    Printer Ignoring My Offsets
    511
    • ScubaDogeundefined
      ScubaDoge
      I am trying to set up my printer with a genuine bl touch and it just seems to ignore my offsets and print in mid air. I get the following error when running g29.
      "Warning: the height map has a substantial Z offset. Suggest use Z-probe to establish Z=0 datum, then re-probe the mesh.
      30 points probed, min error -4.475, max error -3.863, mean -4.249, deviation 0.178
      Height map saved to file 0:/sys/heightmap.csv"
      This is my starting G-Code
      ; Ender 3 Custom Start G-code
      G92 E0 ; Reset Extruder
      G28 ; Home all axes
      G29
      M104 S{material_standby_temperature} ; Start heating up the nozzle most of the way
      M190 S{material_bed_temperature_layer_0} ; Start heating the bed, wait until target temperature reached
      M109 S{material_print_temperature_layer_0} ; Finish heating the nozzle
      G1 Z2.0 F3000 ; Move Z Axis up little to prevent scratching of Heat Bed
      G1 X0.1 Y20 Z0.3 F5000.0 ; Move to start position
      G1 X0.1 Y200.0 Z0.3 F1500.0 E15 ; Draw the first line
      G1 X0.4 Y200.0 Z0.3 F5000.0 ; Move to side a little
      G1 X0.4 Y20 Z0.3 F1500.0 E30 ; Draw the second line
      G1 X5 Y20 Z0.3 F5000.0 ; Move over to prevent blob squish
      Here is my config.g bl touch settings:
      ; Z-Probe Bltouch
      M558 P9 H6 F300 T8000 R0.3 C"^probe" ; set Z probe type to bltouch and the dive height + speeds
      M950 S0 C"Servo0" ; Setup Servo0 as servo port on SKR-RRF-E3
      G31 P500 X-40 Y-12 Z-1.6 ; set Z probe trigger value, offset and trigger height
      M557 X10:230 Y10:230 S40 ; define mesh grid
      If I try and run a print it just prints in mid air and adjusting the z offset in config.g doesn't seem to do anything.
      JamesMundefined 1 Reply Last reply Reply Quote 0
      • JamesMundefined
        JamesM @ScubaDoge
        @ScubaDoge
        I believe your G31 line is incorrect for your Z. It should be a positive number and not a negative.
        For my BL-touch on one of my corexy printers, my G31 line is this
        G31 P500 X-25.5 Y-20 Z2.62
        With a negative z, that means the probe would be higher than the nozzle and it would never make contact. That might make sense for someone using a piezo sensor where the nozzle itself presses on the bed but not for something like a bl-touch.
          It would help to see your full config.g and homeall.g file as well.
          ScubaDogeundefined 1 Reply Last reply Reply Quote 1
            ScubaDoge @Phaedrux
            @Phaedrux
            Height Map Photo
            Config.g:
            M550 P"Ender3Pro" ; set printer name
            M552 S0
            M586 P0 S1 ; enable HTTP
            M586 P1 S0 ; disable FTP
            M586 P2 S0 ; disable Telnet
            M569 P0 S0 ; physical drive 0 goes forwards using default driver timings
            M569 P1 S0 ; physical drive 1 goes forwards using default driver timings
            M569 P2 S1 ; physical drive 2 goes forwards using default driver timings
            M569 P3 S0 ; physical drive 3 goes forwards using default driver timings
            M92 X80.00 Y80.00 Z400.00 E93.00 ; set steps per mm
            M566 X900.00 Y900.00 Z60.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
            M203 X12000.00 Y12000.00 Z600.00 E1200.00 ; set maximum speeds (mm/min)
            M906 X580 Y580 Z580 E650 I30 ; set motor currents (mA) and motor idle factor in per cent
            M84 S30 ; Set idle timeout
            M208 X230 Y230 Z250 S0 ; set axis maxima
            M574 Z1 S1 P"zstop" ; configure active-high endstop for low end on Z via pin zstop
            ;M591 D0 P7 C"e0stop" S1 R50:130 L7.0 E10 ; BTT Smart Filament Sensor
            ;M591 D0 P1 S1 ; Filament runout Sensor
            ; Z-Probe Bltouch
            M308 S0 P"bedtemp" Y"thermistor" T100000 B3950 ; configure sensor 0 as thermistor on pin bedtemp
            M950 H0 C"bed" T0 ; create bed heater output on bed and map it to sensor 0
            M301 P21.73 I1.54 D76.55 ; disable bang-bang mode for the bed heater and set PWM limit
            M307 H0 R2 D65 B1 S1.00 ; disable bang-bang mode for the bed heater and set PWM limit
            M143 H0 S150 ; set temperature limit for heater 0 to 150C
            M308 S1 P"e0temp" Y"thermistor" T100000 B3950 ; configure sensor 1 as thermistor on pin e0temp
            M143 H1 S300 ; set temperature limit for heater 1 to 300C
            M950 F0 C"fan0" Q1000 ; create fan 0 on pin fan0 and set its frequency
            M950 F1 C"fan1" Q1000 ; create fan 1 on pin fan1 and set its frequency
            M106 P1 S0 H1 T60 ; set fan 1 value. Thermostatic control is turned on
            ;M575 P1 S1 B57600 ; enable support for PanelDue
            M575 P1 S2 B57600
            M552 S1 ; enable network
            M150 X2
            T0 P0
            M918 P1 E4 F100000
            Homeall.g
            G91 ; relative positioning
            G1 H1 X-240 Y-240 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
            G1 H2 X5 Y5 F6000 ; go back a few mm
            G1 H1 X-240 Y-240 F360 ; move slowly to X and Y axis endstops once more (second pass)
            ;G1 H1 Z-255 F360 ; move Z down stopping at the endstop
            M98 P"homez.g"
            G90 ; absolute positioning
            G92 Z0 ; set Z position to axis minimum (you may want to adjust this)
            ;G91 ; relative positioning
            ;G1 Z5 F100 ; lift Z relative to current position
            ;G90 ; absolute positioning
            Phaedruxundefined 2 Replies Last reply Reply Quote 0
              Phaedrux Moderator @ScubaDoge
              @ScubaDoge said in Printer Ignoring My Offsets:
              M98 P"homez.g"
              This is probably part of the problem.
