    Time estimates from PrusaSlicer
    2.7k
    • Exerqtorundefined
      Exerqtor
      (Please change the category if it's better suited under "Third-party software" or something)
      I know it's been a topic before, and i've skimmed thru those i could search up. But i couldn't find any fix for the stimate times being way off.
      I've been using SuperSlicer for a couple years now and found that Time estimation compensation: 108,5% is just about the sweetspot for my printer (1-2min of +/- on a print either it's 18min or 19hours).
      But since SS have been dead in the water for a couple months now, and PS coming with a few new features i've been missing I've taken the step back to PS.
      Now with the profiles mirrored between PS & SS the time estimates are off by roughly 1 hour on a print with an estimated time of about 2,5 hours, and it rises exponentially as the overall printtime goes up.
      Alot of smart people here, so maybe someone's found a work around with a post processing script or something?
      dc42undefined ComedianTF2undefined 2 Replies Last reply Reply Quote 0
        It seems strange to be that far off. Have you setup your machine limits accordingly?
        Is your estimated time too fast or too slow?
        Exerqtorundefined 1 Reply Last reply Reply Quote 0
          dc42 administrators @Exerqtor
          @Exerqtor try the PrusaSlicer fork from n8bot. It can fetch the Duet machine parameters to compute more accurate estimates.
          • ComedianTF2undefined
            ComedianTF2 @Exerqtor
            @Exerqtor In PrusaSlicer, go to the printer settings (set to advanced or expert), then under the machine limits tab (only showing when set to RepRapFirmware, not if set to RepRap/Sprinter), set the feedrates, acceleration and jerk limits.
            I would suggest to set it to "use for time estimate only" as well
            • Exerqtorundefined
              Exerqtor @Phaedrux
              @Phaedrux said in Time estimates from PrusaSlicer:
              My thought's too, first i was like "woow, what kind of black magic is this if it manages to print it this much faster with the same settings". But then when i actually did a print my enthusiasm was quickly curbed.
              Yeah the machine limit's should be set correctly, this is the settings that's ran while printing:
              ; Axis accelerations and speeds
              M566 X700.00 Y700.00 Z30.00 P1                                                 ; set maximum instantaneous speed changes (mm/min) and jerk policy
              M203 X18000.00 Y18000.00 Z900.00                                               ; set maximum speeds (mm/min)
              M201 X2000.00 Y2000.00 Z150.00                                                 ; set accelerations (mm/s²)
              ; Extruder accelerations and speeds
              M566 E8000.00 P1                                                               ; set maximum instantaneous speed changes (mm/min) and jerk policy
              M203 E15000.00        ; set maximum speeds (mm/min)
              M201 E1800.0        ; set accelerations (mm/s²)
              ; Printing and travel accelerations
              M204 P1500 T2000                                                               ; Set printing acceleration and travel accelerations (mm/s²)
              And this is what i've input in PrusaSlicer:
              Regarding which way it's wrong it's only been to slow. Haven't got the exact times for more than the last two prints and they are as following:
              Estimated: 1h27m / Realtime: 1h55m, Estimated: 22m / Realtime: 30m.
              The print i did before last restart was estimated to be 4h21m or something, but ended up being 5h57m if my memory serves right. So it's quite a significant error.
              @dc42 said in Time estimates from PrusaSlicer:
              He's fork haven't been updated in ages either (even older than SuperSlicer), so not to keen on jumping on an even more buggy build lol. But i saw the pull request on the master branch he made and commented on it yesterday so maybe something happes.
              @ComedianTF2 said in Time estimates from PrusaSlicer:
              Yeah I've done that allready 😃 Didn't help =/
                Is minimum layer time coming into effect? Do you have any macros or anything that set a different speed/accel/jerk than in config.g?
                Have you tried running a print simulation on one of these files? How accurate is it?
                • Exerqtorundefined
                  Exerqtor @Phaedrux
                  @Phaedrux
                  Nah nothing that slows it down at all, the settings i posted over is my printing/normal operating speeds etc. I only slow stuff down when probing/homing, and i've checked that the above mentioned parameters is applied when printing(in the object model browser). I'll run a simulation on the files later and see what it spews out.
                  You agree that i've input the machine limits correctly right? (sanity check😂)
                  • Exerqtorundefined
                    Exerqtor @Exerqtor
                    I only had time to simulate one file yesterday, the "Estimated: 1h27m / Realtime: 1h55m" one. And the simulation said 1h31m, so closer to estimation than reality (heating time is about 5min from 22c to 110c, so it's not the reason either).
                    Edit:
                    Simulated anoter file with and Estimate of 3h39m / realtime 4h20-something, the simulation said 3h45m.
                    On a little sidenote, is it a way i can stop the simulation from spamming Error: Attempting to extrude with no tool selected. about 2times every minute thru the whole simulation?
                    • oliofundefined
                      oliof @Exerqtor
                      @Exerqtor add T0 P0 to the start gcode of your files, or to the end of config.g to get rid of that error.
                      • Exerqtorundefined
                        Exerqtor @oliof
                        @oliof Yeah i found the "issue" i have the first extruder set via a global variable in my start macro, but it that apparently don't work in simulations.
                          So the time estimate from the slicer matches fairly close to the actual simulated time, but the actual print time is much longer?
                          At this point I'd say share all your system files and macros so we can take a close look at what is happening.
                          • Exerqtorundefined
                            Exerqtor @Phaedrux
                            @Phaedrux
                            That's what i saw too, i was surprised the simulation being that close to the estimate ngl.
