Vivedino Troodon issues
hi i have a vivedino troodon i had an issue with the main board and i ended up replacing the board with a duet 2 Ethernet and duex 5 board but after doing this every time i go to home i get the error message in the image below and the motors do not move i have double checked the phases and done everything i could think of is there any thing else i could try if so it would be much appreciated
@ghostie Post your config.g and response to M122, and a picture of your Duet boards showing wiring. Have you tested a different motor connected to Driver 1? Driver 1 is the 'Y motor' connector on a Duet 2. See https://docs.duet3d.com/Duet3D_hardware/Duet_2_family/Duet_2_WiFi_Ethernet_Hardware_Overview#wiring-diagram
@droftarts hi in have tried this and it seems to work on the duet board but i am not 100% as the endstop switch and it does the same thing no mater which axis i home as it is a core xy machine i believe that it is an issue with the duet board but i wanted to check with some others first as this is my first time doing this and there are still some other bugs with the config
config.g -
Can you post your homing files as well in addition to the things requested by droftarts?
Have you tried sending a simple command to test motor movement?
G92 Y10
G1 Y2 F100Does that provoke the same error?
@Phaedrux I think this may be the issue introduced in RRD 3.1 that was fixed in either 3.3 or 3.4 (failed initialization of nonexisting drivers).
@oliof Thanks. His config.g does define Driver 1, though. While config.g says it's for 2.03, commands are for RRF3.
@ghostie Please supply the output from M122, after you get the message. Also please post a picture of your boards, showing wiring.Try connecting the Y motor to the unused Z_motor output (Driver 3 - make sure there are jumpers on the second drive header) and change these two lines in your config.g:
M569 P1 S1 ; B
M584 X0 Y1 Z5:6:7:8 E3:4to
M569 P2 S1 ; B ... M584 X0 Y2 Z5:6:7:8 E3:4
Does the error go away?
Your config.g, for easier reference:
; Configuration file for Duet WiFi (firmware version 2.03 or newer) ; executed by the firmware on start-up ; General preferences M111 S0 ; Debugging off G21 ; Work in millimetres G90 ; Send absolute coordinates... M83 ; ...but relative extruder moves M555 P2 ; Set firmware compatibility to look like Marlin M575 P1 B57600 S1 ; Comms parameters for PanelDue M564 S1 H1 ; Forbid axis movements when not homed ; General setup M669 K1 ; Select CoreXY mode (2.03 and up) ; Network M550 P"Voron" ; Set machine name M552 S1 ; Enable network M586 P0 S1 ; Enable HTTP (for DWC) M586 P1 S1 ; Enable FTP (for remote backups) M586 P2 S0 ; Disable Telnet ; --- drive map --- ; _______ ; | 6 | 7 | ; | ----- | ; | 5 | 8 | ; ------- ; front ; Drive directions M569 P0 S1 ; A M569 P1 S1 ; B M569 P3 S1 ; Extruder #1 ;M569 P4 S0 ; Extruder #2 M569 P5 S1 ; Z1 M569 P6 S0 ; Z2 M569 P7 S1 ; Z3 M569 P8 S0 ; Z4 ; Motor mapping and steps per mm M584 X0 Y1 Z5:6:7:8 E3:4 M350 X16 Y16 Z16 I1 ; Use 1/16 microstepping with interpolation everywhere M350 E16:16 I1; ; no microstepping on the extruder M92 X80 Y80 Z400 ; Set XYZ steps per mm (1.8deg motors) ;M92 X160 Y160 Z800 ; Set XYZ steps per mm (0.9deg motors) M92 E404:404 ;417 was original - after tuning 405 was slightly over 100mm. Therefore, 404 ;M350 Z16 I0 ; disable Z interpolation M591 D0 P1 C"e0_stop" S1; ; Drive currents