    Euclid Z Probe - Deploy Errors Gcode Logic
    • RogerPodacterundefined
      RogerPodacter
      I'm having trouble getting my newly installed Euclid / Klicky probe to function smoothly with Duet 3 Mini 5+. I successfully have the probe able to dock and undock correctly automatically when a home request is performed. But when i do a 3 point leadscrew tram/bed level, the probe docks and undocks between each point measurement, so its incredibly slow and cumbersome. I have some logging turned on to try and help seeing the logic, but i cannot figure it out.
      It seems that the deploy token never gets set to true.
      I have attached my relevant files and a console output:
      console output
      config.g
      deployprobe.g
      retractprobe.g
      bed.g
      homez.g
      console
      11/14/2022, 6:23:07 PM 	Leadscrew adjustments made: 0.054 0.046 0.042, points used 3, (mean, deviation) before (0.047, 0.004) after (-0.000, 0.000)
      Current rough pass deviation: 0.004
      Final deviation: 0.004
      11/14/2022, 6:22:50 PM 	Macro deployprobe.g complete
      11/14/2022, 6:22:45 PM 	Probe Pickup complete
      Object Model Deployuser token (after while loop) = true
      11/14/2022, 6:22:44 PM 	Probe Value =0
      11/14/2022, 6:22:43 PM 	Object Model Deployuser token (before while loop) = true
      11/14/2022, 6:22:40 PM 	Running deployprobe.g
      Object Model Deployuser token =true
      Lift Z in advance of deploy
      Probe Value =1000
      Passed first logic test to deploy probe
      Probe Pickup macro running
      11/14/2022, 6:22:38 PM 	complete movement commands
      Macro retractprobe.g complete
      Leadscrew adjustments made: 0.013 0.001 0.006, points used 3, (mean, deviation) before (0.006, 0.004) after (0.000, 0.000)
      Current deviation: 0.004
      11/14/2022, 6:22:36 PM 	Probe Value =1000
      Object Model Deployuser token =false
      11/14/2022, 6:22:25 PM 	running retractprobe.g macro
      Probe Value =0
      11/14/2022, 6:22:21 PM 	Macro deployprobe.g complete
      11/14/2022, 6:22:17 PM 	Probe Value =0
      Object Model Deployuser token (after while loop) = false
      11/14/2022, 6:22:15 PM 	Object Model Deployuser token (before while loop) = false
      11/14/2022, 6:22:12 PM 	Probe Value =1000
      11/14/2022, 6:22:11 PM 	complete movement commands
      11/14/2022, 6:22:10 PM 	Probe Value =1000
      11/14/2022, 6:21:58 PM 	running retractprobe.g macro
      Probe Value =0
      11/14/2022, 6:21:54 PM 	Macro deployprobe.g complete
      11/14/2022, 6:21:50 PM 	Probe Pickup complete
      11/14/2022, 6:21:49 PM 	Probe Value =0
      11/14/2022, 6:21:48 PM 	Object Model Deployuser token (before while loop) = false
      11/14/2022, 6:21:45 PM 	Probe Value =1000
      11/14/2022, 6:21:44 PM 	complete movement commands
      11/14/2022, 6:21:42 PM 	Probe Value =1000
      11/14/2022, 6:21:36 PM 	running retractprobe.g macro
      Probe Value =0
      11/14/2022, 6:21:32 PM 	Macro deployprobe.g complete
      11/14/2022, 6:21:28 PM 	Probe Pickup complete
      11/14/2022, 6:21:27 PM 	Probe Value =0
      11/14/2022, 6:21:26 PM 	Object Model Deployuser token (before while loop) = false
      11/14/2022, 6:21:23 PM 	Probe Value =1000
      11/14/2022, 6:21:22 PM 	complete movement commands
      Leadscrew adjustments made: 0.028 0.042 0.043, points used 3, (mean, deviation) before (0.038, 0.006) after (0.000, 0.000)
