    3.5.0b1+ Wifi error - SPI timeout
    Beta Firmware
    8
    39
    1.7k
    • OwenDundefined
      OwenD
      Just finished a six hour print and when I went to the shed to remove the print I found the PanelDue flashing between the screen saver and en error message (see attached video)
      I was unable to access the machine either from the PanelDue or DWC and was forced to restart.
      I have seen this on one other occasion shortly after I upgraded.
      The error reads..
      "Error failed to retrieve WiFi status : SPI timeout"
      In my haste to start the next print before bed I forgot to get an immediate M122.
      This one was taken a few minutes after starting the print.
      I don't get good wifi in the shed, so the occasional wifi dropout is not that unusual.
      However it usually reconnects leaving a notice on the PanelDue.
      Interestingly, the Wifi signal in the M122 report is showing 0dbm
      M122
      RepRapFirmware for Duet 2 WiFi/Ethernet version 3.5beta1+ (2023-01-10 20:40:02) running on Duet WiFi 1.02 or later
      Board ID: 08DGM-917NK-F2MS4-7J1DA-3S86T-TZTWD
      Used output buffers: 4 of 26 (23 max)
      Static ram: 22188
      Dynamic ram: 79984 of which 0 recycled
      Never used RAM 7340, free system stack 122 words
      Tasks: NETWORK(ready,13.3%,233) ACCEL(notifyWait,0.0%,348) HEAT(notifyWait,0.0%,330) Move(notifyWait,0.0%,285) MAIN(running,85.6%,502) IDLE(ready,1.1%,30), total 100.0%
      Owned mutexes: WiFi(NETWORK)
      Last reset 00:04:28 ago, cause: power up
      Last software reset at 2023-01-12 15:51, reason: User, GCodes spinning, available RAM 6048, slot 2
      Error status: 0x08
      Aux0 errors 0,0,0
      Step timer max interval 0
      MCU temperature: min 26.0, current 27.8, max 30.0
      Supply voltage: min 0.2, current 24.3, max 24.5, under voltage events: 0, over voltage events: 0, power good: yes
      Heap OK, handles allocated/used 99/21, heap memory allocated/used/recyclable 2048/776/480, gc cycles 0
      Events: 0 queued, 0 completed
      Driver 0: standstill, SG min n/a
      Driver 1: standstill, SG min 460
      Driver 2: ok, SG min 0
      Driver 3: standstill, SG min n/a
      Driver 4: standstill, SG min 377
      Driver 5:
      Driver 6:
      Driver 7:
      Driver 8:
      Driver 9:
      Driver 10:
      Driver 11:
      Date/time: 2023-01-12 21:29:15
      Slowest loop: 382.76ms; fastest: 0.12ms
      === Storage ===
      Free file entries: 7
      SD card longest read time 7.2ms, write time 98.3ms, max retries 0
      DMs created 83, segments created 19, maxWait 222778ms, bed compensation in use: none, comp offset 0.000
      next step interrupt due in 772 ticks, disabled
      === DDARing 0 ===
      Scheduled moves 15, completed 14, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state 3
      Heater 0 is on, I-accum = 0.2
      Movement locks held by File
      HTTP is idle in state(s) 0
      Telnet is idle in state(s) 0
      File is idle in state(s) 42 0, running macro
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Trigger is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      Daemon is doing "G4 S2 " in state(s) 0 0, running macro
      Q0 segments left 0
      Code queue 0 is empty
      === Filament sensors ===
      Extruder 0 sensor: ok
      === Network ===
      Slowest loop: 79.65ms; fastest: 0.00ms
      Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
      HTTP sessions: 1 of 8
      = WiFi =
      Network state is active
      WiFi firmware version 2.1beta2
      WiFi MAC address bc:dd:c2:89:a0:bb
      WiFi Vcc 3.38, reset reason Power up
      WiFi flash size 4194304, free heap 37848
      WiFi IP address 192.168.1.163
      WiFi signal strength 0dBm, mode 802.11n, reconnections 0, sleep mode modem
      Clock register 00002002
      IMG_5383.mp4
      OwenDundefined 1 Reply Last reply Reply Quote 0
      • OwenDundefined
        OwenD @OwenD
        @OwenD
        So nearing the end of my next print and I lost DWC connection.
        Inspection of the machine shows the print still running but the same error messages flashing on the screen.