                            Well this is going to be a longass post with all the system files, but here we go:
                            config.g:
                            ; Configuration file for Duet 3 Mini 5+ with Duet 3 Expansion Mini 2+ and 1LC (firmware version 3.4.x)
                            ; For E3D Revo Micro ----------------------------------------------------------
                            ; Basic setup
                            M575 P1 S1 B57600                                                              ; enable support for PanelDue
                            ;M111 S0        ; debugging off
                            G21        ; work in millimetres
                            G90        ; send absolute coordinates...
                            M83        ; set extruder to relative mode
                            M550 P"Voron Trident"                                                          ; set printer name
                            G4 S2        ; wait a moment for the CAN expansion boards to start
                            ; Kinematics
                            M669 K1	X-1:-1:0 Y1:-1:0 Z0:0:1                                                ; select CoreXY mode and set kinematics matrix
                            M552 S1        ; enable network
                            G4 S1        ; wait a second
                            M586 P0 S1        ; enable HTTP (for DWC)
                            M586 P1 S1        ; enable FTP (for remote backups)
                            M586 P2 S0        ; disable Telnet
                            ; Driver config
                            ; Drives for Z
                            M569 P0.2 S0        ; Z1 (physical drive 2) goes backwards
                            M569 P0.3 S0        ; Z2 (physical drive 3) goes backwards
                            M569 P0.4 S0        ; Z3 (physical drive 4) goes backwards
                            ; --- Z drive map ---
                            ;   |  0.2  |
                            ;   |0.3|0.4|
                            ;     front
                            ; Drives for XY
                            M569 P0.0 S0        ; X (physical drive 0) goes backwards
                            M569 P0.1 S0        ; Y (physical drive 1) goes backwards
                            ; Drive for extruder
                            M569 P121.0 S0        ; E (physical drive 121.0) goes backwards
                            ; Motor mapping and steps per mm
                            M584 X0.0 Y0.1 Z0.2:0.3:0.4 E121.0                                             ; set drive mapping
                            M350 X16 Y16 Z16:16 E16 I1                                                     ; configure microstepping with interpolation
                            M92 X80.00 Y80.00 Z800.00                                                      ; set XYZ steps per mm (1.8deg motors)
                            M92 E568.83        ; set Extruder steps per mm (Bondtech LGX Lite 562 stock)
                            ; Drive currents
                            M906 X1750 Y1750 Z1170 E550                                                    ; set XYZ motor currents (mA)
                            M906 I30        ; set ide current percentage
                            M84 S30        ; Set idle timeout
                            ; Movement
                            M208 X-2,5 Y0 Z0 S1                                                            ; set axis minima
                            M208 X348 Y359 Z300 S0                                                         ; set axis maxima
                            M574 X2 S1 P"io1.in"                                                           ; configure switch-type (e.g. microswitch) endstop for high end on X via pin io1.in
                            M574 Y2 S1 P"io2.in"                                                           ; configure switch-type (e.g. microswitch) endstop for high end on Y via pin io2.in
                            M574 Z0 P"nil"        ; no endstop
                            ; Z-probe (klicky probe)
                            M558 K0 P8 C"^121.io2.in" H2 R0.2 F600:180 T18000 A5 S0.01                     ; set Z probe type to switch and the dive height + speeds
                            G31 K0 P500 X0 Y18 Z7.50                                                       ; set Z probe trigger value, offset and trigger height (higher Z value = nozzle closer to bed)
                            ; Z microswitch (mechanical Z pin)
                            M558 K1 P8 C"io3.in" H1 R0 F600:180 T18000 A10 S0.005                          ; set Z probe type to switch and the dive height + speeds
                            G31 K1 P500 X0 Y0 Z0.0                                                         ; set Z probe trigger value, offset and trigger height (higher Z value = nozzle closer to bed)
                            ; Bed leveling
                            M671 X175:388:-38 Y416.6:1.5:1.5 S10                                           ; leadscrew locations (Rear, Right, Left)
                            M557 X25:315 Y25:325 P6                                                        ; define default mesh grid ( positions include the Z offset!)