      Current rough pass deviation: 0.006
      Deviation over threshold. Executing pass 1 deviation 0.006
      11/14/2022, 6:21:20 PM 	Probe Value =1000
      11/14/2022, 6:21:09 PM 	running retractprobe.g macro
      Probe Value =0
      11/14/2022, 6:21:05 PM 	Macro deployprobe.g complete
      11/14/2022, 6:21:01 PM 	Probe Pickup complete
      11/14/2022, 6:20:59 PM 	Probe Value =0
      11/14/2022, 6:20:58 PM 	Object Model Deployuser token (before while loop) = false
      11/14/2022, 6:20:56 PM 	Probe Value =1000
      11/14/2022, 6:20:55 PM 	complete movement commands
      11/14/2022, 6:20:53 PM 	Probe Value =1000
      11/14/2022, 6:20:42 PM 	running retractprobe.g macro
      Probe Value =0
      11/14/2022, 6:20:38 PM 	Macro deployprobe.g complete
      11/14/2022, 6:20:34 PM 	Probe Pickup complete
      11/14/2022, 6:20:33 PM 	Probe Value =0
      11/14/2022, 6:20:32 PM 	Object Model Deployuser token (before while loop) = false
      11/14/2022, 6:20:29 PM 	Probe Value =1000
      11/14/2022, 6:20:28 PM 	complete movement commands
      11/14/2022, 6:20:27 PM 	Probe Value =1000
      11/14/2022, 6:20:20 PM 	running retractprobe.g macro
      Probe Value =0
      11/14/2022, 6:20:16 PM 	Macro deployprobe.g complete
      11/14/2022, 6:20:12 PM 	Probe Pickup complete
      11/14/2022, 6:20:11 PM 	Probe Value =0
      11/14/2022, 6:20:10 PM 	Object Model Deployuser token (before while loop) = false
      11/14/2022, 6:20:07 PM 	Probe Value =1000
      11/14/2022, 6:20:06 PM 	G32
      11/14/2022, 6:20:01 PM 	complete movement commands
      11/14/2022, 6:19:59 PM 	Probe Value =1000
      11/14/2022, 6:19:50 PM 	running retractprobe.g macro
      Probe Value =0
      11/14/2022, 6:19:46 PM 	Macro deployprobe.g complete
      11/14/2022, 6:19:42 PM 	Probe Pickup complete
      11/14/2022, 6:19:41 PM 	Probe Value =0
      11/14/2022, 6:19:40 PM 	Object Model Deployuser token (before while loop) = false
      11/14/2022, 6:19:37 PM 	Probe Value =1000
      11/14/2022, 6:19:36 PM 	G28
      config.g
      G90                                     ; send absolute coordinates...
      M83                                     ; ...but relative extruder moves
      M550 P"V-Core3"                         ; set printer name
      M669 K1                                 ; CoreXY
      G21                                     ; Set Units to Millimeters
      M552 S2                                 ; enable network
      M586 P0 S1                              ; enable HTTP
      M586 P1 S0                              ; disable FTP
      M586 P2 S0                              ; disable Telnet
      G4 S2 ; wait for expansion boards to start
      M569 P0.0 S0 D2	                        ; Left Z physical drive 0.0 goes forwards
      M569 P0.1 S0 D2                         ; Rear Z physical drive 0.1 goes forwards
      M569 P0.2 S0 D2                            ; Right Z physical drive 0.2 goes forwards
      M569 P0.3 S1 D2                            ; Right physical drive 0.3 goes forwards
      M569 P0.4 S1 D2                            ; Left physical drive 0.4 goes forwards
      M569 P121.0 S1 D2                            ; Extruder physical drive 0.5 goes forwards
      M584 X0.4 Y0.3 Z0.0:0.1:0.2 E121.0        ; set drive mapping
      M350 X16 Y16 Z16 E16 I1                 ; configure microstepping with interpolation
      M92 X80.00 Y80.00 Z800.00 E690 ;E400               ; set steps per mm