        This time I was able to connect via USB and get an M122 report with it still running.
        I should note that this machine has been in the same spot for > 2 years and this error has only just started since 3.5.0
        The poor signal has always been there, but the behaviour is new.
        I was able to send
        M552 S-1 M552 S1 from YAT to restart it
        Error: failed to retrieve WiFi status message: SPI timeout
        M122<CR>
        Used output buffers: 1 of 26 (26 max)
        Static ram: 22188
        Dynamic ram: 80056 of which 132 recycled
        Never used RAM 6368, free system stack 88 words
        Tasks: NETWORK(notifyWait,36.7%,216) ACCEL(notifyWait,0.0%,348) HEAT(notifyWait,0.6%,305) Move(notifyWait,31.7%,281) MAIN(running,25.4%,460) IDLE(ready,5.6%,30), total 100.0%
        Owned mutexes: WiFi(NETWORK) USB(MAIN)
        Last reset 10:13:44 ago, cause: power up
        Error status: 0x0c
        Aux0 errors 0,0,0
        MCU temperature: min 26.8, current 28.2, max 29.8
        Supply voltage: min 24.0, current 24.2, max 24.5, under voltage events: 0, over voltage events: 0, power good: yes
        Heap OK, handles allocated/used 99/20, heap memory allocated/used/recyclable 2048/1580/1192, gc cycles 360
        Events: 1 queued, 1 completed
        Driver 1: standstill, SG min 0
        Driver 2: standstill, SG min 0
        Driver 3: ok, SG min 0
        Driver 4: ok, SG min 279
        Driver 5:
        Driver 6:
        Driver 7:
        Driver 8:
        Driver 9:
        Driver 10:
        Driver 11:
        Date/time: 2023-01-13 07:38:31
        Slowest loop: 146.73ms; fastest: 0.11ms
        === Storage ===
        Free file entries: 8
        SD card longest read time 10.9ms, write time 74.4ms, max retries 0
        DMs created 83, segments created 51, maxWait 7093ms, bed compensation in use: mesh, comp offset 0.000
        next step interrupt due in 15 ticks, disabled
        === DDARing 0 ===
        Scheduled moves 1265796, completed 1265793, hiccups 0, stepErrors 0, LaErrors 0, Underruns [516, 1, 363], CDDA state 3
        Heater 0 is on, I-accum = 0.1
        Heater 1 is on, I-accum = 0.5
        Movement locks held by null
        File is doing "G1 X28.99 Y125.475 E0.06689" in state(s) 0
        USB is ready with "M122" in state(s) 0
        Q0 segments left 1
        === Network ===
        Slowest loop: 121.70ms; fastest: 0.07ms
        HTTP sessions: 0 of 8
        = WiFi =
        Failed messages: pending 0, notready 5, noresp 7705
        Failed to get WiFi status
        ok
        • OwenDundefined
          OwenD @OwenD
          @OwenD said in 3.5.0b1+ Wifi error - SPI timeout:
          Slightly off topic, but what does this line mean?
          i.e. What are under-runs and does this value signify an issue of some sort I should be looking into?
            dc42 administrators @OwenD
            @OwenD are you running the original 3.5beta1 binary or the version with the G32 fix linked to at https://forum.duet3d.com/post/303514 ?
            • OwenDundefined
              OwenD @dc42
              Good question.
              It looks like I still have one I compiled from source a few days ago.
              Board: Duet 2 WiFi (2WiFi)
              Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.5beta1+ (2023-01-10)
              I haven't made any changes, so I presume it will have the fixes you mention.
              I can upload the last release if it will make it easier to track.
                @OwenD that depends on when you pulled the source files from github.
                • OwenDundefined
                  OwenD @dc42
                  @dc42 said in 3.5.0b1+ Wifi error - SPI timeout:
                  It would have been the same day, but I'll revert and run another print just to be sure.
                  • OwenDundefined
                    OwenD @OwenD
                    @OwenD
                    I've run several prints with no re-occurrence of this issue, so I'll mark this as solved.
                    If it crops up again, I'll re-visit.
                    OwenDundefined 1 Reply Last reply Reply Quote 1
                    • OwenDundefined OwenD marked this topic as a question
                    • OwenDundefined OwenD has marked this topic as solved
                    • OwenDundefined
                      OwenD @OwenD
                      Came home from work today to find this had re-occurred.
