    having trouble with home Y
    263
    • ezemaffundefined
      ezemaff
      hi.. having trouble with Y axis.
      DUET 2 WIFI
      in my config.g i have this
      M569 P0 S1
      M569 P1 S1
      When i do HOME X
      X => GOES TO THE LEFT in negative value (x=0)
      When i do HOME Y
      Y => GOES TO THE FRONT in positive value (y=300)
      .. So..
      When i print something
      i have it fine on the slicer, but on the print i have like a mirror Captura de pantalla_20221017_200031.png
      For example, The cali dragon i have it fine on the slicer (face looking to the front and purge at the left\front)
      when i finish printing it the face are lookig the back and the purge is in the left\back.
      Thanks.
      alankilianundefined 1 Reply Last reply Reply Quote 0
      • alankilianundefined
        alankilian @ezemaff
        @ezemaff If you go to Section 9 of THIS PAGE it tells you how to reverse a motor.
        You should also check Sections 7 and 8 if your Y-axis endstop configuration needs updating after you reverse the motor.
        ezemaffundefined 1 Reply Last reply Reply Quote 0
        • ezemaffundefined
          ezemaff @alankilian
          @alankilian Where can i find that ?
          Thanks Alan.
            alankilian @ezemaff
            @ezemaff Click on the "THIS PAGE" link words.
            • ezemaffundefined
              ezemaff
              @alankilian I do the section 9.. and the movement its ok.
              G1 H2 Y10 goes backward to the back
              G1 H2 Y-10 goes foward to the front
              But, when i push on the dashboard HOME Y - Y+10 > its come forward to the front.
              Any idea ?
                alankilian @ezemaff
                @ezemaff Post your homex.g and homey.g file.
                How did you generate the configuration for your machine?
                ezemaffundefined 2 Replies Last reply Reply Quote 0
                • ezemaffundefined
                  ezemaff @alankilian
                  ; homex.g
                  ; called to home the X axis
                  ; generated by RepRapFirmware Configuration Tool v3.1.3 on Sat Jul 04 2020 19:19:39 GMT-0300 (Argentina Standard Time)
                  G91 ; relative positioning
                  G1 H1 X-348 F1800 ; move quickly to X axis endstop and stop there (first pass)
                  G1 X5 F6000 ; go back a few mm
                  G1 H1 X-348 F1800 ; move slowly to X axis endstop once more (second pass)
                  G1 H2 Z-5 F6000 ; lower Z again
                  G90 ; absolute positioning
                  ; homey.g
                  ; called to home the Y axis
                  G1 H1 Y326 F1800 ; move quickly to Y axis endstop and stop there (first pass)
                  G1 Y-5 F6000 ; go back a few mm
                  G1 H1 Y326 F360 ; move slowly to Y axis endstop once more (second pass)
                  ; homeall.g
                  ; called to home all axes
                  G1 H1 X-348 Y326 F1800 ; move quickly to X or Y endstop and stop there (first pass)
                  G1 H1 X-348 ; home X axis
                  G1 H1 Y326 ; home Y axis
                  G1 X5 Y-5 F6000 ; go back a few mm
                  G1 H1 X-348 F360 ; move slowly to X axis endstop once more (second pass)
                  G1 H1 Y326 ; then move slowly to Y axis endstop
                  G1 X150 Y150 F6000 ; Probe Z on the center of the bed
                  G29 S1
                  ;G91 ; relative positioning
                  ;G1 Z5 F100 ; lift Z relative to current position
                  ;G90 ; absolute positioning
                  I add my config.g file _config.g
                  • ezemaffundefined
                    ezemaff @alankilian
                    @alankilian i did it on 2020 with an old firmware..2.something.
                    and i upgrade to 3.
                      alankilian @ezemaff
                      @ezemaff OK, see where in homex.g you move towards -348 to "go home" and then in homey.g you move to +326 to "go home"?
                      That's why it's moving the wrong direction when homing.
                      Change the signs of the Y movements.
                      Something like this:
                      G1 H1 Y-326 F1800 ; move quickly to Y axis endstop and stop there (first pass)
                      G1 Y5 F6000 ; go back a few mm
                      G1 H1 Y-326 F360 ; move slowly to Y axis endstop once more (second pass)
                      ezemaffundefined 1 Reply Last reply Reply Quote 1
                      • ezemaffundefined
                        ezemaff @alankilian
                        @alankilian
                        I changed two elements to make it right. and then I did what you say to finish that part of the printer.
                        change
                        M574 Y VALUE
                        and i moved the cable from X to motor Y
                        thanks for the help.