      M906 X2000 Y2000 Z1800 E1000 I10 ;E700 I30              ; set motor currents (mA) and motor idle factor in per cent -- safe for Duet 3 mini 5+
      M84 S30                                 ; Set idle timeout
      M566 X500.00 Y500.00 Z60.00 E300 P1 				;X1500.00 Y1500.00 Z6.00 E300 P1 ;E120.00 P1          ; set maximum instantaneous speed changes (mm/min)
      M203 X30000.00 Y30000.00 Z1000.00 E7200 			;E3600.00     ; set maximum speeds (mm/min)
      M201 X10000.00 Y10000.00 Z100.00 E10000 			;E3600.00        ; set accelerations (mm/s^2)
      M207 S0.6 F7200 Z0.2						; firmware retraction orbiter 2.0
      M208 X0 Y0 Z0 S1                               ; set axis minima
      M208 X310 Y310 Z300 S0                         ; set axis maxima
      M574 X1 S1 P"121.io2.in"                           ; configure active high endstops
      M574 Y2 S1 P"io1.in"                           ; configure active high endstops
      M574 Z1 S2
      M671 X-4.5:150:304.5 Y-4.52:305:-4.52 S5       ; define positions of Z leadscrews or bed levelling screws
      M557 X30:280 Y20:290 P5                        ; define 5x5 mesh grid
      M308 S0 P"temp0" Y"thermistor" T100000 B3950 A"Keenevo 600W Bed"    ; configure sensor 0 as thermistor on pin temp0
      M950 H0 C"out0" T0 Q10												; Define Heater0 as the heated bed, bind to Sensor0
      M140 H0 P0															; Define Heated Bed
      M307 H0 R0.602 K0.401:0.000 D2.44 E1.35 S1.00 B0							; PID Tuning for Heater0, Heated Bed (100C)
      M143 H0 S140														; Set temperature limit for Heater0 to 120C
      M308 S1 P"121.temp0" Y"thermistor" T100000 B4725 C7.060000e-8 A"Slice Hotend"  ;Slice Engineering 300C thermistor, settings are online
      M950 H1 C"121.out0" T1 Q100													; Define Heater1 as Extruder0 heater, bind to Sensor1
      M307 H1 R3.030 K0.444:0.000 D4.49 E1.35 S1.00 B0 V23.8					; PID Tuning for Heater1, Extruder0 (240C)
      M143 H1 S325														; Set temperature limit for heater 1 to 285C
      M308 S2 P"temp1" Y"thermistor" T100000 B3950 A"Chamber" ; configure sensor 2 as thermistor on pin temp2
      M950 H2 C"out1" T2 ;Q10												; create chamber heater output on out1 and map it to sensor 2
      M307 H2 R0.01 K0.200:0.000 D60 E1.35 S1.00 B1                              ; enable bang-bang mode for the chamber heater and set PWM limit
      M141 H2                                      ; map chamber to heater 2
      M143 H2 S120                                  ; set temperature limit for heater 2 to 60C
      M308 S3 P"121.temp1" Y"thermistor" A"Toolhead Motor" T100000 B4725 C7.060000e-8 ; Define Sensor as Chamber temperature
      M308 S4 Y"drivers" A"4028 Power"    								; 4028 power using spare heater
      M308 S5 Y"mcu-temp" A"MCU"											; Define Sensor3 as the integrated MCU temperature sensor
      M308 S6 Y"drivers" A"TMC Drivers"									; Define Sensor4 as the TMC overheat sensor
      M308 S7 Y"mcu-temp" P"121.dummy" A"Toolboard 1LC"
      M308 S8 Y"drivers" P"121.dummy" A"1LC Stepper"
      M950 H3 C"!out2" T2 Q10	;H2											; Define Heater2 as the 4028 fan power, bind to Sensor3
      M143 H3 P2 S200														; Needed M143 to set max temp so the graph scaled correctly
      M950 F0 C"!121.out1+out1.tach" Q25000 ;Q500							; create fan 0 on pin out4 and set its frequency
      M106 P0 C"Layer Fan" L0.0 X1.0 S0 H-1 B0.1							; set fan 0 name and value. Thermostatic control is turned off