                      The printer has been idle for several days apart from some macro debugging last night.
                      When it occurs the PanelDue is flooded with error messages at a very high rate.
                      Connected by USB and got an M122 report.
                      M122
                      RepRapFirmware for Duet 2 WiFi/Ethernet version 3.5beta1+ (2022-12-31 17:10:26) running on Duet WiFi 1.02 or later
                      Static ram: 22148
                      Dynamic ram: 79236 of which 216 recycled
                      Never used RAM 4712, free system stack 192 words
                      Tasks: NETWORK(notifyWait,37.1%,233) ACCEL(notifyWait,0.0%,348) HEAT(notifyWait,0.6%,330) Move(notifyWait,0.1%,362) MAIN(running,60.8%,331) IDLE(ready,1.6%,30), total 100.0%
                      Last reset 23:57:15 ago, cause: software
                      Last software reset at 2023-01-19 19:22, reason: User, GCodes spinning, available RAM 8228, slot 2
                      Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a
                      Error status: 0x00
                      Aux0 errors 0,0,0
                      MCU temperature: min 27.3, current 29.4, max 34.3
                      Supply voltage: min 0.4, current 0.5, max 0.5, under voltage events: 0, over voltage events: 0, power good: no
                      Heap OK, handles allocated/used 297/195, heap memory allocated/used/recyclable 4096/3648/484, gc cycles 89
                      Driver 0: ok, SG min n/a
                      Driver 1: ok, SG min n/a
                      Driver 2: ok, SG min n/a
                      Driver 3: ok, SG min n/a
                      Driver 4: ok, SG min n/a
                      Driver 5:
                      Driver 6:
                      Driver 7:
                      Driver 8:
                      Driver 9:
                      Driver 10:
                      Driver 11:
                      Date/time: 2023-01-20 19:19:46
                      Slowest loop: 97.05ms; fastest: 0.07ms
                      === Storage ===
                      Free file entries: 10
                      SD card longest read time 4.8ms, write time 131.9ms, max retries 0
                      DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000
                      no step interrupt scheduled
                      === DDARing 0 ===
                      File is idle in state(s) 0
                      Daemon is idle in state(s) 0
                      Q0 segments left 0
                      === Network ===
                      Slowest loop: 523.09ms; fastest: 0.00ms
                      = WiFi =
                      Failed messages: pending 0, notready 5, noresp 775826
                      ok
                      • OwenDundefined OwenD has marked this topic as unsolved
                        jay_s_uk @OwenD
                        @OwenD before you reset could you try activating wifi debugging over USB?
                        M111 P14 S1
                        • OwenDundefined
                          OwenD @jay_s_uk
                          @jay_s_uk
                          Will do.
                          Not sure how long it will take before it will occur again.
                          T3P3Tonyundefined dc42undefined 2 Replies Last reply Reply Quote 1
                          • T3P3Tonyundefined
                            T3P3Tony administrators @OwenD
                            @OwenD also it would be helpful to get a summary of how (in)frequently this occurs and confirmation of the firmware and wifi firmware versions running.
                            www.duet3d.com
                            • jay_s_ukundefined jay_s_uk referenced this topic
                              @OwenD version 2.1beta2 of DuetWiFiSocketServer has been replaced by 2.1beta3 available at https://github.com/Duet3D/WiFiSocketServerRTOS/releases/tag/2.1beta3.
                              • OwenDundefined
                                OwenD @dc42
                                @dc42 @T3P3Tony
                                I'm afraid I haven't been able to reproduce this and I can't determine one factor that has "fixed" it.
                                I do have a few observations.
                                I used to get the occasional message on PanelDue that said that the WiFi had been successfully reconnected.
                                This is a modal message, so it could have happened at any time and I wouldn't see it until I went to the shed.
                                My wifi signal in the shed has always been around -51db, not horrible, but not great either.
                                After this issue arose, I went and got a wifi range extender.
                                This boosted the signal to around -41 to -44db
                                Note: That I hadn't had a re-occurrence BEFORE I put the extender on.
                                I don't know what signal I showed with 2.1beta2 as it didn't report it.
                                I just installed 2.1beta3
                                My first M122 showed a signal of -36db with the extender!
                                = WiFi =
                                WiFi firmware version 2.1beta3
                                WiFi flash size 2097152, free heap 39380
                                WiFi signal strength -36dBm, mode 802.11n, reconnections 0, sleep mode modem
                                I then went back in versions and did reports on each, both with and without the extender.