                            ; Accelerometer
                            M955 P121.0 I05        ; configure accelerometer
                            M593 P"zvd" F49.3                                                              ; use ZVD input shaping to cancel ringing at 49.3Hz
                            ;  Heaters
                            ; Bed heater
                            ;M307 H0 R1.223 K0.599:0.000 D7.69 E1.35 S1.00 B0
                            ;M307 H0 B0 R0.750 C228.2 D3.40 S1.00 V0                                        ; Bed heater tuned for 85�C with 230v 750w heater
                            ;M308 S0 P"temp0" Y"thermistor" T104400 B4138 A"Bed"                            ; configure sensor 0 as thermistor on pin temp0
                            M308 S0 P"temp0" Y"thermistor" T100000 B3950 A"Bed"                            ; configure sensor 0 as thermistor on pin temp0
                            M950 H0 C"out0" T0 Q5                                                          ; create bed heater output on out0, map it to sensor 0 and set PWM frequency(Hz)
                            M307 H0 B0 S1.00                                                               ; disable bang-bang mode for the bed heater and set PWM limit
                            M140 H0        ; map heated bed to heater 0
                            M143 H0 S110        ; set temperature limit for heater 0 to 110�C
                            M143 H0 A2 C0 S110                                                             ; make sure bed heater stays below 110�C
                            M143 H0 A1 C0 S125                                                             ; make sure bed heater shuts down at 125�C
                            ; Hodend heater
                            M308 S1 P"121.temp0" Y"thermistor" T100000 B4725 C7.060000e-8 A"Hotend"        ; configure sensor 1 as thermistor on pin 121.temp0
                            M950 H1 C"121.out0" T1                                                         ; create nozzle heater output on 121.out0 and map it to sensor 1
                            M307 H1 B0 S1.00                                                               ; disable bang-bang mode for heater  and set PWM limit
                            M143 H1 S300        ; set temperature limit for heater 1 to 300�C
                            ; Chamber heater
                            M308 S4 P"121.temp1" Y"thermistor" T9600 B3950 A"Chamber"                      ; configure sensor 4 as thermistor on pin e1temp
                            ;M950 H2 C"out1" T4                                                            ; create a heater, but not actually anything connected to this output
                            ;M141 H2        ; map heated chamber to heater 2
                            ;M143 H2 S100        ; set temperature limit for heater 2 to 100�C
                            ;M141 S35        ; set chamber to 35�C (to avoid heater faults)
                            M308 S2 Y"mcu-temp" A"MCU"                                                     ; configure sensor 2 as MCU temperature
                            M912 P0 S-2.9        ; MCU temp calibration parameters
                            M308 S3 Y"drivers" A"DRIVERS"                                                  ; configure sensor 3 as drivers temperature
                            ;  Fans
                            ;Part cooling
                            M950 F0 C"121.out1" Q500                                                       ; create fan 0 on pin 121.out1 and set its frequency
                            M106 P0 S0 H-1 C"Part Cooling"                                                 ; set fan 0 value. Thermostatic control is turned off
                            ;Hotend fan
                            M950 F1 C"121.out2" Q500                                                       ; create fan 1 on pin 121.out2 and set its frequency
                            M106 P1 S1 H1 T45 C"Hotend Fan"                                                ; hotend fan @ 100%, turns on if temperature sensor 1 reaches 45�C
                            ;Electronics fan
                            M950 F2 C"out5" Q500                                                           ; create fan 2 on pin out3 and set its frequency
                            M106 P2 L0.15 H2:3 T45:50 C"Electronics Fans"                                  ; electronics fans start @ 30% when temperature sensor 2 reaches 45�C or sensor 3 (drivers report over temp)
                            ;M106 P2 H2:3 L0.15 X1 B0.3 T40:70                                             ; set fan 2 value, electronics cooling, starts to turn on when the MCU temperature(H2) reaches 45�C and reaches full speed when the MCU temperature reaches 70�C or if any TMC2660 drivers(H3) report that they are over-temperature.
                            ;Exhaust fan
                            M950 F3 C"out6" Q500                                                           ; create fan 3 on pin out4 and set its frequency
                            ;M106 P3 S1 H2 T75 Q500 C"Exhaust fan"                                         ; Exhaust fan @ 100%, turns on if temperature sensor 1 reaches 75�C
                            M106 P3 H-1 Q500 C"Exhaust fan"                                                ; Exhaust fan 3 value. Thermostatic control is turned off
                            M563 P0 S"Revo Micro" D0 H1 F0                                                 ; define tool 0
                            G10 P0 X0 Y0 Z0        ; set tool 0 axis offsets
                            G10 P0 R0 S0        ; set initial tool 0 active and standby temperatures to 0�C
                            ;  Other
                            ; Filament monitoring
                            ;M591 D0 P1 C"e0stop" S0                                                       ; filament monitor for extruder0, simple sensor (high signal when filament present), connected to e0stop and it's disabled
                            M950 P0 C"out2"        ; create output Port0 attached to out2 connector for LED lights
                            M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000"                             ; set voltage thresholds and actions to run on power loss
                            M572 D0 S0.0        ; Disable Pressure Advance
                            M98 P"/sys/lib/init.g"                                                         ; iniate external configs
                            M501        ; load config-override.g
                            T0        ; select tool 0
                            init.g:
                            ; /sys/lib/init.g
                            ; Called in the end of config.g
                            ; Used to setup more stuff during the boot process
                            M98 P"/sys/lib/globals.g"                                                      ; setup global variables
                            M98 P"/sys/lib/speed/speed_printing.g"                                         ; set normal speed & accel
                            M98 P"/sys/lib/current/xy_current_high.g"                                      ; set normal xy currents
                            M98 P"/sys/lib/current/z_current_high.g"                                       ; set normal z currents
                            M98 P"/sys/lib/fw_retraction.g"                                                ; set firmware retraction settings
                            M98 P"/sys/lib/klicky/klicky_status.g"                                         ; refresh klicky status
                            • Exerqtorundefined
                              Exerqtor @Exerqtor
                              globals.g:
                              ; /sys/lib/globals.g
                              ; Called by init.g
                              ; Used to initialize global variables
                              ; Global declarations and defaults values
                              ; Temperature
                              if !exists(global.bed_temp)
                                global bed_temp = 0
                              if !exists(global.hotend_temp)
                                global hotend_temp = 0
                              if !exists(global.chamber_temp)
                                global chamber_temp = 0
                              ; Stepper currents
                              if !exists(global.xy_current)
                                global xy_current = move.axes[0].current
                              if !exists(global.z_current)
                                global z_current = move.axes[2].current
                              if !exists(global.e_current)
                                global e_current = move.extruders[0].current
                              ; Mechanical Z pin
                              if !exists(global.z_pin_x)
                                global z_pin_x = 194
                              if !exists(global.z_pin_y)
                                global z_pin_y = 355.5
                              ; Klicky probe
                              ; Setup the klicky status
                              if !exists(global.klicky_status)
                                global klicky_status = "none"
                              ; The distance from the body of the klicky probe to it's own trigger point
                              if !exists(global.klicky_offset)
                                global klicky_offset = -1.49  ; a larger values makes the nozzle closer to the bed after running Z calibration
                              ; The Z distance from nozzle to bed surface
                              if !exists(global.klicky_clearance)
                                global klicky_clearance = 20 ; going lower than 8 will make the probe scary-close to the bed in most setups!
