M671 setting
Hello friends could someone tell me what theM671 X369.75:-59.75 Y155:155 S5 line corresponds to, the dimensions are those of the bed?
@sgk where the pivot points are for where the bed or gantry is secured.
@jay_s_uk
And is there also a relation to these lines or not?
G30 P0 X10 Y155 Z-99999
G30 P1 X300 Y155 Z-99999 S2 -
@sgk those lines are where you probe the bed near to bed/gantry pivot positions.
@jay_s_uk Excuse me, I'm lost, what is the M671 used for? And how can I have the right dimensions for the M671 how to do?this is my bed 350x350x350
@sgk On the photo I have 2 axes but now I have 3 axes the photo was before.
@sgk
its probably going to be the ball screw positions for your printer.
how is the bed secured to the ballscrews? -
@sgk said in M671 setting:
See M671 in the Gcode dictionary.
The X and Y coordinates in M671 are measured from the origin X0,Y0 set by M208. Measure to the pivot point of the bed where it connects to the Z axis. This is often each leadscrew, but may also be offset from the leadscrew if the bed rests on a carriage extending out from the leadscrew.
See https://docs.duet3d.com/User_manual/Connecting_hardware/Z_probe_auto_levelling for a longer description.
Lay on marbles
@droftarts I looked at the documentation but I can't understand why I'm asking the group for help
@sgk In your case, the centre of each 'marble' is the pivot point of the bed. So:
The X and Y coordinates in M671 are measured from the origin X0,Y0 set by M208. Measure to the pivot point of the bed.
@sgk the the position of those balls then under the bed
@jay_s_uk yes exactly
This post is deleted! -
M584 X1 Y2 Z3:4:5 E0 ; set drive mapping Z3=Left center, Z4= Right front, Z5=Right rear
Your description of the positions here does not match your photo.
@Phaedrux ha ok i understand your answer
