New Raspberry Pi Zero 2W
https://www.raspberrypi.com/products/raspberry-pi-zero-2-w/
now it should be possible to run DSF with the Pi Zero
@pcr I liked the idea of a tiny SBC in the past, but they always ended up in a pile of cables and extra-adapters (active USB hub etc)
What would be the recommended shopping list for this board running a HDMI screen and keyboard/mouse?//edit How about running a slicer on it?
@pcr I wonder if 512mb is enough ram???
@jay_s_uk said in New Raspberry Pi Zero 2W:
[OT] On my Odroid headless MCU cluster I defined 1GB RAM of each MCU as Ram-disk and the Head-MCU could access them as Swap-drive. This way I had +8GB swap drive with network read/write speed (1GBit LAN).
Maybe we can install a swap-drive here with USB-speed (SSD?)
//edit there's an official RPi eMMC_to_SD-card with 32GB, might be a good compromise? -
RP3A0, a custom-built system-in-package designed by Raspberry Pi in the UK
I wonder what interesting yet to be discovered kernel/driver "features" lie in wait heredefinitely worth giving it a go though!
How much free RAM does a RPi 3 or 4 show after DSF has booted?
@o_lampe On DuetPi:
pi@duet3:~ $ free -h total used free shared buff/cache available Mem: 3.7Gi 342Mi 2.9Gi 58Mi 511Mi 3.2Gi Swap: 99Mi 0B 99Mi
On DuetPi-lite (no GUI):
pi@Ender3Pro ~> free -h total used free shared buff/cache available Mem: 1.8Gi 128Mi 1.5Gi 8.0Mi 175Mi 1.6Gi Swap: 99Mi 0B 99Mi
Both are running on two different RPi 4s. I suspect some more RAM could be saved by turning off some more system services (like bluetooth and pulseaudio).
@chrishamm Even in GUI mode it only takes ~350MB, that should work with the Zero 2W. But slicing is a different story.
Don't want to highjack the thread, but while shopping in the raspberry shop, I saw the RP2040 aka. Raspberry Pi Pico.
It has a very low price and comes with a Cortex M0 MCU. I wonder if it would work as Arduino nano replacement, or even better as a mini toolboard MCU? -
@o_lampe said in New Raspberry Pi Zero 2W:
On that off-topic subject
I've been playing with some Seeed Xiao boards - again an M0 CPU with 256K flash, 32K RAM. About £5 on ebay and minuscule things, 17x20mm. Info:
https://wiki.seeedstudio.com/Seeeduino-XIAO/I'd not thought of them in relation to 3D printing, but for a small, light auxiliary interface, they should be good.
mini toolboard MCU?
if someone wrote the code to use one of the pico processor cores to simulate CAN-FD fast enough then just maybe but that could well be impossible.
@t3p3tony
I tried to find a Pico board with Sam-C21 and CAN-FD.
As Toolbord in the classic sense is difficult, but it could do some light duty chores, like extra fans, thermistors or other less timing relevant things. -
@o_lampe i see using it as a coprocessor. There could be applications for a coprocessor (maybe not so much a toolboard but on a mainboard) but it adds significantly to the complexity of many things (think a firmware update).
@t3p3tony said in New Raspberry Pi Zero 2W:
I'd happily go that extra mile, if it helps the huge Duet2-community "over the hump" and enables it to benefit from future development.
The M0 processor has ~twice the power of the onboard MCU. If we'd use the onboard MCU as gateway and the M0 as mainprocessor, it would be a huge leap forward. (just dreaming) -
@o_lampe I don't understand exactly what you are proposing? what would the board with the pico do? how would it communicate (and what hump are we getting over?)
@t3p3tony the M0 could do the multi-stream gcode analysis, while the onboard MCU does the pulse-generating for steppers, PWM a.s.o.
The hump is the limited RAM of the duet2 mcu -
@t3p3tony
I tried to find a Pico board with Sam-C21 and CAN-FD.See https://duet3d.dozuki.com/Wiki/Using_the_Sammy-C21_development_board_with_Duet_3.
@dc42 I know the board, but it's out off stock and quite expensive. (27EUR vs 4EUR)
But I'd still consider it as Duet2 CoPro as described above.@T3P3Tony I wouldn't mind to delete the last posts and start a new thread, although everything I posted about the M0 is IMHO also valid for the Zero 2W and any other SBC
@pcr nice! why the two different headers, one for Duet 3 and one for the 3 mini?
@t3p3tony yes. I dont want to Stack in diectly on the Board. Because of some connectors. And yes the Header is placed diffrently on duet 3 and Duet Mini ;(
@pcr btw someone from Germany who Likes to Test the Board ?
How about a duet controller board with a plugged in Pi Zero for both controller and SBC functionalities?
Edit: or a Pi Zero and a minimal MCU for i/o only, basically a Klipper style RRF on a single board.
@pcr said in New Raspberry Pi Zero 2W:
Ich habe heute einen Zero 2W bestellt, aber ich habe weder Duet3 oder Mini5+.
Vielleicht @cosmowave ?English: I've ordered a Z2W, but don't have duet3 nor Mini5...maybe Cosmowave?
pi@raspberrypi:~ $ neofetch `.::///+:/-. --///+//-:`` pi@raspberrypi `+oooooooooooo: `+oooooooooooo: -------------- /oooo++//ooooo: ooooo+//+ooooo. OS: Raspbian GNU/Linux 10 (buster) armv7l `+ooooooo:-:oo- +o+::/ooooooo: Host: Raspberry Pi Zero 2 Rev 1.0 `:oooooooo+`` `.oooooooo+- Kernel: 5.10.63-v7+ `:++ooo/. :+ooo+/.` Uptime: 10 mins ...` `.----.` ``.. Packages: 533 (dpkg) .::::-``:::::::::.`-:::-` Shell: bash 5.0.3 -:::-` .:::::::-` `-:::- Terminal: /dev/pts/0 `::. `.--.` `` `.---.``.::` CPU: BCM2835 (4) @ 1.000GHz .::::::::` -::::::::` ` Memory: 49MiB / 427MiB .::` .:::::::::- `::::::::::``::. -:::` ::::::::::. ::::::::::.`:::- :::: -::::::::. `-:::::::: :::: -::- .-:::-.``....``.-::-. -::- .. `` .::::::::. `..`.. -:::-` -::::::::::` .:::::` :::::::` -::::::::::` :::::::. .::::::: -::::::::. :::::::: `-:::::` ..--.` ::::::. `...` `...--..` `...` .:::::::::: `.-::::-` pi@raspberrypi:~ $ ls /opt/dsf/sd filaments firmware gcodes macros menu sys www
