    problems with setting current for step motor
    560
    • Kirylundefined
      Kiryl
      Hello
      We are facing a problem with settings the motor current.
      When the motor shaft is going to lift the lead, it starts messing steps and going down with a snap, then we measured the current and concluded that it was not enough
      The max value for our type of motor is 5 amps, so we set the current by M906 Z5000.
      and when we started to measure current by multimeter, we saw something about 1 amp.
      Can you help out with our problem?
      Best regards
        jay_s_uk @Kiryl
        @Kiryl what board are you using? what firmware? what stepper motor is connected to Z?
        Kirylundefined 1 Reply Last reply Reply Quote 0
        • Kirylundefined
          Kiryl @jay_s_uk
          @jay_s_uk we are using MB6HC and motor drivers 1HCL, firmfire version is 3.3, and motor is CS-M22323B
          dc42undefined jay_s_ukundefined 2 Replies Last reply Reply Quote 0
          • jens55undefined
            jens55
            Motor current is an AC value, you are measuring DC. Even if you were measuring AC current, chances are that you would not get a correct reading. I would also suggest you look at the maximum output current on the stepper board you are using. A Duet 6HC can drive a peak current of 6.3A but a Duet 2 maxes out at 2.4A peak.
              dc42 administrators @Kiryl
              @Kiryl to measure the peak motor current you need to move the motor in very tiny steps with the driver in open loop mode. The current will change as the microstepping phase changes. Look for the peak value.
              The current is reduced when the motor is standing still or moving very slowly. By default the standstill current is 70% of the normal current.
                jay_s_uk @Kiryl
                @Kiryl i didn't think the 1HCL was supported by 3.3? release notes indicate it wasn't supported until RRF 3.4.
                I suggest upgrading the 3.4.4 and making sure all boards run the same version of the firmware (which they probably aren't).
                And yes, you can't easily measure the stepper current with a multimeter. I use one of Zapta's fantastic stepper motor analyzers
                • Kirylundefined
                  Kiryl @jens55
                  @jens55 Our step driver can provide up to 6.3A, but why we can't change the output current?
                  jens55undefined 1 Reply Last reply Reply Quote 0
                  • Kirylundefined
                    Kiryl @dc42
                    @dc42 Before that we measured the current consumption of the driver itself as DC, after your advice we measured the current of one phase of the motor in AC mode, and it turned out that there are about 4 amps. This means that the driver works properly and delivers the right current.
                    However we would like to increase duration time of ON state. We checked this with an oscilloscope and it turned out that the phase voltage is always the same and it does not increase even if the motor runs out of phase.
                    Is there any solution to this problem?
                    • jens55undefined
                      jens55 @Kiryl
                      @Kiryl, as I explained, you do not know what the driver output current is. You can not claim to know that you can't change the driver current unless you have valid data .... and you do not have that.
                      • jens55undefined
                        jens55 @Kiryl
                        @Kiryl said in problems with setting current for step motor:
                        Ahhh, now there is data you can work with ....
                        Next you need to understand how a stepper driver works. I myself am fuzzy on the concept but to my understanding you will never see a change in voltage. A stepper driver is a current source and not a voltage source. Current is controlled (I think) by switching the drive on a phase on and off. If you increase drive current then the 'on' time increases. I do not fully understand how the stepping algorithms work and exactly how the driver gets the motor to do a micro step but I believe it too is a function of the amount of current supplied to a given phase. In other words, the amount of current that a particular coil gets is dependant on exactly where in the micro step sequence you are. If you set up to use only full steps than what you see on the oscilloscope will likely make more sense.
                        Anyway, I will step back as I am not the right person to comment on this subject.
                        Good luck .... (it would appear to me that you are very likely getting the right amount of drive current)
                        • jens55undefined
                          jens55
                          An interesting experiment would be to change the supply voltage and watch how the 'on' time changes.
