    Z seam blobs, pause at layer change
    • davidewenundefined
      davidewen
      Re: [Trying to remove blobs](what order to change things)
      Hello all.
      I am getting significant blobs at layer changes on the Z seam of every print.
      This only happens on my Ender6 with the Duet mini5+. My Prusa doesn’t do this.
      Both printers have the same Bondtech direct drive extruders and Slice Engineering hot ends.
      I’m using Prusa slicer, but I have also tested Cura 5.x
      My printer pauses ever so slightly at each layer change.
      I have attempted to adjust retraction, coasting and other settings, but the pause is the primary issue.
      Has anyone else had this problem?
      Do you have ideas to solve it?
      Thanks!
        Post your config.g.
        I would guess that your Z axis is set to a very slow speed, so it's slow to change layers. Perhaps your extruder is also set slow.
        Sharing a sliced gcode file would be helpful as well.
        giostarkundefined davidewenundefined 2 Replies Last reply Reply Quote 0
        • giostarkundefined
          giostark @Phaedrux
          @Phaedrux
          Yo Phaedrux!
          He posted the same thing here (link) and I tried to answer him... let see if he will solve the problem:
          https://forum.duet3d.com/topic/14846/strange-blobbing-on-layer-change/32
          ps:
          i'm restoring a CNC for build some part for the full metal CoreXY high temp I'm assembling... That will be a very fine piece of hardware 😵
          Soon as possible I'll post stuffs 😊
            davidewen @Phaedrux
            @Phaedrux & @giostark
            Hey guys, thanks for responding.
            Yes, I did post 2x. Sorry, I found the older post after continuing my search after I posted.
            The g-code is 7.3mb. Not sure how to get it to you. Please advise and I'll send it.
            @Phaedrux , when you say my Z axis speed it slow, is that in the Duet config or in my slicer settings that you're referring to? Or maybe both?
              Phaedrux Moderator @davidewen
              @davidewen said in Z seam blobs, pause at layer change:
              Perhaps slice a smaller object.
