    2 Thermistors for Chamber Temperature (Non Active Heated)
    • RogerPodacterundefined
      RogerPodacter
      I cannot seem to get 2 temperature readings displayed in my DWC. i want to passively read lower chamber temp and upper chamber temp, but I cannot visually see them in the web interface. am i setting these incorrectly?
      config.g
      G90                                     ; send absolute coordinates...
      M83                                     ; ...but relative extruder moves
      M550 P"V-Core3"                         ; set printer name
      M669 K1                                 ; CoreXY
      G21                                     ; Set Units to Millimeters
      M552 S2                                 ; enable network
      M586 P0 S1                              ; enable HTTP
      M586 P1 S0                              ; disable FTP
      M586 P2 S0                              ; disable Telnet
      G4 S2 ; wait for expansion boards to start
      M569 P0.0 S0 D2	                        ; Left Z physical drive 0.0 goes forwards
      M569 P0.1 S0 D2                         ; Rear Z physical drive 0.1 goes forwards
      M569 P0.2 S0 D2                            ; Right Z physical drive 0.2 goes forwards
      M569 P0.3 S1 D2                            ; Right physical drive 0.3 goes forwards
      M569 P0.4 S1 D2                            ; Left physical drive 0.4 goes forwards
      M569 P121.0 S1 D2                            ; Extruder physical drive 0.5 goes forwards
      M584 X0.4 Y0.3 Z0.0:0.1:0.2 E121.0        ; set drive mapping
      M350 X16 Y16 Z16 E16 I1                 ; configure microstepping with interpolation
      M92 X80.00 Y80.00 Z800.00 E690 ;E400               ; set steps per mm
      M906 X2000 Y2000 Z1800 E1000 I10 ;E700 I30              ; set motor currents (mA) and motor idle factor in per cent -- safe for Duet 3 mini 5+
      M84 S30                                 ; Set idle timeout
      M566 X1500.00 Y1500.00 Z60.00 E300 P1 ;Z6.00 E300 P1 ;E120.00 P1          ; set maximum instantaneous speed changes (mm/min)
      M203 X30000.00 Y30000.00 Z1000.00 E7200 ;E3600.00     ; set maximum speeds (mm/min)
      M201 X10000.00 Y10000.00 Z100.00 E10000 ;E3600.00        ; set accelerations (mm/s^2)
      M207 S0.6 F7200 Z0.2						; firmware retraction orbiter 2.0
      M208 X0 Y0 Z0 S1                               ; set axis minima
      M208 X310 Y310 Z300 S0                         ; set axis maxima
      M574 X1 S1 P"121.io2.in"                           ; configure active high endstops
      M574 Y2 S1 P"io1.in"                           ; configure active high endstops
      M671 X-4.5:150:304.5 Y-4.52:305:-4.52 S5       ; define positions of Z leadscrews or bed levelling screws
      M557 X30:280 Y20:290 P5                        ; define 5x5 mesh grid
      M308 S0 P"temp0" Y"thermistor" T100000 B3950 A"Keenevo 600W Bed"    ; configure sensor 0 as thermistor on pin temp0
      M950 H0 C"out0" T0 Q10												; Define Heater0 as the heated bed, bind to Sensor0
      M140 H0 P0															; Define Heated Bed
      M307 H0 R0.602 K0.401:0.000 D2.44 E1.35 S1.00 B0							; PID Tuning for Heater0, Heated Bed (100C)
      M143 H0 S120														; Set temperature limit for Heater0 to 120C
      M308 S1 P"121.temp0" Y"thermistor" T100000 B4725 C7.060000e-8 A"Slice Hotend"  ;Slice Engineering 300C thermistor, settings are online
      M950 H1 C"121.out0" T1 Q100													; Define Heater1 as Extruder0 heater, bind to Sensor1
      M307 H1 R3.030 K0.444:0.000 D4.49 E1.35 S1.00 B0 V23.8					; PID Tuning for Heater1, Extruder0 (240C)
      M143 H1 S285														; Set temperature limit for heater 1 to 285C
      M308 S2 P"temp1" Y"thermistor" A"Chamber 1 Upper" T100000 B4725 C7.060000e-8; Define Sensor as Chamber temperature
      ;M950 H0 C"out0" T0 Q10												; Define Heater0 as the heated bed, bind to Sensor0
      M308 S3 P"temp2" Y"thermistor" A"Chamber 2 Lower" T100000 B4725 C7.060000e-8; Define Sensor as Chamber temperature
      M308 S4 Y"drivers" A"4028 Power"    								; 4028 power using spare heater
      M308 S5 Y"mcu-temp" A"MCU"											; Define Sensor3 as the integrated MCU temperature sensor
      M308 S6 Y"drivers" A"TMC Drivers"									; Define Sensor4 as the TMC overheat sensor
      M308 S7 Y"mcu-temp" P"121.dummy" A"Toolboard 1LC"
      M307 S8 Y"drivers" P"121.dummy" A"1LC Stepper"
      M950 H2 C"!out2" T2 Q10												; Define Heater2 as the 4028 fan power, bind to Sensor2
      M143 H2 P2 S200