      M950 F1 C"121.out2+out2.tach" Q500 				; Fan 1 uses out3, and using out3.tach as a tacho input
      M106 P1 C"Hotend Fan" S0 H1 T45        ; set fan 1 name and value. Thermostatic control turned on for Hotend
      M950 F2 C"out5" Q500                   ; create fan 1 on pin out5 and set its frequency
      M106 P2 C"Board Fan" S0 H4:5:6 T46        ; set fan 1 name and value. Thermostatic control turned on for Hotend
      M950 F3 C"out3+out3.tach" Q500                   ; Chamber Heater Fan Noctua NF-F12 Industrial
      M106 P3 C"Chamber Heater Fan" S0.0 L1.0 X0.0 H2 T100 ; S0.3  L0.3 X0.6 B0.1 T30:40       ; set fan 1 name and value. Thermostatic control turned on for Hotend
      M950 F4 C"out4" Q500                   ; create fan 4 for Water Cooling 12V Fan 4 on pin out4 and set its frequency
      M106 P4 C"Liquid Cooling Fan" S0 H4:5:6 T15        ; set fan 1 name and value. Thermostatic control turned on for Hotend
      M563 P0 D0 H1 F0 S"Mosquito Magnum"           										; define tool 0
      G10 P0 X0 Y0 Z0 R0 S0            ; set tool 0 axis offsets, set initial tool 0 active 60C and standby temperatures to 0C
      ;M563 P0 H0 F0 S"Keenevo 600W Bed"
      ;G10 P0 X0 Y0 Z0
      ;G10 P0 R50 S0
      ; Z-Probe Inductive Probe
      ;M558 P5 C"121.io0.in" H5 F400 T5000       ; set Z probe type to unmodulated and the dive height + speeds
      M558 P8 C"^121.io0.in" H8 F400 T9000 A1 ; S0.01       ; set Z probe type to unmodulated and the dive height + speeds
      G31 P1000 X-28 Y-20 Z8.50    ; K0           ; set Z probe trigger value, offset and trigger height, more Z means closer to the bed
      ;; BLTouch
      ; M950 S0 C"io7.out"                     ; Create a servo pin on io7
      ; M558 P9 C"io7.in" H5 F240 T10800 A5    ; set Z probe type to unmodulated and the dive height + speeds
      ; G31 P25 X-28.00 Y-13.00 Z0.78          ; set Z probe trigger value, offset and trigger height, more Z means closer to the bed
      ;Accelerometer
      M955 P121.0 I16
      ;Input Shaper
      M593 P"zvdd" F44		; for 10k acceleration
      ;M593 P"mzv" F42.5		; for 15k acceleration
      ;Filament Sensor0
      M591 D0 P3 C"121.io1.in" S1
      M591 D0 L27 R10:190
      ;PanelDue 5i
      M575 P1 S1 B57600
      ;NeoPixels x3
      M150 X3 Q4000000 ;R128 U128 B128 P128 S2 F0
      M150 X3 R255 U255 B255 W255 P255 S2 F0      ; display led
      ; Custom settings
      G29 S1
      M572 D0 S0.01; set Pressure Advance K-factor
      M501
      ;M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss
      ; init print time logging
      if !exists(global.runtime)
        M98 P"runtime.g"
      ; init LED variables
      if !exists(global.warmUp)
      	global warmUp = false
      ; Select default tool
      M404 N1.75															; Define filament diameter for print monitor
      T0
      retractprobe.g homez.g deployprobe.g bed.g
      • A Former User?
        A Former User
        This post is deleted!
        RogerPodacterundefined 1 Reply Last reply Reply Quote 0
          RogerPodacter @A Former User
          @Herve_Smith thanks, so you are calling your homexy.g directly.
          i made some progress by adding M401 deploy probe at the beginning of my bed.g. now it trams all points with the same deploy, but now i get a new error due to the last line of my bed.g where i home Z one final time after tramming.