                              ; Dock settings:
                              ; The absolute X location of the klicky while docked
                              if !exists(global.klicky_dock_x)
                                global klicky_dock_x = 19.4
                              ; The absolute Y location of the klickywhile docked
                              if !exists(global.klicky_dock_y)
                                global klicky_dock_y = 356.4
                              ; The relative disance and direction of the klicky docking move
                              if !exists(global.klicky_wipe)
                                global klicky_wipe = 35  ; -30 for a left wipe 30 for a right wipe
                              ; Bed
                              ; Define the bed size on x-axis(print area from 0 to max)
                              if !exists(global.bed_x)
                                global bed_x = 350
                              ; Define the bed size on y-axis(print area from 0 to max)
                              if !exists(global.bed_y)
                                global bed_y = 350
                              ; If the bed has been leveled or not
                              if !exists(global.bed_leveled)
                                global bed_leveled = false
                              ; Print area
                              ; Setup the variables for min/max print area
                              if !exists(global.paMinX)
                                global paMinX = "N/A"
                              if !exists(global.paMaxX)
                                global paMaxX = "N/A"
                              if !exists(global.paMinY)
                                global paMinY = "N/A"
                              if !exists(global.paMaxY)
                                global paMaxY = "N/A"
                              ; MISC
                              if !exists(global.RunDaemon)
                                global RunDaemon = true
                              if !exists(global.initial_extruder)
                                global initial_extruder = 0
                              if !exists(global.first_layer_height)
                                global first_layer_height = "none"
                              ; The length needed to clear the meltzone of the extruder (as speced by E3D for the Revo)
                              if !exists(global.unload_length)
                                global unload_length = 18
                              if !exists(global.job_completion)
                                global job_completion = 0
                              if !exists(global.debug_mode)
                                global debug_mode = true
                              if !exists(global.chamber_leds)
                                global chamber_leds   = "off"
                              if !exists(global.sb_leds)
                                global sb_leds        = "boot"
                              if !exists(global.Z_cal)
                                global Z_cal          = false
                              if !exists(global.Print_Probe)
                                global Print_Probe = false
                              if !exists(global.Adaptive_Probing)
                                global Adaptive_Probing = false
                              if !exists(global.Adaptive_Purge)
                                global Adaptive_Purge = true
                              ; Output current values
                              echo "Klicky probe is: " , global.klicky_status
                              speed_printing.g:
                              ; /sys/lib/speed/speed_printing.g
                              ; called to set speed and accelerations settings for printing
                              xy_current_high.g:
                              ; /sys/lib/current/xy_current_high.g
                              ; Called when printing
                              ; Used to set X Y motor currents for printing
                              M913 X100 Y100        ; Set X Y motors to 100% of their max current
                              set global.xy_current = move.axes[0].current
                              z_current_high.g:
                              ; /sys/lib/current/z_current_high.g
                              ; Used to set Z motor currents for printing
                              M913 Z100        ; Set Z motors to 100% of their max current
                              set global.z_current = move.axes[2].current
                              fw_retraction.g & klickly_status.g aren't worth sharing since i've got filament specific retraction settings etc. and the status update is just what it sounds like.
                              But here is my filament config for ABS:
                              ; filaments/ABS/config.g  (v2.1)
                              ; called when M703 is sent and ABS is loaded
                              ; Settings section
                              ; Filament settings
                              var FilamentType        = "ABS"       ; Input the filament type (only for the message)
                              var Default             = false        ; Use default settings (retraction and PA), true/yes or false/no
                              var PA                  = 0.025        ; Pressure advance amount (s)
                              var RLen                = 0.400        ; Retraction length (mm)
                              var X_URLen             = 0.010        ; Extra unretract length (mm)
                              var RSpd                = 4200         ; Retraction speed (mm/min)
                              var URSpd               = 4200         ; Unretract speed (mm/min)
                              var Z_Lift              = 0.200        ; Zlift amount (mm)
                              ; Message placeholders
                              var Message1 = "N/A"
                              var Message2 = "N/A"
                              ; Config section
                              if !var.Default
                                ; Pressure Advance
                                M572 D0 S{var.PA}                                                            ; Set extruder 0 pressure advance to 0.1 seconds
                                ;Retraction & Zlift
                                M207 S{var.RLen} R{var.X_URLen} F{var.RSpd} T{var.URSpd} Z{var.Z_Lift}       ; Set firmware retraction length, extra un-retract lenght, retract speed, unretract speed & zlift
                                ; Travel & acceleration
                                ;M204 P800 T3000                                                             ; Set printing and travel accelerations (mm/s²)
                                ;Cancel Ringing (Ghosting)
                                ;M593 P"none" F50                                                            ; Cancel ringing at 50Hz
                              ; Define & send messages
                              if var.Default
                                set var.Message1 = "" ^ var.FilamentType ^ " config applied (default settings)"
                              else
                                set var.Message1 = "" ^ var.FilamentType ^ " config applied"
                              if move.extruders[0].pressureAdvance = 0
                                set var.Message2 = "Pressure Advance disabled"
                              else
                                set var.Message2 = "Pressure Advance set to " ^ move.extruders[0].pressureAdvance ^ " seconds"
                              ; Config applied message
                              M118 P0 S{var.Message1}                                                        ; Send message to DWC
                              M118 P2 S{var.Message1}                                                        ; Send message to PanelDue
                              ; Pressure advance info message
                              M118 P0 S{var.Message2}                                                        ; Send message to DWC
