    No IP address after updating from config tool Mini 5+ Ethernet
    469
    • chrishammundefined
      chrishamm administrators @prcdslnc13
      @prcdslnc13 Can you share your config.json or the file provided by "Download JSON template" on the last page?
      Duet software engineer
      prcdslnc13undefined 1 Reply Last reply Reply Quote 0
      • prcdslnc13undefined
        prcdslnc13 @chrishamm
        @chrishamm config.json
        @Phaedrux correct. The only way I have been able to get it to show up is by forcing the IP. DHCP has not worked since updating.
          Can you try M552 S1 P0.0.0.0 in config.g?
            prcdslnc13 @Phaedrux
            @Phaedrux the connection died and didn't come back. Same behaviour as last night when I tried. Ill have to pull the SD card and redo the IP to make it work again most likely.
              @prcdslnc13 Thanks, interesting. The first thing I see after loading it is:
              because no Z-probe input pin was specified.
              Also no fans seem to be present in the preset, so I am a bit puzzled how you could get it to generate NaN/undefined values. Sorry to be a PITA but can you provide step-by-step instructions to reproduce a faulty config?
                @chrishamm no worries I understand where you are coming from. I am not sure how I got that json file. These are the settings I used to get the config that I have now. I ended up just copying the config file from the last link. That may have been my issue? Here is the config.json these settings generated.
                config.json
                  @prcdslnc13 Thanks, I tried to reproduce it but I couldn't get NaN/undefined values with those inputs or your config.json.
                    @chrishamm Ive been trying to replicate it as well with no luck.
                    Any ideas on the network issue I initially posted about?
                      @prcdslnc13 Can you repeat this and check for other errors?
                      @dc42 said in No IP address after updating from config tool Mini 5+ Ethernet:
                      @prcdslnc13 if you run M98 P"config.g" do you see any error messages?
                        No errors with this config.g
                        config (2).g
                          This address is a bit odd. What subnet mask are you using for your network? .86. is a bit unusual. I would expect it to be .1. Perhaps you need to specify a custom subnet mask as well with M553
                          https://docs.duet3d.com/en/User_manual/Reference/Gcodes#m553-set-netmask
                          By default it is 255.255.255.0 but perhaps you need 255.255.0.0
                            @Phaedrux I understand your thinking but it’s 255.255.255.0.
                            My mesh router setup defaulted to 86 for my subnet when I set it all up and it seemed reasonable to leave it
                            chrishammundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
                              @prcdslnc13 I have no good explanation why it only works after the second attempt. Does it work at the first try if you comment out the network M-code M552 in your config and then send the same command via serial/USB/PanelDue? Perhaps try a different microSD card or format it again, maybe it's a bit dodgy.
                                Phaedrux Moderator @prcdslnc13
                                @prcdslnc13 said in No IP address after updating from config tool Mini 5+ Ethernet:
                                Does the mesh network put out a 2.4 and 5ghz network with the same name?
                                  @Phaedrux yes there is no seperate network names or channels
