    can't find my "watched" topics anymore
    • o_lampeundefined
      o_lampe
      With today, I see a new forum layout which makes it harder to find back read threads.
      I can't even find my watched threads?
      FWIW, I'm running Win7 on the latest Firefox browser
      • o_lampeundefined
        o_lampe @o_lampe
        @o_lampe
        ...I have to click "recent" to see the forum layout I was used to. And guess what: i can now select "watched" threads. PHEW....
        • o_lampeundefined o_lampe marked this topic as a question
        • o_lampeundefined o_lampe has marked this topic as solved
        • Norderundefined
          Norder
          @o_lampe
          I also had to look for where the site remained that I have known for over 3 years.
          I also took the opportunity to change the skin from Standard to Darkly.
          If everything is new, then also correct. 😄
          I'm curious what else has changed.
          Is there a "What's new" list?
          DDA5X... 0.9° Stepper... Linearrails... Duet 2 Wifi... PT100 Board... Duet IR-Probe... Dyze Pro Kit up to 500°C.. etc
          Thingiverse
            droftarts administrators @Norder
            @Norder not sure what is new, but there have been improvements, eg text selecting in iOS works for me now.
            I initially had the same issue of seeing the categories rather than recent when opening the forum, but you can chiose what you see in your profile > settings > select a homepage. For some reason mine was set to custom.
            The other thing that has changed for me (in iOS) is viewing notifications. These were shown at the bottom of my profile, but now there is a button (bell icon) at the top to show them.
            Norderundefined 1 Reply Last reply Reply Quote 1
            • Norderundefined
              Norder @droftarts
              @droftarts said in can't find my "watched" topics anymore:
              I found that after about 5 minutes of "troubleshooting" 😄 and switched it to "Recent".
              You can also switch it to German, which I tried, but then immediately changed again.
              The forum software then displays everything in German, but of course the comments remain in English.
              The problem is... My translation plug-in no longer asks me if it should translate the page into German, because it's in German. 😬
              And since I can't get the icon to translate the page, I had to switch it back to English.
              But it's OK like that. The few things that are then displayed in German will not get you any further.
              Google Translate
              -- Original Text --
              Das habe ich dann nach etwa 5 Minuten "Fehlersuche" 😄 auch gefunden und es auf "Recent" umgestellt.
              Man kann es auch auf Deutsch umstellen, was ich ausprobiert habe, aber dann gleich wieder geändert habe.
              Die Forensoftware zeigt dann alles auf Deutsch an, aber die Kommentare bleiben natürlich auf Englisch.
              Problem ist dabei... Mein Übersetzungs PlugIn fragt mich nicht mehr ob er die Seite auf Deutsch übersetzen soll, weil sie ja auf Deutsch ist. 😬
              Und da ich so nicht an das Icon komme um die Seite übersetzen zu lassen, habe ich es wieder auf Englisch umgestellen müssen.
              Es ist aber OK so. Die paar Dinge die dann auf Deutsch angezeigt werden, bringen einen nicht weiter.
              Thingiverse