                              M118 P2 S{var.Message2}                                                        ; Send message to PanelDue
                              • Exerqtorundefined
                                Exerqtor @Exerqtor
                                This is what my custom start gcode on PS looks like:
                                ; Start G-code: START
                                ; Inform of first layer height
                                set global.first_layer_height = {first_layer_height}
                                ; Define print area
                                set global.paMinX = {first_layer_print_min[0]}
                                set global.paMaxX = {first_layer_print_max[0]}
                                set global.paMinY = {first_layer_print_min[1]}
                                set global.paMaxY = {first_layer_print_max[1]}
                                ; Set temps & the initial extruder
                                set global.bed_temp = [first_layer_bed_temperature]
                                set global.hotend_temp = {first_layer_temperature[initial_extruder]}
                                set global.initial_extruder = [initial_extruder]
                                M83        ; use relative distances for extrusion
                                M98 P"/sys/lib/print/print_start.g"                                            ; run print start routine
                                ; Start G-code: END
                                print_start.g:
                                ; /sys/lib/print/print_start.g
                                ; Called when starting a print
                                ; Used to configure print parameters
                                ;LED status
                                set global.sb_leds = "heating"
                                set global.job_completion = 0
                                G21        ; set units to millimeters
                                G90        ; use absolute coordinates
                                M220 S100        ; reset speed multiplier
                                M140 S{global.bed_temp}                                                        ; set bed temperature
                                ;M141 S{global.chamber_temp}                                                   ; set chamber temperature
                                G10 P{global.initial_extruder} R{global.hotend_temp} S{global.hotend_temp}     ; set active and standby temps for the initial tool
                                M116        ; wait for bed and hotend to reach there temperatures
                                M42 P0 S0.3        ; Turn on chamber lights to 30%
                                M98 P"/sys/lib/print/print_level_bed.g"                                        ; level the bed while everything is hot
                                G29 S1        ; load & turn on bed height map
                                M376 H5        ; set bed compensation taper to 5mm
                                T{global.initial_extruder}                                                     ; select initial tool
                                M98 P"/sys/lib/nozzle_scrub.g"                                                 ; clean the nozzle
                                G1 X{global.z_pin_x} Y{global.z_pin_y - 60} F6000                              ; Move out on the printbed
                                G0 Z{(global.first_layer_height + 5)} F3000                                    ; Drop bed to first layer height + 5mm to reduce pucker factor
                                M98 P"/sys/lib/print/print_purge.g"                                            ; purge the nozzle before starting print
                                M400        ; wait for moves to finish
                                ;LED status
                                set global.sb_leds = "printing"
                                print_level_bed.g:
                                ; /sys/lib/print/print_level_bed.g
                                ; Called as part of print_start.g
                                ; Used to make sure the bed is leveled
                                ; homing check
                                  ; Lower currents, speed & accel
                                  M98 P"/sys/lib/current/xy_current_low.g"                                       ; Set low XY currents
                                  M98 P"/sys/lib/current/z_current_low.g"                                        ; Set low Z currents
                                  M98 P"/sys/lib/speed/speed_probing.g"                                          ; Set low speed & accel
                                ; Make sure all axes are Homed
                                if !move.axes[0].homed || !move.axes[1].homed || !move.axes[2].homed           ; If axes aren't homed
                                  ; Home all axis
                                  G91        ; Relative positioning
                                  ; Lower Z relative to current position if needed
                                  if !move.axes[2].homed                                                         ; If Z ain't homed
                                    G1 Z20 F9000 H1                                                              ; Lower Z(bed) relative to current position
                                  elif move.axes[2].userPosition < 10                                            ; If Z is homed and less than 10
                                    G1 Z20 F9000        ; Move to Z 10
                                  ; Coarse home X or Y
                                  G1 X600 Y600 F2400 H1                                                          ; Move quickly to X or Y endstop(first pass)
                                  ; Coarse home X
                                  G1 X600 H1        ; Move quickly to X endstop(first pass)
                                  ; Coarse home Y
                                  G1 Y600 H1        ; Move quickly to Y endstop(first pass)
                                  ; Move away from the endstops
                                  G1 X-5 Y-5 F9000                                                               ; Go back a few mm
                                  ; Fine home X
                                  G1 X600 F360 H1        ; Move slowly to X axis endstop(second pass)
                                  ; Fine home Y
                                  G1 Y600 H1        ; move slowly to Y axis endstop(second pass)
                                  ; Absolute positioning
                                  G90        ; Absolute positioning
                                  ; Home Z
                                  ; Load the probe
                                  M401 P0        ; Load the klicky probe
                                  M400        ; Wait for moves to finish
                                  M98 P"/sys/lib/klicky/klicky_status.g"                                         ; Refresh klicky status
                                  ; Last check to ensure klicky is attached
                                  if global.klicky_status = "attached"
                                    echo "Probe ATTACHED"
                                  else
                                    echo "Error probe not attached - aborting"
                                    M291 T5 R"Z Homing Aborted!" P"Z haven't been homed - check probe"
                                    abort
                                  ; Move to bed center and home Z
                                  M98 P"/sys/lib/goto/bed_center.g"                                              ; Move to bed center
                                  G30 K0 Z-99999        ; Probe the center of the bed
                                else
                                  ; Home Z
                                  ; Load the probe
                                  else
                                    abort
                                ; check if bed is leveled
                                ; If the bed isn't leveled
                                if global.bed_leveled = false
                                  ;LED status
