es im ersten Post gezeigt hast.
                                  Also Düse reinigen... Drucker homen (alle Achsen)... Druckbett auf die durchschnittlich genutze Temperatur (zB 60°C) erhitzen... Düse über einer Bettlevelschraube platzieren (wenn möglich). Dazu die Mashine Movement des DWC nutzen.
                                  Düse auf Z0.05mm anheben wenn ein 0.05mm Blatt einer Fühllehre zum messen genutzt wird, was die genaueste Methode ist.
                                  Das Druckbett mit den Levelschrauben so anheben bzw absenken dass das Blatt der Fühllehre gerade etwas eingeklemmt wird.
                                  Jetzt die Sonde genau über diesen Punkt platzieren wo vorher die Düse war.
                                  Mit G30 S-1 diesen Punkt 10x hintereinander messen.
                                  Dann die 10 Messergebnisse aus der Konsole addieren und durch 10 teilen.
                                  Jetzt hast Du den exakten Z-Offset Deiner Sonde.
                                  Das ist meine Vorgehensweise um den Z-Offset zu ermitteln.
                                  Thingiverse
                                  • Norderundefined
                                    No matter which RRF version you have installed, the offset value of your probe always remains the same.
                                    This distance is purely mechanical and is not changed by the software.
                                    If the Z-Offset value of the probe has changed in the config.g when updating the firmware, replace the value in the config.g with the previously measured value or determine the value again by working through the steps I wrote in the previous post wrote down.
                                    If you add an IR probe, then that probe will have its own z-offset which is not the same as the probe you are using now.
                                    I have installed two probes, one the IR probe and one for special print surfaces where the IR probe has problems, such as glass, for which I have the BLTouch.
                                    Each probe has its own Z offset.
                                    Here as proof my sample section from the config.g...
                                    ; Z-Probe (IR-Probe & BLTouch) 1.765mm Differenz
                                    ; IR-Probe
                                    M558 K0 C"zprobe.in" P3 H1.7 F120 T10000 B1 A10 S0.010 R0.4   		; disable Z probe but set dive height, probe speed and travel speed
                                    G31 K0 P500 X0.6 Y22.3 Z3.162               		   				; set Z probe trigger value, offset and trigger height
                                    ; BLTouch
                                    M950 K1 S0 C"exp.heater7"
                                    M558 K1 C"e1stop" P9 H3 F120 T10000 B1 A10 S0.010 R0.4				; disable Z probe but set dive height, probe speed and travel speed
                                    G31 K1 P500 X-30.0 Y11.0 Z1.397										; set Z probe trigger value, offset and trigger height
                                    ; Grid
                                    M557 X30:300 Y30:300 P9												; Mesh-Grid
                                    Google Translate
                                    -- Original Text --
                                    Egal welche RRF Version Du installiert hast, der Offset Wert Deiner Sonde bleibt immer gleich.
                                    Dieser Abstand ist rein mechanisch und wird durch die Software nicht verändert.
                                    Wenn sich der Wert des Z-Offset der Sonde in der config.g beim update der Firmware geändert haben, ersetzte den Wert in der config.g durch den vorher gemessenen Wert oder ermittle den Wert erneut indem Du die Schritte abarbeitest die ich im vorherigen Post aufgeschrieben habe.
                                    Wenn Du eine IR-Probe einbaust, dann hat diese Sonde ihren eigenen Z-Offset der nicht der gleiche ist wie von der Sonde die Du jetzt nutzt.
                                    Ich habe bei mir zwei Sonden eingebaut, einmal den IR-Probe und für spezielle Druckoberflächen wo der IR-Probe peobleme mit hat, wie zB Glas, dafür habe ich den BLTouch.
                                    Jede Sonde hat ihren eigenen Z-Offset.
                                    Hier zu Beweis meine Probe Sektion aus der config.g... (Code siehe oben)
                                    Thingiverse
                                    printingforfunundefined 2 Replies Last reply Reply Quote 0
                                      @norder sorry if I offended you,
                                      Vanadium Nozzle 0,40 -35.80€
                                      Mosquito Thermistor -29.00€
                                      Mosquito 24V 50W Heater -22.50€
                                      Mosquito 24V Fan -7.90€
                                      Mosquito Boron Nitride Paste -10.22€
                                      Mosquito Hotend -153.41€
                                      Shipping -20€
                                      Total:278.83€
                                      When you put that in the contents of the hot end model and price, you are probably take a good care of it....
                                        @norder with IR probe just want to rule out the possibility of a faulty Omron probe, the problem is that the mesh bed is up, didn't change anything on the printer or the settings except the z offset because probing the bed,now shows bed is up significantly, as the Warning and title of the post is saying, and yes, I make at least 10 trigger height and make a average of the results(with a clean nozzle and without filament in the hotend, with a printing temperature for bed and hotend, have macros for PID tuning, depending on what material is used, mostly PETG-222,80 / ABS,ABS+,ASA -240,100)
                                          @norder thanks, anyway!
                                          • Norderundefined
                                            No, you didn't insult me.
                                            I know what it's like to have such an expensive hotend.
                                            Look in my signature, there's a link to my print head, it's almost twice as expensive.
                                            Nevertheless, one can be careless and forget to wipe the nozzle tip before determining the Z offset.
                                            If you had a different z-offset value before the firmware update and everything was OK and you now have a different z-offset value in the config.g and the mesh of the heightmap is still hovering over the print bed, then the problem is already there solved.
                                            Enter the old value again or measure the Z offset again.
                                            Or did I misunderstand something here from the Google translation?
                                            You followed @Phaedrux tip, and if that didn't solve the problem... Z offset value !
                                            Google Translate
                                            -- Original Text --
                                            Nein, Du hast mich nicht beleidigt.
                                            Ich weiß wie es ist so ein teures Hotend zu haben.
                                            Gucke in meiner Signatur, dort ist mein Druckkopf verlinkt, der ist fast doppelt so teuer.
                                            Trotzdem kann man unvorsichtig sein und vergessen vor dem ermitteln des Z-Offset die Düsenspitze vorher abzuwischen.
                                            Wenn Du vor dem Firmware Update einen anderen Z-Offset Wert hattest und alles OK war und Du jetzt einen anderen Z-Offset Wert in der config.g stehen hast und das mesh der heightmap schwebt weiter über dem Druckbett, dann ist das Problem ja schon gelöst.
                                            Alten Wert wieder eintragen oder Z-Offset neu vermessen.
                                            Oder habe ich hier durch die Google Übersetzung etwas falsch verstanden ?
                                            Den Tipp von @Phaedrux hast Du ja befolgt, und wenn das Problem dadurch nicht behoben werden konnte... Z-Offset Wert !
                                            Thingiverse
