    Duet not starting properly if SBC is not on
    619
    • kuonundefined
      kuon
      I just built a new printer with a brand new duet 6HC, and I have the following issue:
      if the raspberry PI is not on before the duet, the PI cannot connect with the duet, and I have the following error in control server:
      30 17:18:59 lili systemd[1]: Starting Duet Control Server...
      Oct 30 17:18:59 lili DuetControlServer[669]: Duet Control Server v3.4.4
      Oct 30 17:18:59 lili DuetControlServer[669]: Written by Christian Hammacher for Duet3D
      Oct 30 17:18:59 lili DuetControlServer[669]: Licensed under the terms of the GNU Public License Version 3
      Oct 30 17:19:00 lili DuetControlServer[669]: [info] Settings loaded
      Oct 30 17:19:00 lili DuetControlServer[669]: [info] Environment initialized
      Oct 30 17:19:00 lili DuetControlServer[669]: [warn] Restarting full transfer because a bad header format code was received (0xff)
      Oct 30 17:19:02 lili DuetControlServer[669]: [warn] Restarting full transfer because a bad header format code was received (0xff)
      Oct 30 17:19:02 lili DuetControlServer[669]: [fatal] Could not connect to Duet: Timeout while waiting for transfer ready pin
      Oct 30 17:19:02 lili systemd[1]: duetcontrolserver.service: Main process exited, code=exited, status=69/UNAVAILABLE
      If I start the PI, wait for it to boot, THEN start the duet, it works, but that's cumbersome because I would need a timed relay or something to sequence the power up.
      There is no SD card in the duet.
      gloomyandyundefined o_lampeundefined 2 Replies Last reply Reply Quote 0
      • gloomyandyundefined
        gloomyandy @kuon
        @kuon Do you have 3.4.4 firmware installed on the 6HC board?
        kuonundefined 1 Reply Last reply Reply Quote 0
        • kuonundefined
          kuon @gloomyandy
          Yes, everything is running 3.4.4
          M122 report
          RepRapFirmware for Duet 3 MB6HC version 3.4.4 (2022-10-20 16:19:01) running on Duet 3 MB6HC v1.01 (SBC mode)
          Board ID: 08DJM-956BA-NA3TJ-6J9D6-3S46J-TB8US
          Used output buffers: 1 of 40 (14 max)
          Static ram: 152824
          Dynamic ram: 68024 of which 0 recycled
          Never used RAM 129824, free system stack 200 words
          Tasks: SBC(resourceWait:,0.7%,472) HEAT(notifyWait,0.0%,328) Move(notifyWait,0.0%,351) CanReceiv(notifyWait,0.0%,798) CanSender(notifyWait,0.0%,335) CanClock(delaying,0.0%,340) TMC(notifyWait,7.8%,91) MAIN(running,90.4%,1231) IDLE(ready,1.1%,30), total 100.0%
          Owned mutexes: HTTP(MAIN)
          Last reset 00:00:59 ago, cause: power up
          Last software reset at 2022-10-29 23:58, reason: User, GCodes spinning, available RAM 128696, slot 0
          Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0x00000000 SP 0x00000000 Task SBC Freestk 0 n/a
          Error status: 0x00
          Step timer max interval 131
          MCU temperature: min 28.0, current 38.4, max 38.4
          Supply voltage: min 23.8, current 23.9, max 24.0, under voltage events: 0, over voltage events: 0, power good: yes
          12V rail voltage: min 12.1, current 12.1, max 12.1, under voltage events: 0
          Events: 0 queued, 0 completed
          Driver 0: standstill, SG min 0, mspos 8, reads 2751, writes 11 timeouts 0
          Driver 1: standstill, SG min 0, mspos 8, reads 2748, writes 14 timeouts 0
          Driver 2: standstill, SG min 0, mspos 8, reads 2749, writes 14 timeouts 0
          Driver 3: standstill, SG min 0, mspos 8, reads 2749, writes 14 timeouts 0
          Driver 4: standstill, SG min 0, mspos 8, reads 2749, writes 14 timeouts 0
          Driver 5: standstill, SG min 0, mspos 8, reads 2749, writes 14 timeouts 0
          Date/time: 2022-10-30 20:41:08
          Slowest loop: 1.55ms; fastest: 0.04ms
          === Storage ===
          Free file entries: 10
          DMs created 125, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000
          === MainDDARing ===
          === AuxDDARing ===
          Bed heaters 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0
          Segments left: 0
          Movement lock held by null
          Telnet is idle in state(s) 0
          File is idle in state(s) 0
          USB is idle in state(s) 0
          Aux is idle in state(s) 0
          Queue is idle in state(s) 0
          LCD is idle in state(s) 0
          SBC is idle in state(s) 0
          Daemon is idle in state(s) 0
          Aux2 is idle in state(s) 0
          Code queue is empty
          === CAN ===
          Messages queued 567, received 2376, lost 0, boc 0
          Longest wait 3ms for reply type 6053, peak Tx sync delay 6, free buffers 50 (min 49), ts 298/297/0