                                  set global.sb_leds = "leveling"
                                  ; prepare to probe
                                  ; report whats going on
                                  M291 R"Bed leveling" P"Please wait..." T0                                    ; leveling bed message
                                  M561        ; clear any bed transform
                                  M290 R0 S0        ; reset baby stepping
                                  M84 E0        ; disable extruder stepper
                                  ; probing code
                                  ; Coarse leveling pass
                                  M558 K0 H15 F600 A1                                                          ; increase the depth range, gets the bed mostly level immediately
                                  M98 P"/sys/bed_probe_points.g"                                               ; probe the bed
                                  ; Probe the bed
                                  while true
                                    ; --- probe near lead screws -
                                    M558 K0 H3 F240:120 A30                                                    ; reduce depth range, probe slower for better repeatability
                                    ; check results - exit loop if results are good
                                    if move.calibration.initial.deviation < 0.02                               ; if probing result is less than 0.02mm
                                      break        ; stop probing
                                    ; check pass limit - abort if pass limit reached
                                    if iterations = 5                                                          ; if probed more than 5 times
                                      M291 P"Bed Leveling Aborted" R"Pass Limit Reached"                       ; abort probing, something wrong
                                      set global.bed_leveled = false                                           ; set global state
                                      abort "Bed Leveling Aborted - Pass Limit Reached"                        ; abort probing, something wrong
                                  ; finish up
                                  ; Home Z
                                  ; Dock the probe
                                  M402 P0        ; Dock the klicky probe
                                  set global.bed_leveled = true                                                ; set global state
                                  ;echo "global.bed_leveled. Value : " , global.bed_leveled
                                  M291 R"Bed leveling" P"Done" T5                                              ; bed leveling done message
                                else
                                  ; response if leveled
                                  ; Dock the probe
                                  ; Bed already leveled, no need to probe
                                  M291 S1 R"Bed leveling" P"Bed allready leveled" T1
                                ;LED status
                                set global.sb_leds = "ready"
                                • Exerqtorundefined
                                  Exerqtor @Exerqtor
                                  nozzle_scrub.g:
                                  ; /sys/lib/nozzle_scrub.g  (v2.5)
                                  ; Called when "M98 P"/sys/lib/nozzle_scrub.g" is sent
                                  ; Used to clean and (alternatively) purge the nozzle
                                  ; Sample macro config to be used in conjunction with a Purge Bucket & Nozzle Scrubber combo and RepRapFirmware 3.4.x
                                  ; The goal of this macro is to provide a nozzle scrubbing and purging routine that is easily copied/referenced into your  printer.
                                  ; Users can simply change parameters and enable/disable options in the first half. Descriptions are plentiful, making this macro
                                  ; look huge but informative and are laid out in sequence to be read first describing the line below; PLEASE READ CAREFULLY.
                                  ; This sample config assumes the following: The user has implemented a purge bucket & nozzle scrubber to their printer
                                  ; It can be tweaked for customized purge bucket geometries and brushes.
                                  ; Features in this macro: purge routine that can be enabled/disabled.
                                  ; By default, bucket is located at rear right of bed and purge routine is enabled. The purge and scrubbing routine is randomized
                                  ; in either left or right bucket to ensure as even as possible distribution of filament gunk.
                                  ; Default parameters are set for safe speeds and movements. Where necessary, tweak the parameters for the nozzle scrub procedure
                                  ; to fit your printer.
                                  ; If you want the purging routine in your bucket enabled, set to true (and false vice versa).
                                  var enable_purge        = false
                                  ; These parameters define your filament purging. The retract variable is used to retract right after purging to prevent unnecessary
                                  ; oozing. Some filament are particularly oozy and may continue to ooze out of the nozzle for a second or two after retracting. The
                                  ; ooze dwell variable makes allowance for this. Update as necessary. If you decided to not enable purge, you can ignore this section.
                                  var purge_len           = 10         ; Amount of filament, in mm, to purge.
                                  var purge_spd           = 150        ; Speed, in mm/min, of the purge.
                                  var purge_temp_min      = {global.hotend_temp - 5}        ; Minimum nozzle temperature to permit a purge. Otherwise, purge will not occur.
                                  var purge_ret           = 2          ; Retract length, in mm, after purging to prevent slight oozing. Adjust as necessary.
                                  var ooze_dwell          = 2          ; Dwell/wait time, in seconds, after purging and retracting.
                                  ; Adjust this so that your nozzle scrubs within the brush. Currently defaulted to be a lot higher for safety. Be careful not to go too low!
                                  var brush_top           = 1
                                  ; These parameters define your scrubbing, travel speeds, safe z clearance and how many times you want to wipe. Update as necessary. Wipe
                                  ; direction is randomized based off whether the left or right bucket is randomly selected in the purge & scrubbing routine.
                                  var clearance_z         = 5          ; When traveling, but not cleaning, the clearance along the z-axis between nozzle and brush.
                                  var wipe_qty            = 3          ; Number of complete (A complete wipe: left, right, left OR right, left, right) wipes.
                                  var prep_spd_xy         = 3000       ; Travel (not cleaning) speed along x and y-axis in mm/min.
                                  var prep_spd_z          = 1500       ; Travel (not cleaning) speed along z axis in mm/min.
                                  var wipe_spd_xy         = 5000       ; Nozzle wipe speed in mm/min.
                                  ; These parameters define the size of the brush. Update as necessary. A visual reference is provided below. Note that orientation of
                                  ; parameters remain the same whether bucket is at rear or front.
                                  ;                  ?   brush_width   ?
                                  ;                   _________________
                                  ;  brush_start (x) |                 | brush_depth
                                  ;                  |_________________|  ?