                                No extender
                                = WiFi =
                                WiFi Vcc 3.38, reset reason Turned on by main processor
                                WiFi flash size 2097152, free heap 39440
                                WiFi signal strength -41dBm, mode 802.11n, reconnections 0, sleep mode modem
                                No extender
                                = WiFi =
                                WiFi firmware version 1.27
                                WiFi flash size 4194304, free heap 23776
                                WiFi signal strength -51dBm, mode 802.11n, reconnections 0, sleep mode modem
                                No extender
                                = WiFi =
                                WiFi flash size 2097152, free heap 40992
                                WiFi signal strength -44dBm, mode 802.11n, reconnections 0, sleep mode modem
                                With extender
                                = WiFi =
                                WiFi flash size 2097152, free heap 38844
                                WiFi signal strength -37dBm, mode 802.11n, reconnections 0, sleep mode modem
                                I'm not sure how the firmware version can increase the signal so dramatically?
                                I'm inclined to mark this as solved again simply because I can't repeat it reliably, so if nobody else is complaining it's not worth chasing.
                                  @OwenD thanks for reporting this. Versions 1.x and 2.x of the WiFi firmware use different versions of the Expressif SDK. I guess either one of those SDK versions is mis-reporting RSSI, or they have changed the interface and we didn't pick that up. I will check the version 2.x code.
                                  • OwenDundefined
                                    OwenD
                                    So for some reason this has reared it's head again a couple of times lately.
                                    My system has a 5v power supply which powers the duet and switches a 24 volt power supply via the ATX pin as required.
                                    Before resetting I ran M111 P14 S1, then M122
                                    YAT seems to have dumped that report due to the volume of lines added, so I've only got the report immediately after restarting.
                                    For some reason the MCU voltage shows a very low value until I run M80 and kick the 24v power supply into action. Not sure if that's related.
                                    It does the same regardless of this wifi anomaly.
                                    ResponseTimeout, pending=1
                                    ESP reported status change
                                    M111 P14 S1
                                    Debugging enabled for modules: WiFi(14 - 0xffffffff)
                                    Debugging disabled for modules: Platform(0) Network(1) Webserver(2) Gcodes(3) Move(4) Heat(5) Dda(6) unused1(7) unused2(8) PrintMonitor(9) Storage(10) PortControl(11) DuetExpansion(12) FilamentSensors(13) Display(15) SbcInterface(16) Can(17)
                                    M122
                                    RepRapFirmware for Duet 2 WiFi/Ethernet version 3.5beta2+ (2023-02-12 12:52:31) running on Duet WiFi 1.02 or later
                                    Used output buffers: 1 of 26 (11 max)
                                    Static ram: 22216
                                    Dynamic ram: 79456 of which 12 recycled
                                    Never used RAM 8284, free system stack 184 words
                                    Tasks: NETWORK(ready,10.9%,377) ACCEL(notifyWait,0.0%,348) HEAT(notifyWait,0.0%,327) Move(notifyWait,0.0%,361) MAIN(running,87.9%,502) IDLE(ready,1.1%,30), total 100.0%
                                    Last reset 00:01:21 ago, cause: power up
                                    Last software reset at 2023-02-15 03:34, reason: StuckInSpinLoop, Platform spinning, available RAM 7040, slot 0
                                    Software reset code 0x4080 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0040080f BFAR 0xe000ed38 SP 0x20003014 Task NETW Freestk 488 ok
                                    Stack: 00414fdf 00459cc2 010f0000 e8000000 400985ff 41c475a6 3edb9368 3331bb4c 40000000 b5ddd8b0 388ab355 bb360b61 3e2aaaab 3f800000 3f800000 41d94ba3 4354c416 41200000 3f800000 80000010 00414fa5 b5ddd8b0 388ab355 20010fbc 3e2aaa01 3f800000 20011248
                                    Error status: 0x00
                                    Aux0 errors 0,0,0
                                    MCU temperature: min 29.3, current 33.6, max 33.8
                                    Supply voltage: min 0.3, current 0.5, max 0.5, under voltage events: 0, over voltage events: 0, power good: no
                                    Heap OK, handles allocated/used 99/15, heap memory allocated/used/recyclable 2048/384/116, gc cycles 0
                                    Driver 5:
                                    Driver 6:
                                    Driver 7:
                                    Driver 8:
                                    Driver 9:
                                    Driver 10:
                                    Driver 11:
                                    Cache data hit count 3368987419
                                    Slowest loop: 7.82ms; fastest: 0.14ms
                                    === Storage ===
                                    SD card longest read time 1.0ms, write time 0.0ms, max retries 0
                                    === DDARing 0 ===
                                    Q0 segments left 0
                                    === Network ===
                                    Slowest loop: 7.76ms; fastest: 0.00ms
                                    = WiFi =
                                    WiFi Vcc 3.39, reset reason Power up
                                    WiFi flash size 2097152, free heap 45652
                                    WiFi signal strength -29dBm, mode 802.11n, reconnections 0, sleep mode modem
                                    ok
                                    WiFi: <ESC>[0mConns: 0:free, 1:free, 2:free, 3:free, 4:free, 5:free, 6:free, 7:free
                                    • OwenDundefined
                                      OwenD
                                      Some more info this morning.