          Tx timeouts 0,0,0,0,0,0
          === SBC interface ===
          Transfer state: 5, failed transfers: 0, checksum errors: 0
          RX/TX seq numbers: 360/2533
          SPI underruns 0, overruns 0
          State: 5, disconnects: 1, timeouts: 0 total, 0 by SBC, IAP RAM available 0x2ad08
          Buffer RX/TX: 0/0-0, open files: 0
          === Duet Control Server ===
          Code buffer space: 4096
          Configured SPI speed: 8000000Hz, TfrRdy pin glitches: 0
          Full transfers per second: 39.12, max time between full transfers: 36.7ms, max pin wait times: 27.6ms/1.2ms
          Codes per second: 0.11
          Maximum length of RX/TX data transfers: 3497/28
          kuonundefined o_lampeundefined 2 Replies Last reply Reply Quote 0
          • kuonundefined
            kuon @kuon
            Also I noticed that the "status" LED on the mainboard is dim and not blinking, and the status led on toolboards is blinking quickly, like 2Hz.
            • o_lampeundefined
              o_lampe @kuon
              @kuon said in Duet not starting properly if SBC is not on:
              Would it be possible to add a G4 S60 command at the beginning of config.g to wait a minute?
              Or maybe toggle an IO pin on the PI after boot, which allows Duet to boot? (hold down Duet reset button or the like)
                jay_s_uk @kuon
                @kuon the status LED being dim points to there being no firmware on the board.
                • o_lampeundefined
                  o_lampe @kuon
                  M122 report
                  AFAIK, you must run M122 for each board separately. You've only posted the mainboard status...
                    gloomyandy @o_lampe
                    "Would it be possible to add a G4 S60 command at the beginning of config.g to wait a minute?"
                    @o_lampe The problem is that you can't read the config.g file if there is no SBC to provide it....
                    • kuonundefined
                      kuon @o_lampe
                      @o_lampe Yes, and they are all running 3.4.4. But when I tried to fix the issue, the toolboard where disconnected so I didn't think of including the M122 output.
                      I think the issue occurs even before the duet can start loading the config.g or anything. It just stays here.
                      • kuonundefined
                        kuon @kuon
                        I also tried pressing the reset button, but it doesn't do anything. Power cycling the duet fixes the issue and the duet connects to the SBC. But this doesn't help, as I would need to power up the duet after the SBC had booted, and this would require an additional timed relay.
                        @dc42 what is the duet looking for when booting to try to communicate with the SBC? Should a pin on the ribbon be pulled up and it arrives too late in my case?
                        • kuonundefined
                          kuon @kuon
                          I think I found the issue, my 5V power supply for my PI takes about 500ms to run to a steady 5V, but the Duet regulator is faster, (I clearly see a sequence in the LEDs) and what I think is happening is that the duet sees that the 5V pin for the PI is not at 5V and then ignores it (@dc42 might be able to confirm this).
                          I have removed the INT 5V EN jumper, and I am now providing the duet 5V from the power supply I use for the PI through the EXT 5V KK connector and the issue is gone.
                          o_lampeundefined 1 Reply Last reply Reply Quote 1
                          • o_lampeundefined
                            o_lampe @kuon
                            @kuon The problem wit RasPi powersupplies is: they produce a little more than 5V. Just check out your'e not toasting the other 5V components with it.
                            kuonundefined dc42undefined 2 Replies Last reply Reply Quote 0
                            • kuonundefined
                              kuon @o_lampe
                              @o_lampe It is a power supply I made myself to convert from 24V, and it has a regulated 5V output which I measured between 4.95 and 5.06V with my scope, so I guess it should be fine.
                                dc42 administrators @o_lampe
                                @o_lampe the Duet is quite happy with a little more than 5V such as the 5.2V typically provided by RPi PSUs. The absolute maximum is 6.5V or 7V AFAIR.
                                • kuonundefined
                                  kuon @dc42
                                  @dc42 Is the behaviour I am observing normal? I mean the duet ignoring the SBC if SBC's 5V comes a bit late after duet powering up.