                                  ;                          (y)
                                  ;                      brush_front
                                  ;__________________________________________________________
                                  ;                     PRINTER FRONT
                                  ; Input where your brush assembly start is on the x axis
                                  var brush_start         = 237
                                  ; This value is for the brush width (with brush holder), change it if your brush setup width is different.
                                  var brush_width         = 50
                                  ; Specify the location in y axis for your brush - see diagram above.
                                  var brush_front         = 353
                                  var brush_depth         = 8
                                  ; These parameters define the size of your purge bucket. Update as necessary. If you decided to not enable purge, you can ignore
                                  ; this section. A visual reference is provided below. Note that orientation of parameters remain the same whether bucket is at rear
                                  ; or front.
                                  ;                                     bucket_gap
                                  ;                     __________________________________________
                                  ;  bucket_start (x)  |                 |______|                 |
                                  ;                    |_________________|. . . |_________________|
                                  ;                     bucket_left_width        bucket_right_width
                                  ;_______________________________________________________________________________________
                                  ;                                    PRINTER FRONT
                                  ; Input your left bucket width
                                  var bucket_left_width   = 23.5
                                  ; Input your gap width
                                  var bucket_gap          = 25
                                  var bucket_right_width  = 35.5
                                  ; Input where your bucket start is on the x axis
                                  var bucket_start        = 219
                                  ; From here on, unless you know what you're doing, it's recommended not to change anything. Feel free to peruse the code if you stumble apon it
                                  ; and reach out to me on Discord (Exerqtor#3178) or the duet forum (Exerqtor) if you spot any problems, or have any sugestions for improvements!
                                  ; Shout-out to "fcwilt" on the duet forum for helping me with ironing out bugs and streamlining the macro! <3
                                  ; Placeholder. The variable wil later be set to contain the overhang for the brush assembly in the buckets
                                  var brush_oh            = 0
                                  ; Brush overhang calculation:
                                  set var.brush_oh = {(var.brush_width - var.bucket_gap) / 2}
                                  ; Placeholder. The variable will later be set to contain, at random, a number representing the left(0) or right(1) side
                                  var pos                 = 1
                                  ; Randomly select left or right side
                                  set var.pos = random(2)
                                  ; Check if the axes are homed - if not homed just abort - it exits this routine and none of the rest of the code is executed
                                    M291 R"Axes not homed" P"Please home all axes first!" T0
                                    abort "nozzle_scrub.g aborted - axes were not homed"
                                  ;LED status
                                  set global.sb_leds = "cleaning"
                                  ; Report what's going on
                                  M291 S1 R"Cleaning nozzle" P"Please wait..." T5
                                  ; Set to absolute positioning.
                                  G90
                                  ; purging code
                                  ; Check if user enabled purge option or not.
                                  if var.enable_purge
                                    ; If hotend needs to be loaded, to it now (at 2x purge_spd).
                                    if exists(global.unload_length)
                                      if global.unload_length > 0
                                        G1 E{global.unload_length + 0.5} F{var.purge_spd * 2}
                                        echo "Hotend loaded"
                                    ; Purge if the temp is up to min temp. If not, it will skip and continue executing rest of macro.
                                    if heat.heaters[1].current > var.purge_temp_min
                                        echo "Purging"
                                      ; Raise Z for travel.
                                      G1 Z{var.brush_top + var.clearance_z} F{var.prep_spd_z}
                                      ; Move towards brush.
                                      G1 Y{var.brush_front + (var.brush_depth / 2)} F{var.prep_spd_xy}
                                      ; Position for purge. Randomly selects middle of left or right bucket. It references from the middle of the left bucket (while compensating for any brush overhang).
                                      if var.pos = 0
                                        ; Left bucket selected
                                        G1 X{var.bucket_start + ((var.bucket_left_width - var.brush_oh) / 2)}
                                      else
                                        ; Right bucket selected
                                        G1 X{(var.bucket_start + var.bucket_left_width) + (var.bucket_gap + var.brush_oh) + ((var.bucket_right_width - var.brush_oh) / 2)}
                                      ; Perform purge with a small retract after purging to minimize any persistent oozing at (retract 5x purge_spd).
                                      M83        ; relative mode
                                      G1 E{var.purge_len} F{var.purge_spd}
                                      G1 E{0 - var.purge_ret} F{var.purge_spd * 5}
                                      G4 S{var.ooze_dwell}
                                      G92 E0        ; reset extruder
                                    else
                                      echo "To cold to purge"
                                  ; wiping code
                                  ; Placeholders
                                  var pos1                = 0
                                  var pos2                = 0
                                  ; Position for wipe. Either left or right of brush based on var.pos to avoid unnecessary travel after purging
                                  if var.pos = 0
                                    set var.pos1 = var.brush_start
                                    set var.pos2 = var.brush_start + var.brush_width
                                  else
                                    set var.pos1 = var.brush_start + var.brush_width
                                  G1 X{var.pos1} F{var.prep_spd_xy}
                                  ; Move in to the brush.
                                  ; Move nozzle down into brush.
                                  G1 Z{var.brush_top} F{var.prep_spd_z}
                                  ; Perform wipe. Wipe direction based off pos for cool random scrubby routine.
                                  while true
                                    G1 X{var.pos2} F{var.wipe_spd_xy}
                                    G1 X{var.pos1}
                                    if iterations = var.wipe_qty + 1
                                      break
                                  ; finish up
                                  ; Clear from area.
                                  G1 X{var.bucket_start + ((var.bucket_left_width - var.brush_oh) / 2)} F{var.prep_spd_xy}
                                  M118 S"Nozzle cleaned!"