          ERROR G28 may not be used within a homing file.
          but this line has always been present at the end of my bed.g. for some reason the M401 and M402 commands don't like this. i'm stuck on this now.
          bed.g
          M290 R0 S0    ;  clear baby stepping
          M561          ;  reset all bed adjustments
          M400          ;  flush move queue
          ; echo "Running bed4point.g"
          ;M558 F60 A6 ;A3                              ; fix probe speed to 1mm/s
          ;G90
          ;G4 P250
          if !move.axes[0].homed || !move.axes[1].homed || !move.axes[2].homed
          	echo "not all axes homed, homing axes first"
          	G28
          M401 ; deploy Z probe (omit if using bltouch)
          G30 P0 X30 Y20 Z-99999 ;X30 Y20 Z-99999 ; probe near a leadscrew
          G30 P1 X155 Y276 Z-99999 ;Y282 Z-99999 ; probe near a leadscrew
          G30 P2 X279 Y20 Z-99999 S3 ; probe near a leadscrew and calibrate 3 motors
          echo "Current rough pass deviation: " ^ move.calibration.initial.deviation
          while move.calibration.initial.deviation > 0.005
          		if iterations >= 5
          			echo "Error: Max attemps failed. Deviation: " ^ move.calibration.initial.deviation
          			break
          		echo "Deviation over threshold. Executing pass" , iterations+1, "deviation", move.calibration.initial.deviation
          		G30 P0 X30 Y20 Z-99999 ; probe near a leadscrew
          		G30 P1 X155 Y276 Z-99999 ; probe near a leadscrew
          		echo "Current deviation: " ^ move.calibration.initial.deviation
          		continue
          echo "Final deviation: " ^ move.calibration.initial.deviation
          M402 ; retract probe (omit if using bltouch)
          G0 X155 Y155 Z10 F9000
          ; rehome Z as the absolute height of the z plane may have shifted
          G28 Z
            jay_s_uk @RogerPodacter
            @RogerPodacter can you post your homez file?
              RogerPodacter @jay_s_uk
              @jay_s_uk
              homez.g
              ; Euclid Probe homez.g Example Macro
              ; RRF3.X Firmware Example
              ; saveas system/homez.g
              ; comments and echo statements throughout are provided for convenience
              if !move.axes[0].homed || !move.axes[1].homed     ; If the printer hasn't been homed, home it
              	M98 P"0:/sys/homexy.g"
              M561                                            ; clear any bed transform
              M290 S0 R0                                      ; clear baby steps
              G91                                             ; relative positioning
              G1 H2 Z6 F6000                                  ; lift Z relative to current position to clear any obstructions
              M400
              G90                                             ; absolute positioning
              ; echo "Call deployprobe.g macro"
              M401 P0                                         ; This runs macro file deployprobe
              ; echo "Return"
              G1 X145 Y162.5 F9000                            ; go to center of bed in advance of probe that point
              M400
              ; echo "G30 Command"
              G30                                             ; Probe the bed at the current XY position. When the probe is triggered,
                                                              ; adjust the Z offset of the current tool to make the current position Z=0.
              G1 Z10                                          ; raise Z=10
              M400
              G4 P500
              ; echo "Call bed4point.g macro"
              M98 P"0:/sys/bed.g"                       ; tram bed
              ; echo "Return"
              G1 X145 Y162.5 F9000                              ; go back to the first probe point and reprobe 0 in case it moved
              G30
              ; echo "Call retractprobe.g macro"
              M402 P0                                         ; retract probe
              ; echo "Return"
              G1 Z10 F600                                     ; lift Z relative to current position
              M564 S1 H0                                      ; reset the bounding limits
              ; G1 X150 Y0 F9000                              ; move carriage to center front
                @RogerPodacter it may be that you're calling the bed macro from home z, which is then itself calling home z, which is calling bed and so on.
                Remove calling the bed file from home z use G32 after you've homed the machine
                RogerPodacterundefined 1 Reply Last reply Reply Quote 1
                  @jay_s_uk
                  i experimented a bit removing that command but didnt have much luck resolving the issue. i think i finally have it working, using your advice i removed the G28 and replaced with a G30 at the end of bed.g and that seemed to give the behavior expected. it completes the cycle fully.
                  ;G90
                  ;G4 P250
                  	G28
                  		if iterations >= 5
                  			break
                  		continue
                  G30
                  ;G28 Z
