3.5 beta1 print not starting
Hello
After 3.5b1 update, it hangs after home process and print doesn't start...
How to downgrade please ?
Thanks -
@Touchthebitum does your home process include using G32 to perform true bed levelling? If so, see https://forum.duet3d.com/post/303514.
@dc42 No, the problem stands when I run a print. Home is ok and then it freezes. PanelDue indicates printing.... I tried your update but it doesn't work.
@Touchthebitum to clarify: are you saying that your homing process does not run G32? The G32 bug did not always cause an immediate reset.
@dc42 No, my homing process doesn't run G32.
@Touchthebitum thanks. When the machines hangs while trying to start a print, are you able to send M122 and get a report back?
The instructions for rolling the firmware back were linked to in my original post announcing the new release. Here is a copy of that link: https://docs.duet3d.com/en/User_manual/Machine_configuration/DSF_RPi#switch-to-unstable-packages.
@dc42 thanks