                                  ;LED status
                                  print_purge.g:
                                  ; /sys/lib/print/print_purge.g  (v1.2)
                                  ; Called when "M98 P"/sys/lib/print/print_purge.g" is sent
                                  ; Used to purge the nozzle close to the actual print area
                                  ;  Adaptive Purging with VoronDesign Logo for RepRapFirmware 3.4.x
                                  ; This macro will parse information from objects in your gcode to define a min and max area, creating a nearby purge with Voron flair!
                                  ; For successful purging, you may need to configure:
                                  ; Declare global.unload_length, and define what length it's needed to be.
                                  ; Declare global.Adpative_Purge,and set it true
                                  ; Declared globals for X/Y min/max, and have these to defined in your slicer.
                                  ; Variable declarations & defaults
                                  ; To enable adaptive purging "global.Adaptive_Purging" must be declared and true.
                                  var z_height              = 0.4                            ; Height above the bed to purge
                                  var prime_dist            = {global.unload_length + 1}     ; Distance between filament tip and nozzle tip before purge (this might require some tuning)
                                  var purge_amount          = 20                             ; Amount of filament to purge
                                  var flow_rate             = 10                             ; Desired flow rate in mm3/s
                                  var x_default             = 10                             ; X location to purge, overwritten if adaptive is True
                                  var y_default             = 10                             ; Y location to purge, overwritten if adaptive is True
                                  var size                  = 10                             ; Size of the logo in mm
                                  var distance_to_object_x  = 15                             ; Distance in x to the print area
                                  var distance_to_object_y  = 0                              ; Distance in y to the print area
                                  var travel_speed          = 300                            ; Travel speed
                                  ; Placeholders:
                                  var x_origin = "N/A"
                                  var y_origin = "N/A"
                                  var consoleMessage = "N/A"
                                  ; Purge location calculation
                                  if global.Adaptive_Purge
                                    set var.x_origin = {global.paMinX - var.distance_to_object_x - var.size}
                                    set var.y_origin = {global.paMinY - var.distance_to_object_y - var.size}
                                  else
                                    set var.x_origin = var.x_default
                                    set var.y_origin = var.y_default
                                  var prepurge_speed = (var.flow_rate / 2.405)
                                  var purge_move_speed = {2.31 * var.size * var.flow_rate / (var.purge_amount * 2.405)}
                                  ; Info messages
                                  set var.consoleMessage = "X: " ^ var.x_origin ^ "; Y: " ^ var.y_origin ^ "; Purge move speed: " ^ var.purge_move_speed ^ "; Prepurge speed: " ^ var.prepurge_speed  ; Set the console message
                                  M118 P2 S{var.consoleMessage}  ; send used probe grid to paneldue
                                  M118 P3 S{var.consoleMessage}  ; send used probe grid to DWC console
                                  ; Purging code
                                  ; LED status
                                  set global.sb_leds = "pink"
                                  G92 E0
                                  G0 F{var.travel_speed * 60}        ; Set travel speed
                                  G0 X{var.x_origin} Y{var.y_origin + var.size / 2}        ; Move to purge position
                                  G0 Z{var.z_height}        ; Move to purge Z height
                                  M83        ; Relative extrusion mode
                                  G1 E{var.prime_dist} F{var.prepurge_speed * 60}        ; Move tip of filament to nozzle
                                  G1 X{var.x_origin + var.size * 0.289} Y{var.y_origin + var.size} E{var.purge_amount / 4} F{var.purge_move_speed * 60}  ; Purge first line of logo
                                  G1 E-.5 F2100        ; Retract
                                  G0 Z{var.z_height * 2}        ; Z hop
                                  G0 X{var.x_origin + var.size * 0.789} Y{var.y_origin + var.size}                                                       ; Move to second purge line origin
                                  G1 E.5 F2100        ; Recover
                                  G1 X{var.x_origin + var.size * 0.211} Y{var.y_origin} E{var.purge_amount / 2} F{var.purge_move_speed * 60}             ; Purge second line of logo
                                  G0 X{var.x_origin + var.size * 0.711} Y{var.y_origin}        ; Move to third purge line origin
                                  G1 X{var.x_origin + var.size} Y{var.y_origin + var.size / 2}  E{var.purge_amount / 4} F{var.purge_move_speed * 60}     ; Purge third line of logo
                                  G92 E0        ; Reset extruder distance
                                  ; LED status
                                  Good luck sifting thru all that, had to split it up in several posts lol.
                                  But like i said, i checked the object modell during last print, and all the values seemed correct 😕
                                    It'll take me some time to go through that.
                                    Do you happen to use input shaping? Pressure advance?
                                    • Exerqtorundefined
                                      Exerqtor @Phaedrux
                                      It's alot 🤢
                                      Yeah input shaping gets defined in config.g M593 P"zvd" F49.3
                                      Pressure advance get set in filament config.g M572 D0 S0.025.
                                      Exerqtorundefined 1 Reply Last reply Reply Quote 1
                                      • Exerqtorundefined
                                        Exerqtor @Exerqtor
                                        Just simulated AND printed another file, estimated 1h7m, simulated 1h32m, printed 1h31m (with preheated bed and hotend).
                                        I'm lost...
                                        Another one:
                                        Estimated 0h21m, simulated 0h26m, printed 0h31m.
                                          @Exerqtor did you see my earlier post? User n8bot has made modifications to PS to make the estimates more accurate for RRF. Part of this is a facility to fetch the maximum speeds and accelerations from RRF. https://github.com/n8bot/PrusaSlicer/releases
                                          • Exerqtorundefined
                                            Exerqtor @dc42
                                            Yeah i did 😅 :
