Updated to RRF 3.4.5, no more toolboards
@paolozampini1973, hmmmm ..... don't know what to say - "she's dead jim"
What's the best way to downgrade? - Can I just pop out the memory card and install all the files directly from a separate computer ?
Guess I should have made a backup before upgrading - my bad
@jens55 said in Updated to RRF 3.4.5, no more toolboards:
dwc
@paolozampini1973, with a lot of help from @chrishamm I was able to re-flash the firmware and am now back in business.
@jens55 on 3.4.4 or 3.4.5?
@oliof, not clear on what you are asking but I went from 3.4.4 to 3.4.5 which failed. I then installed 3.4.5 using bossa and that worked.
SBC mode or standalone?
@dc42, standalone
@jens55 did you upload the zip file, or did you attempt to update the firmware in some other way?
@dc42, I uploaded the zip file, it unpacked successfully, it asked me if I wanted to install the new firmware (I said yes) and did it's thing. The printer disconnected and then never reconnected.
Once I had bossa up and running, before I did anything else, I did a 'verify' and tat actually failed so something was corrupt. I then replaced the firmware with bossa, disconnected the usb cable and powered up and all was well -
@jens55 thanks. Which main board do you have?
@dc42 6HC
Another 3.4.5 (MB6HC, SBC) with Toolboard 1LC 1.3. Toolboard is gone after firmware update to 3.4.5.
I've done lots of poking at it (initially it was a 2 blink, no firmware) now it's a 3 blink (bad CRC). I forced downgrade to 3.4.4, etc. No dice.
I have a thread on the Firmware board about it also:
https://forum.duet3d.com/topic/30641/toolboard-firmware-issues/ -
@chrishamm my boards are 1.3