M906 X1200 Y1200 Z1200 E1000 ; XYZ and E current M906 I30 ; Idle current percentage M84 S120 ; Idle timeout ; Endstops M574 X2 S1 P"xstop" ; X max active low endstop switch M574 Y2 S1 P"ystop" ; Y max active low endstop switch M208 X0 Y0 Z0 S1 ; Set axis minima M208 X400 Y400 Z500 S0 ; Set axis maxima ; Bed leveling ;M671 X-65:-65:265:265 Y-20:280:280:-20 S20 ; Define Z belts locations (Front_Left, Back_Left, Back_Right, Front_Right) M671 X-65:-65:320:320 Y-20:350:350:-20 S20 ; Define Z belts locations (Front_Left, Back_Left, Back_Right, Front_Right) M557 X50:200 Y50:200 S25 ; Define bed mesh grid (inductive probe, positions include the Z offset!) ; Accelerations and speed M350 X16 Y16 Z16 E16 I1 ; microstepping with interpolation (I1) M92 X80 Y80 Z400 E400 ; steps per mm - with bt M566 X2000 Y2000 Z602.65 E1000 ; maximum instantaneous speed changes (mm/min) (jerk) M203 X20000 Y20000 Z1500 E10000 ; maximum speeds (mm/min) M201 X1500 Y1500 Z500 E10000 ; accelerations M906 X1200 Y1200 Z1200 E1250 I60 ; motor currents (mA) and motor idle factor in per cent M84 S60 ; set idle timeout ; Heated bed #0 ;Create Heater Thermistor ;A: Name ;P: pin ;Y: type M308 A"Heater Temp" P"bedtemp" Y"thermistor" S0 T100000 B3950 M950 H0 C"bedheat" Q10 T0 ; create heater T0 10Hz SSR M140 H0 ; set temp to 0C M143 H0 S115 ; set the maximum bed temperature to 115C ; Hotend #1 heater M308 S1 P"e0temp" Y"thermistor" T100000 B4092 ; define thermistor M950 H1 C"e0heat" Q100 T1; ; define heater, connect to thermistor M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit M143 H1 295 ; Max hot end temp 295C M950 F1 C"fan1" Q100 ; fan for hot end M106 P1 T45 H1 ; Set fan 1 to on when hot end goes > 45C M950 F0 C"fan0" Q100 M106 P0 C"Part Cooling" ;Side Fans M950 F5 C"duex.fan5" Q100; M950 F6 C"duex.fan6" Q100; M106 C"Electronics Bay"P5 T45:65 F50 H100:101:102 ; Electronics bay fan, turn on gradually if MCU is over 45C or any TMC driver is over temp M106 C"Electronics Bay"P6 T45:65 F50 H100:101:102 ; Electronics bay fan, turn on gradually if MCU is over 45C or any TMC driver is over temp ; Disable unused heaters (so they are hidden on the PanelDue) ; Bltouch ; Z-Probe M574 Z0 P"nil" ; no Z endstop switch, free up Z endstop input M558 P9 C"^zprobe.in" H5 R1 F120 T6000 A5 S0.02 ;BLTouch connected to Z probe IN pin M950 S0 C"duex.pwm5" G31 P50 X0 Y21 Z3.0 ; Set Z probe trigger value, offset and trigger height M557 X15:285 Y15:285 S50 ; Define mesh grid ; Fans ;M106 P3 S1 I0 H1 T50 ; E3D V6 Hotend fan, turns on if temperature sensor 1 reaches 50 degrees ;M106 P3 S0.6 I0 H1 T50 ; Mosquito Hotend fan @ 60%, turns on if temperature sensor 1 reaches 50 degrees ;M106 P4 S0 I0 H-1 ; Part cooling fan, no thermostatic control ;M106 P5 T45:65 F50 H100:101:102 ; Electronics bay fan, turn on gradually if MCU is over 45C or any TMC driver is over temp ;M106 P8 S1 H0 T50 ; Chamber filter fan, turn on when bed is hotter than 50C ; Tools M563 P0 D0 H1 F0 ; Define tool 0 G10 P0 X0 Y0 Z0 ; Set tool 0 axis offsets G10 P0 R0 S0 ; Set initial tool 0 active and standby temperatures to 0C ; Enable pressure advance ; 0.085 was damn near perfect. Slight blobbing. Upping to 0.087. M572 D0 S0.087 M501 ; load config-override.g T0 ; select tool 0
@oliof said in Vivedino Troodon issues:
I thought so too, but it sounds like it's no longer running the troodon board?
@ghostie said in Vivedino Troodon issues:
