    How well does the RPi Zero 2W work with the Duet3 mini5+?
    • 0nn0undefined
      0nn0
      I have a printer which I'd like to use with the Duet 3 mini5+.
      I'm kind of new to the Duet ecosystem. I'd like to know if the Raspberry Pi Zero 2W is a suitable SBC for this controller board. The Pi4 is a bit too Can I use the camera header to attach a pi camera?
      The tread about the Pi Zero 2W (https://forum.duet3d.com/topic/25730/new-raspberry-pi-zero-2w) went a bit off-topic and didn't really provide an answer to this question.
      droftartsundefined o_lampeundefined 2 Replies Last reply Reply Quote 0
        droftarts administrators @0nn0
        @0nn0 I think @o_lampe had a Z2W working; see https://forum.duet3d.com/post/257109
        However, it has the same processor as an RPi 3B, so performance is on the same level as that.
        • o_lampeundefined
          o_lampe @0nn0
          @0nn0
          I only benchmarked the Z2W and it was on par with RPi3b.
          Without GUI the available memory is suitable for SBC use, I guess.
          Everytime I wanted to test SBC setup for Duets, some threads here told me, it's not worth the extra hassle (yet)
          You'd need a PC to connect remotely to the SBC; no advantage here either.
          • 0nn0undefined
            0nn0
            @o_lampe So if I understand you correctly, the RAM shortage is the problem here?
            • o_lampeundefined
              o_lampe @0nn0
              @0nn0
              I don't know if the RRF-SBC firmware needs the GUI? Then there might be problems.
              But a classic Linux distribution probably is more RAM hungry than the RRF branch....so maybe it's no issue at all.
              As I said, I never bothered to install RRFs SBC version.
              Others please chime in here with free RAM numbers on their SBC?
                jay_s_uk
                i've ran RRF on a fly-gemini-v1 and that only has 512Mb of ram.
                I had to run it without a gui though as 512Mb wasn't enough for a desktop