              Can you post homez.g please?
              Whatever homez is doing, when it's done, you have it setting whatever position it's currently at as Z0.
                ScubaDoge @Phaedrux
                @Phaedrux
                Thank you for your help.
                homez.g
                17:25:01 GMT+0800 (中国标准时间)
                ;G1 H2 Z5 F6000 ; lift Z relative to current position
                ;G1 H1 Z-255 F1800 ; move Z down until the endstop is triggered
                ;G92 Z0 ; set Z position to axis minimum (you may want to adjust this)
                ; ################# Home Z Preparation ################
                G91 ; Relative mode
                G1 H2 Z5 F5000 ; Lower the bed
                G90 ; Back to absolute positioning
                G1 X117 Y117 F10000 ; Move to the center of the bed. Adjust to the co-ordinates required for the centre of your bed
                G30 ; Probe a single point
                  Simply delete this line from your homeall.g and I think things should be working better.
                    ScubaDoge @Phaedrux
                    @Phaedrux
                    Genius!
                    That definitely made a difference, and the height map looks a lot better.
                    If I have probe offsets for marlin, could I also use the same values with duet?
                    Also, I did notice it was skipping points on the bed.
                    I am running into this error.
                    1/11/2023, 1:39:31 AM 30 points probed, min error -0.215, max error 0.585, mean 0.283, deviation 0.193
                    1/11/2023, 1:39:19 AM Warning: Skipping grid point X=210.0, Y=170.0 because Z probe cannot reach it
                    Warning: Skipping grid point X=210.0, Y=210.0 because Z probe cannot reach it
                    1/11/2023, 1:38:42 AM Warning: Skipping grid point X=210.0, Y=90.0 because Z probe cannot reach it
                    Warning: Skipping grid point X=210.0, Y=130.0 because Z probe cannot reach it
                    1/11/2023, 1:38:10 AM G29
                    Warning: Skipping grid point X=210.0, Y=10.0 because Z probe cannot reach it
                    Warning: Skipping grid point X=210.0, Y=50.0 because Z probe cannot reach it
                    OwenDundefined 1 Reply Last reply Reply Quote 0
                    • OwenDundefined
                      OwenD @ScubaDoge
                      @ScubaDoge
                      1/11/2023, 1:39:19 AM Warning: Skipping grid point X=210.0, Y=170.0 because Z >probe cannot reach it
                      If your probe offsets in your G31 are correct then there's no way the probe can reach the coordinates specified for your mesh.
                      The M557 points try to put the probe over the specified spot.
                      If the probe is 40mm to the left of the nozzle, then you can easily get it to X10, but to get the probe to X230 means the nozzle must be at X270, which is bigger than your stated X maxima.
                      Same applies in the Y direction.
                      Check your offsets using the method here
                      Then drive the head to the furthest points in X that you can safely reach with the probe and mark the points with some tape or a marker.
                      Then drive the nozzle to these points and take note of the positions. These will be your min max for M557.
                      Repeat the process for the Y directions.
                      You should end up with something like M557 X3:187 Y3:215 (assuming you leave a few mm from the edge of the bed) if your offsets are in fact X-140 and Y-12.
                      ScubaDogeundefined 1 Reply Last reply Reply Quote 2
                        ScubaDoge @OwenD
                        @OwenD said in Printer Ignoring My Offsets:
                        @ScubaDoge
                        Owen thank you for that. It seems to be working a lot better now after those adjustments. I am trying to understand however why it isn't probing farther to the right. When I was running marlin, it would probe the exact center on its center home. When it probes with this software the nozzle is center not the probe. Do I have something set wrong?
                        • OwenDundefined
                          OwenD @ScubaDoge
                          @ScubaDoge
                          When you run G29, the firmware uses the probe offsets and moves to put the probe in the command position
                          When you are homing and use G30, it probes in the current position.
                          So you need to adjust your G1 command to place the probe in the center of the bed (or wherever you want it to be) before you call G30 to probe.