                                      Normally I discover this problem either when I walk out to the garage to get a beer and see the PanelDue flashing ans SPI error, or I can't connect to DWC.
                                      This morning I opened my phone (to a previously open tab) and DWC was frozen.
                                      When I tried refreshing, it just said connecting and that the drive wasn't mounted.
                                      Suspecting an SD card issue, I checked the PanelDue wasn't displaying any errors.
                                      Sending M20 resulted in a normal listing, so the SD card has to be mounted.
                                      Maybe this is a red herring?
                                      DWC from my laptop just doesn't connect. "Can't find host"
                                      M20
                                      Begin file list
                                      random-moves-test.g
                                      Outer_Trays_0.2mm_PLA.gcode
                                      freak_Pin_0.14mm_PA-CF.gcode
                                      Inner_Trays_0.2mm_PLA.gcode
                                      SKEW_100mm_0.2mm_PLA.gcode
                                      cube_0.2mm_PLA.gcode
                                      Freak body large skirt_0.2mm_PA-CF.gcode
                                      YACS_0.2mm_PLA.gcode
                                      calibration_0.2mm_PLA.gcode
                                      monitor-pad-right_0.2mm_PLA.gcode
                                      calibration piece _0.2mm_PLA.gcode
                                      Box1_0.2mm_PLA.gcode
                                      EspChunky_0.2mm_PA-CF.gcode
                                      pump-filter_0.2mm_PA-CF.gcode
                                      End file list
                                      If I send M111 P14 S1, I immediately get a barrage of busy responses in YAT .
                                      M111 P14 S1
                                      ResponseBusy
                                      ResponseBusy
                                      ResponseBusy
                                      ResponseBusy
                                      ResponseBusy
                                      ResponseBusy
                                      ResponseBusy
                                      ResponseBusy
                                      ResponseBusy
                                      ResponseBusy
                                      ResponseBusy
                                      ResponseBusy
                                      ResponseBusy
                                      ResponseBusy
                                      ResponseBusy
                                      M111 S0
                                      ok
                                      If I try to do a network scan I get this
                                      M587.1
                                      Error: M587.1: failed to start scan: another SPI transfer is pending
                                        Can you try flashing back to 1.27 and seeing if this still happens? If so, I think it may be the module.
                                        • OwenDundefined
                                          OwenD
                                          @Phaedrux
                                          Can't rule out a hardware issue I guess.
                                          Have reverted back to 1.27 and will monitor.
                                          I did an M122 before and after the change.
                                          This is the network section. Note the not ready number and lack of IP address.
                                          === Network ===
                                          Slowest loop: 29273.09ms; fastest: 100.43ms
                                          = WiFi =
                                          Failed messages: pending 0, notready 42217, noresp 1
                                          Socket states: 6 0 0 0 0 0 0 0
                                          After reverting and restart.
                                          = WiFi =
                                          Failed messages: pending 0, notready 0, noresp 2
                                          WiFi flash size 4194304, free heap 24848
                                          WiFi signal strength -35dBm, mode 802.11n, reconnections 0, sleep mode modem
                                          • StreetFurnitureAustraliaundefined
                                            Hi, I have also been getting instability issue with the wifi since going to 3.5.0b1.
                                            The duet will drop off from the network midprint or even not connect at all unless i power it down and then back up.