                          I also want to point out that while the picture of the oscilloscope is 'pretty', it doesn't really tell you much until you trigger a sweep at a precise and repeatable point, look at an entire full step or similarly longer stretch of time and then use the time delay to move a magnified view along the captured sweep. You should see that the current varies with each micro step and you will be able to find the point of maximum current, presumably on a full step boundary.
                          You would need to attach the probe to the current feedback resistor that the driver uses to determine how much current is flowing. If you simply look at the voltage supplied to the individual coil of the stepper motor, I would expect to see the 'on' time to vary with the micro step you are looking at with the longest 'on' time happening at a full step point.
                          To repeat myself - I haven't got a clue so take all of this with a good heaping of salt ...
                          • Kirylundefined
                            Kiryl @jens55
                            @jens55 Thank you for your help. We will fight it further
                              Can you send M122 and M122 B# (where # is the canbus address of your expansion boards) in the gcode console in DWC and copy and paste the results here?
                              Have you updated the firmware yet?
                              • Kirylundefined
                                Kiryl @Phaedrux
                                @Phaedrux this is what I get after sending M115 B51
                                "Duet EXP1HCL firmware version 3.4.0beta7+8 (2022-01-25 10:33:00)"
                                The M112 command is an emergency stop.
                                  jay_s_uk @Kiryl
                                  @Kiryl M122 not M112
                                  and as i've already commented, upgrade the firmware on all of them to 3.4.4 so they're all the same. You should not be mixing and matching firmware versions
                                  • Kirylundefined
                                    Kiryl @jay_s_uk
                                    @jay_s_uk oh yes, sorry.
                                    M122 B51 - "Diagnostics for board 51:
                                    Bootloader ID: SAME5x bootloader version 2.4 (2021-12-10)
                                    All averaging filters OK
                                    Never used RAM 52296, free system stack 2592 words
                                    Tasks: Move(notifyWait,0.0%,160) HEAT(notifyWait,0.0%,95) CanAsync(notifyWait,0.0%,69) CanRecv(notifyWait,0.0%,82) CanClock(notifyWait,0.0%,71) TMC(notifyWait,31.4%,360) CLSend(notifyWait,0.0%,152) MAIN(running,66.8%,400) IDLE(ready,0.0%,39) AIN(notifyWait,1.8%,265), total 100.0%
                                    Last reset 00:22:34 ago, cause: software
                                    Last software reset data not available
                                    Closed loop enabled: no, pre-error threshold: 0.00, error threshold: 0.00, encoder type none
                                    Driver 0: pos 0, 40.0 steps/mm,standstill, SG min 0, mspos 696, reads 15671, writes 19 timeouts 0, steps req 0 done 0
                                    Moves scheduled 0, completed 0, in progress 0, hiccups 0, step errors 0, maxPrep 0, maxOverdue 0, maxInc 0, mcErrs 0, gcmErrs 0
                                    Peak sync jitter -5/8, peak Rx sync delay 183, resyncs 0/0, no step interrupt scheduled
                                    VIN voltage: min 24.1, current 24.2, max 24.2
                                    V12 voltage: min 18.0, current 18.0, max 18.0
                                    MCU temperature: min 31.2C, current 31.2C, max 38.1C
                                    Last sensors broadcast 0x00000000 found 0 124 ticks ago, 0 ordering errs, loop time 0
                                    CAN messages queued 10869, send timeouts 0, received 6690, lost 0, free buffers 37, min 37, error reg 0
                                    dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 0"
                                    M122 - "=== Diagnostics ===
                                    RepRapFirmware for Duet 3 MB6HC version 3.4.1 (2022-06-01 21:09:01) running on Duet 3 MB6HC v1.01 or later (SBC mode)
                                    Board ID: 0JD2M-999AL-D2PS0-6JTDA-3SD6J-1NJ30
                                    Used output buffers: 1 of 40 (12 max)
                                    Static ram: 151000
                                    Dynamic ram: 64632 of which 0 recycled
                                    Never used RAM 135040, free system stack 200 words
                                    Tasks: SBC(resourceWait:,0.5%,482) HEAT(notifyWait,0.0%,371) Move(notifyWait,0.0%,352) CanReceiv(notifyWait,0.0%,772) CanSender(notifyWait,0.0%,374) CanClock(delaying,0.0%,339) TMC(notifyWait,7.5%,92) MAIN(running,91.9%,1254) IDLE(ready,0.0%,30), total 100.0%
                                    Owned mutexes: HTTP(MAIN)
                                    Last reset 00:23:07 ago, cause: software
                                    Last software reset at 2022-09-17 06:26, reason: User, GCodes spinning, available RAM 134696, slot 0
                                    Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0044a000 BFAR 0x00000000 SP 0x00000000 Task SBC Freestk 0 n/a
                                    Error status: 0x00
                                    Step timer max interval 136
                                    MCU temperature: min 37.5, current 39.2, max 39.4
                                    Supply voltage: min 23.9, current 23.9, max 24.0, under voltage events: 0, over voltage events: 0, power good: yes
                                    12V rail voltage: min 12.2, current 12.2, max 12.2, under voltage events: 0
                                    Events: 0 queued, 0 completed
                                    Driver 0: standstill, SG min 0, mspos 8, reads 53352, writes 11 timeouts 0
                                    Driver 1: standstill, SG min 0, mspos 8, reads 53352, writes 11 timeouts 0
                                    Driver 2: standstill, SG min 0, mspos 8, reads 53352, writes 11 timeouts 0
                                    Driver 3: standstill, SG min 0, mspos 8, reads 53352, writes 11 timeouts 0
                                    Driver 4: standstill, SG min 0, mspos 8, reads 53352, writes 11 timeouts 0
                                    Driver 5: standstill, SG min 0, mspos 8, reads 53353, writes 11 timeouts 0
                                    Date/time: 2022-09-17 06:49:26
                                    Slowest loop: 21.28ms; fastest: 0.03ms
                                    === Storage ===
                                    Free file entries: 10
                                    DMs created 125, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000
                                    === MainDDARing ===
                                    === AuxDDARing ===
                                    Bed heaters -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0
                                    Segments left: 0
                                    Movement lock held by null
                                    Telnet is idle in state(s) 0
                                    File is idle in state(s) 0
                                    USB is idle in state(s) 0
                                    Aux is idle in state(s) 0
                                    Queue is idle in state(s) 0
                                    LCD is idle in state(s) 0
                                    SBC is idle in state(s) 0
                                    Daemon is idle in state(s) 0
                                    Aux2 is idle in state(s) 0
                                    Code queue is empty
                                    === CAN ===
                                    Messages queued 6980, received 44466, lost 0, boc 0
                                    Longest wait 3ms for reply type 6024, peak Tx sync delay 382, free buffers 50 (min 49), ts 6940/6939/0
                                    Tx timeouts 0,0,0,0,0,0
                                    === SBC interface ===
                                    Transfer state: 5, failed transfers: 0, checksum errors: 0
                                    RX/TX seq numbers: 55494/55494
                                    SPI underruns 0, overruns 0
                                    State: 5, disconnects: 0, timeouts: 0 total, 0 by SBC, IAP RAM available 0x2b880
                                    Buffer RX/TX: 0/0-0, open files: 0
                                    === Duet Control Server ===
                                    Duet Control Server v3.4.1
                                    Code buffer space: 4096
                                    Configured SPI speed: 8000000Hz, TfrRdy pin glitches: 1
                                    Full transfers per second: 40.03, max time between full transfers: 57.9ms, max pin wait times: 55.8ms/14.7ms
                                    Codes per second: 0.02
                                    Maximum length of RX/TX data transfers: 3084/728"
                                      jay_s_uk @Kiryl
                                      there have been a number of fixes specific to the 1HCL board since the above beta release. please upgrade
                                        Update your firmware with the Pi terminal.
                                        https://docs.duet3d.com/en/User_manual/Machine_configuration/SBC_setup#h-6-update-firmware
                                        Then check the firmware versions for the boards again afterwards to see if they have been udpated.