      M950 F0 C"!121.out1+out1.tach" Q25000 ;Q500							; create fan 0 on pin out4 and set its frequency
      M106 P0 C"Layer Fan" L0.0 X1.0 S0 H-1 B0.1							; set fan 0 name and value. Thermostatic control is turned off
      M950 F1 C"121.out2+out2.tach" Q500 				; Fan 1 uses out3, and using out3.tach as a tacho input
      M106 P1 C"Hotend Fan" S0 H1 T45        ; set fan 1 name and value. Thermostatic control turned on for Hotend
      M950 F2 C"out5" Q500                   ; create fan 1 on pin out5 and set its frequency
      M106 P2 C"Board Fan" S0 H2:3:4 T46        ; set fan 1 name and value. Thermostatic control turned on for Hotend
      M563 P0 D0 H1 F0 S"Mosquito Magnum"           										; define tool 0
      G10 P0 X0 Y0 Z0 R0 S0            ; set tool 0 axis offsets, set initial tool 0 active 60C and standby temperatures to 0C
      ;M563 P0 H0 F0 S"Keenevo 600W Bed"
      ;G10 P0 X0 Y0 Z0
      ;G10 P0 R50 S0
      ; Z-Probe Inductive Probe
      ;M558 P5 C"io3.in" H5 F400 T5000       ; set Z probe type to unmodulated and the dive height + speeds
      M558 P8 C"121.io0.in" H5 F400 T5000       ; set Z probe type to unmodulated and the dive height + speeds
      G31 P1000 X-28 Y-15 Z0.99               ; set Z probe trigger value, offset and trigger height, more Z means closer to the bed
      ;; BLTouch
      ; M950 S0 C"io7.out"                     ; Create a servo pin on io7
      ; M558 P9 C"io7.in" H5 F240 T10800 A5    ; set Z probe type to unmodulated and the dive height + speeds
      ; G31 P25 X-28.00 Y-13.00 Z0.78          ; set Z probe trigger value, offset and trigger height, more Z means closer to the bed
      ;Accelerometer
      M955 P121.0 I16
      ;Input Shaper
      M593 P"zvdd" F44		; for 10k acceleration
      ;M593 P"mzv" F42.5		; for 15k acceleration
      ;Filament Sensor0
      M591 D0 P3 C"121.io1.in" S1
      M591 D0 L27 R10:190
      ;PanelDue 5i
      M575 P1 S1 B57600
      ;NeoPixels x3
      M150 X3 Q4000000 ;R128 U128 B128 P128 S2 F0
      M150 X3 R255 U255 B255 W255 P255 S2 F0      ; display led
      ; Custom settings
      G29 S1
      M572 D0 S0.065; set Pressure Advance K-factor
      M501
      ;M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss
      ; init print time logging
      if !exists(global.runtime)
        M98 P"runtime.g"
      ; init LED variables
      if !exists(global.warmUp)
      	global warmUp = false
      ; Select default tool
      M404 N1.75															; Define filament diameter for print monitor
      T0
        jay_s_uk @RogerPodacter
        @RogerPodacter you need to map them to a heater to get them on the front page. this heater doesn't have to do anything. Just make sure you pin a spare pin that isn't being used for anything else (as i'm not sure you can use a dummy pin)
        RogerPodacterundefined 1 Reply Last reply Reply Quote 0
          RogerPodacter @jay_s_uk
          @jay_s_uk does it have to be a heater output pin, or can i use any spare output on the board? i tried both combinations but i'm still having trouble displaying both temperatures in DWC.
          M950 H2 C"io2.out" T0 Q10												; Define dummy Heater2 and spare pin as the heated bed, bind to Sensor0
          M950 H3 C"io3.out" T0 Q10												; Define dummy Heater3 and spare pin as the heated bed, bind to Sensor0
            @RogerPodacter I think you may get away with any spare pin.
            Give it a go and it'll either work or it won't.
            If it doesn't use a heater, fan or bed output
              @jay_s_uk i tried both but still no luck. the web interface doesnt show them. i have a spare heater pin, so i can use it. but it still didnt show in the web screen.
                @RogerPodacter follow the chamber info https://docs.duet3d.com/en/User_manual/Connecting_hardware/Heaters_chamber
                  @jay_s_uk thanks, i think that fixed it. final gcode:
                  M308 S2 P"temp1" Y"thermistor" A"Chamber 1 Upper" T100000 B4725 ; Define Sensor as Chamber temperature
                  M950 H2 C"out1" T0 Q10												; Define dummy Heater2 and spare pin as the heated bed, bind to Sensor0
                  M307 H2 B0 S1.00                             ; disable bang-bang mode for the chamber heater and set PWM limit
                  M141 H2                                      ; map chamber to heater 2
                  M143 H2 S120                                  ; set temperature limit for heater 2 to 60C
                  M308 S3 P"temp2" Y"thermistor" A"Chamber 2 Lower" T100000 B4725 ; Define Sensor as Chamber temperature
