    tuning 2 heaters
    988
    • ardisfundefined
      ardisf
      is it possible to tune 2 heaters at the same time?
        jay_s_uk @ardisf
        @ardisf if they're on the same tool or bed then yes, if they are separate hotends etc, then no
        ardisfundefined 1 Reply Last reply Reply Quote 0
        • ardisfundefined
          ardisf @jay_s_uk
          @jay_s_uk said in tuning 2 heaters:
          my hotend using 2 heaters at H1 and H2, so is it possible to tune them at the same time?
            jay_s_uk @ardisf
            @ardisf Tune as a tool rather than a heater (assuming you've mapped both heaters in M563)
            M303 T0 S240 as an example
            ardisfundefined 1 Reply Last reply Reply Quote 1
            • ardisfundefined
              ardisf @jay_s_uk
              i've define H0 and H1 at tool 0, should i define them at new tool (T1) or i can execute using T0?
                jay_s_uk @ardisf
                @ardisf you've assigned them correctly, just tune as T0
                ardisfundefined 2 Replies Last reply Reply Quote 1
                • ardisfundefined
                  ardisf @jay_s_uk
                  @jay_s_uk thank you
                  • ardisfundefined
                    ardisf @jay_s_uk
                    @jay_s_uk
                    i've sent M303 T0 S240, but only H1 is tuning and H2 is off like the picture above
                      jay_s_uk @ardisf
                      @ardisf thats strange and not the behaviour I expected to happen but thinking about it, it may be due to heater parameters being stored per heater rather than by tool. so maybe the answer is actually this isn't currently supported and a feature request needs to be made?
                      Maybe @Phaedrux or @droftarts can confirm
                      • ardisfundefined
                        ardisf @jay_s_uk
                        pardon me i've mention the wrong picture. this one is the correct one
                        deckingmanundefined 1 Reply Last reply Reply Quote 1
                        • deckingmanundefined
                          deckingman @ardisf
                          @ardisf I wrote a post about this some time back wherein I detailed a strategy that has worked well for me. Unfortunately I'm 10,000 miles away from home with only my phone to hand, otherwise I would have posted a link to the thread, but a search for "tuning multiple heat zones" or some such should get you there.
                            jay_s_uk
                            this is the thread @deckingman is referring to https://forum.duet3d.com/topic/26910/strategy-for-pid-tuning-multiple-heat-zones
                            • ardisfundefined
                              ardisf @deckingman
                              @deckingman @jay_s_uk tysm
                                jay_s_uk @ardisf
                                @ardisf what hotend are you using? Are both heaters in the same block?
                                • ardisfundefined
                                  ardisf @jay_s_uk
                                  i used custom hotend for pellet extruder and i put both heaters in the same block
                                  btw, i've tried the procedure of deckingman's thread, he said in Strategy for PID tuning multiple heat zones:
                                  The first step was to tune each individual heater to get some sort of PID "model" as a starting point.
                                  but what if my secondary heater can't be tuned and sent me "Auto tune cancelled because target temperature was not reached"? i used cartridge heater 24v 40w, is it enough?
                                    jay_s_uk @ardisf
                                    @ardisf rather than creating 2 heaters individually, as long as you're on 3.4 or later, you can map 2 outputs to one heater e.g. M950 H1 C"3.out0+out2" T1
                                    maybe give that a go and see if you can tune the hotend that way?
                                    • ardisfundefined
                                      ardisf @jay_s_uk
                                      like this?
                                        jay_s_uk @ardisf
                                        @ardisf yes but obviously you need to change the outputs to where they're actually wired to
                                        • ardisfundefined
                                          ardisf @jay_s_uk
                                          @jay_s_uk i used e0 heater and e1 heater as an output, what should i write on the config?
                                            jay_s_uk @ardisf
                                            @ardisf e0heat+e1heat
